Chevrolet Cavalier: Head Gasket Issues
Hi, I was just searching the web for help with my cavalier, and came across this website, how awesome is this. I never knew this stuff was available. Anyways, I was reading some of the posts and it appears as though 95's have a history with crappy headgaskets. Am I making a fair assumption? I recently (January 2005)bought a 95 cavalier 2.2l Coupe, and within 1 month I had to have the head gasket done. Now it is June 21, and guess what, I am having the head gasket done AGAIN! Is this normal? Am I going to keep having this problem every 6 months? Any ideas of what could be causing this? I was told back in January that they replaced the thermostat when they did the head gasket, but I think they were full of it! It's gotten to the point when I am waiting at a traffic light, I have to turn off my car so it won't overheat! Makes for a unejoyable experience. BUT....I STILL LOVE MY CAR!!
Mandi
Mandi
My wife and I traded our otherwise perfectly good 1995 Cavalier for a Mazda Protege5 in 2002 because, at 52,000 miles, we were in need of our FOURTH head gasket in the car! Chevy knew there was a problem and warranted the original head gasket for 100,000 miles -- but once you had the original replaced, you were on your own to the tune of about $600 each time. Oh, we went back and forth with the dealership and GM, to no avail. The first head gasket went at about 32,000 miles, and each subsequent one went anywhere from 6,000 to 8,000 miles before busting open and covering the engine with smelly green antifreeze. We got really tired of cleaning pools of antifreeze off our driveway and choking up $600 annually for a car that was so young. By comparison, by the way, the 2002 Protege5 has just crossed 50,000 miles and has yet to visit the shop for a problem of any kind.
It was one thing for GM to have a bad engine, but something even worse to not come clean and issue a recall for the real defect. They put band-aids on the problem instead of fixing the problem itself -- -- a poorly designed HEAD -- and then left their customers hanging. For that reason we now refer to my wife's former car as the "Crapalier" and have vowed never to patronize General Motors again.
If you love the Cavalier so much, trade it -- quick -- for a 1997 or newer model with the Ecotec engine. It'll be the same look and the same interior, but with a much more reliable engine under the hood.
Meade
Meade
For the record, I purchased the '95 Cavalier because it was all I could afford. The car looked well taken care of, had exceptionally low mileage; I ran a carfax on it, and believe I did everything possible to assure myself that this was a "good little vehicle for me." I had no idea that the car had gasket and all of the other problems because I had my mechaniccheck it out (who until then I trusted) tell me it was a "great" little car, buy it! Some of us can't just purchase a vehicle and "run" either. Nice thought but I'm not one who can.
One shop sez its the head gasket. Another sez its not the head gasket but he's uncertain what is wrong. Anyone else run into this problem? Thanks.
I have a 96 chevy cavalier with 173K miles on it.
Since past 1 week, I am facing a problem of overheating. When I start the car, it says, COOLANT is low and after running for @ 1 to 1.5 miles, the car temp increases to Maximum.
I got my car checked for this problem. They are also clueless about the problem.
Can anyone suggest me the cost effective way of removing the problem??
regs
oscorp
You have to be careful, there's a lot of bunk repair places out there. A friend of mine had the heads gone though on his Dodge motor home. They failed to replace a couple of stretched valves, one broke and ended up destoying the motor. He got what he paid for.
This motor can't handle too much heat, problem with aluminum in general also the way it's built, light and cheap... too much heat they warp and crack, the mating surface between the head and block must be perfect. Let this motor overheat they WILL blow head gaskets. This is a fact.
If you see steam or liquid leaking from between the head and block you can bet it's a head gasket. If you see steam in the exhaust, head gasket or cracked head. Oil in the water or water in the oil, same thing.
I just replaced the timing chain and it starts but misses.
Bought compr. tester...
0 on #1,
155 on #2,
140 on #3,
150 on #4
Must be at least 1 bent valve.
I'm not sure if I'm brave enough but I might do it.(I did the chain and they didn't make that too easy did they?)
Any advise would be muchly appreciated
I did not remove the intake or exhaust manifold, left them on. I disconnected the throttle and cruise at the throttle body. I removed the power steering pump bracket bolts attached to the head, left the lines on just pushed it off to the side. Exhaust pipe at manifold,electrical connectors as needed, there should be on the drivers side a EGR tube to disconnect on the back of the engine. I may have missed something but if it will not lift off with ease after breaking the gasket loose look around.
With everything still on I laid the head up side down on a old blanket. I used a razor blade scraper to remove the old gasket material, don’t use an abrasive cleaner like Scotch pads. When you scrape the block be careful not to drop anything down in the engine, a small shop vacuum work good for this.
If you need to strip the head for valve work it‘s easier to do on the bench.
I would rather do a head gasket then a chain. Good Luck.
What if I had to replace the head? I'm sure I have valve problems in one cyl. One Shop will sell me a rebuilt head for $200 with exchange. What do you think about that price and would you remove parts differently if you are replacing the head (exhaust, fuel, etc.)?
Thanks alot!!
I would do just like I said, easier to strip the head on the bench and build it back up on the bench. The 98 on had a new style air induction and valve cover and other changes, it is still the same engine just some upgrades. The 97 should have the valve cover with length wise ridges, the 98 on the valve cover is smooth. My truck with the 99 2.2 has the smooth cover.
On a side note I had the Head Gasket replaced (under warranty) in 1998 @70,000 miles. The car now has 136,000 and I had the whole head replaced.
:confuse:
I would like to talk about 2.2L Corsica but no format exist on this web site. Do you have any solution?
Thanx
Lets begin (assuming it is the 2.2 OHV); before starting make sure you have the fallowing; new gasket, sealant, torque wrench ( can be rented if needed), assorted metric and SAE sockets and wrenchs,plyers and .
Wait for the ENGINE to be COMPLETLY COOL OR MANY THINGS COULD POSSIBLY GO WRONG INCLUDING NASTY BURNS!!!! First begin by removing the resonator ( black plastic thing over the throttle body). To do so you'll need nice a 10mm socket and ratchet. Unbolt the resonator mounting bolt using the 10mm socket. Once this is done you can remove the resonator by GENTLY lifting it from the throtle body.
Once the resonator is removed, you will need to remove a "metal sheild" that protects the fuel rail. To remove this you will need a 13mm wrench (size maybe abit off, if it is simply trial and error until you find the proper side). There are two (2) bolts ontop of "the sheild" and three (3) located on the rear. Once thats out of the way your ready to begin unbolting the valve cover.
To unbolt the valve cover you'll need to use the 10mm ratchet and socket used earlier for the resonator. There a total of six (6) bolts to unbolt. If the bolts are rusted or seized up, use penetrating fluid (WD-40, Engine Oil) to loosen the rust. Once the bolts have been removed, your ready to lift of the valve cover. Place the cover and cover bolts in a safe location and be carful not to lose any bolts. If the valve cover is stuck, use a block of and a mallet to tap off the cover.
Once the cover is off, remove the old gasket from the cover and remove all traces of old gasket and sealent from the mating surface. To remove the old sealant use a shop rag soaked in Kerosen. MAKE SURE YOU STORE THE USED RAGS SAFLEY!!!! Once that is done, install apply some RTV sealant to valve cover and install the gasket on the cover. When this is done, put the cover back on. MAKE ABSOLUTELY SURE THAT ALL TRACES OF THE OLD GASKET HAVE BEEN REMOVED OR AN OIL LEAK CAN/WILL OCCUR!!!!
Using the torque wrench install the valve cover bolts to Chevrolet's torque specifications. Install the fuel rail protective sheild and the resonator and you are done! I also strongly suggest that you pick up a Haynes repair manual (15-20 CDN$). They contain tons of pictures and tips to make the job easier. Have fun and keep that hard earned money! If you have any questions Pep Boys, NAPA, Partsource (if your in Canada) will be glad to provide any advice!
I've recently had the following replaced: water pump (after car overheated a month ago), alternator, battery, starter (about 7 mo. ago), new spark plugs, new brakes, all new tires and a serpentine belt. I get oil changes every 3,000-3,500 miles. I drive mostly on the highway to commute 20 miles to and from work every day and some in town driving. I am so frustrated as I have put so much money into this vehicle. I am looking to buy a new (used) car soon but need this car to last me at least another month or two.
Any advice would be appreciated. Thank you.
p.s. - My power steering also seems screwed up since I got it back from the shop. I've had this happen before for brief times but it would always go back to normal.
The last head gasket I replaced was in '82 on a Ford Fiesta. When that went it broke a valve (the replacement was incorrectly listed at the dealer and it took 3 days to get the right valve - after I took a good one and showed them that their replacement was incorrect!)
Any thoughts on whether it's a gasket, head or worse?
140,000 miles.
My mechanic identified that the head gasket was leaking hydrocarbons at something like 35 parts per million. Said it should be zero. He didn't want to take the engine apart to fix it and so applied SteelSeal. The hydrocarbons are now down to 15 parts per million.
I am looking to sell this car. Figure that the buyer will have a head gasket repair job sometime in a year or so (and of course I'll be up front about it), but am concerned that because it was not fully repaired I might be mistaken and the buyer will be stuck with a repair job very soon.
Mechanic said that the hydrocarbon leak would not cause it to fail a smog check.
Opinions?
I had a 1997 Dodge Neon that I bought because I liked the look and the way it ran and handled. It was a 2.0 DOHC Sport model. Little did I know when I bought it 5 years ago that they were notorious for head gasket problems. 2 or 3 years later, I had a blown head and dropped $800 to repair it. I really don't want to go through that again.
I know my dad said they had 2.2 engines in their Dodge trucks when he worked for the Department of Transportation, and that they were junk. These were older 2.2's, and not the Ecotec.
I'm also considering a 2004 Kia Optima. The reason I'm leaning to the Cavalier is I thought it could save me more money all the way around... on gas, on insurance, on parts and maintenance. I'm not dirt poor, mostly because I live alone, but I'm definitely not rich either. I'm a one vehicle owner, so I need something dependable.
Long story short, I had another mechanic look it over and he pressure tested the system and told me the water pump was leaking, a sensor that makes the fan come on was bad and the sensor wasn't switching the fan on, and I might have a blown head gasket. He replaced the water pump, he replaced the thermostat, replaced the sensor, he flushed the system and added some sealer - I think he called it Red Devil -- and said it was a temporary fix for a head gasket problem. He drove it around and said he thought it was ok for awhile.
I am a nervous wreck now to drive it. I figure I'll have to get that gasket replaced eventually, but how long do you think I have? I'll need to save money in order to get it done, otherwise I would have had him do it today. Is it possible that the water pump could have been the big problem or is it definitely a head gasket problem when the coolant leaks and the car temp gauge goes to H?
In any event, perhaps the repairs done will fix the problem. If the head gasket is in fact leaking, you won't get far with the car.
In the future, the proper tests for a head gasket leak are:
1. pressurize the system, remove spark plugs and inspect
2. inspect the oil for water intrusion
3. test the radiator coolant for combustion gases with the proper tester
4. compression test that shows two low adjacent cylinders
5. white smoke out of exhaust pipe
6. rapid overheating
The general rule, to which there are exceptions, is that if you have a low speed overheat, that is, when the car is barely moving, you have an AIR circulation problem, (non-working fan for instance) and if you have a high speed overheat, that is when the car is moving fairly rapidly, you have a coolant circulation problem. (clogged radiator, stuck thermostat).
I brought it to the mechanic last night for him to look at the fan -- (to show me where it was actually) He is a friend's brother in law, so I do believe that he is honest. After the engine cooled down I checked and the coolant is staying in the resevoir -- no more big leakage in my garage yet the temp gauge climbs past halfway while driving in stop and go traffic under 50 miles an hour. I was very nervous seeing it climb past the halfway point since it never used to do that.
He checked it and showed me the fan was going while the A/C was on. Then he turned the A/C off and we waited and waited to see when or if the fan would kick back on by itself. It did eventually. So it seems not to be a fan problem. He said the temp outside has something to do with how hot an engine gets, and living in Florida it gets hot here. It is usually in the 90's everyday, most of the day and sunny. Driving it at night the temp gauge still goes past the mid point, but not by much. During the day it goes over 3/4 of the way and it seems dangerously close to the white line marking the space before the dreaded red zone of H.
Why is it running so much hotter? He said it was safe to drive it at 3/4 of the way over, but it scares me. He said to pull over and shut it off if it gets into the red H zone, of course. I spend all the time behind the wheel now staring at the gauge and praying for it not to move more. Why has it changed? (He replaced the water pump, the thermostat, some sensor, and put in that Red Devil sealant in case the gasket was going.) He didn't really have an answer that was definitive for me as to why it is running hotter. I thought maybe someone here with more experience would know. Is it safe to drive at 3/4 of the way over toward HOT? How can I get it back to the safer middle area?
