Infiniti M35/M45 Tires
in INFINITI
I just rode home in my (shiny) new M35x (AWD) and I get a burining smell from my tires...
Anyone else seen this problem (and NO I did not go over 60Mph).
Quite frankly, when I look at what my extra $$$ for the Sport w/ those wheels/tires bought me I doubt I'd go for another Sport particularly given the low-mileage driving I do (7K per year).
There are other manufacturers out there who make a 245/40R/19 that are considerably less costly than the 'Stones that might make sense if and when I have to replace ALL of my tires but when one goes I'm stuck w/ a perfect match. However, w/ my lease came a warranty whereby all tires will be replaced at no cost to me at lease end if tread wear is low.
Thus far, no more air leakage.
Bart :shades:
Other observations:
1.This did not suddenly occur, it has done this since it was new. (I just haven't gotten around to writing about it and I haven't brought it to the dealer's attention.)
2. It didn't happen with winter tires. I suppose that makes it an easy fix - new tires, but I wanted to see if anyone else found the same thing to be true.
3. On a smooth road without the rutted wear - no problem. Tracks just fine.
Anyone else experience this?
My wife has a Lexus GX470 that's tough to maintain on the straight and narrow at hiway speeds and folks on the Lexus thread have posted that changing to different tires on THAT vehicle (and I've forgotten what they were; possibly Cross Terrains?) stabilized the ride. Others found no difference with the upgraded tires.
Bart
Overall I love the car, and have no problems with the seating.
It actually gets BETTER gas mileage than the G35X which I got rid of..go figure.
I puzzled over this for a moment or two ... then realized it's the Long Island Expressway. Your gas mileage experience is interesting ... computed by hand or by the on-board computer? You're lugging around more weight in a brand new car so I would have expected the mileage to be LESS than the G35X ... don't look a gift horse in the face. Don't worry, be happy! LOL
thought a lot of it had to do with the fact
that it's a front-wheel drive car, whereas the
M35 is rear-wheel drive. The only switch in
tires that I made was when my Bridgestone
Potenzas were worn out at 45,000 miles, I
purchased Futura tires. The size is the same
and they're also V-rated tires. They do ride
a little better than the Potenzas did, but
I deal with the tracking/pulling issue still
when driving on less than stellar roads.
Quite encouraging to see this kind of mileage on OEM tires ... that will get me to the end of my 3 year lease w/ the OEM tires, save me $400/ tire to replace them for my use, and my add-on warranty covers tire replacement at lease end if tread's < 1/8". The downside may be that the 19" Potenzas on my Sport may not last as long? I believe someone posted similar numbers for their Potenzas a month ago, so he's hopin'! Bart
I have noticed the same thing, especially on roads where the surface has been "cupped" from the effects of tire wear. I have an M35x.
Back in the late 80's I had a Celica GTS which came with aggressive (at the time) low profile tires and experienced the same thing with that vehicle. At first, I thought it might be tires or the fact that it was front wheel drive. Changing the tires did not resolve the issue. I was told that if the road surface is not flat, vehicles with low profile tires are more sensitive to moving off track as they try to find a line.
They're available in 245/45-18 W speed rated.
I got 22k miles out of the RS-A's.
- Kai
M35x
If you have a chance, pleasev let me know why you selected the Michelin Pilot HX MXM4, I assume in 245/45 VR18? Tire Rack lists them at $236 each.
Can you comment on the ride quality of the M35x compared to the G35x? And can you also comment on the quietness between these two cars?
Bruce
Do you notice any handling problems as described in this forum?
J
Overall Ive had the car almost 3 months and its been fantastic. I dont have any complaints at all...
Good luck!
If you want to swap tires will tire retailers take your brand new RSA's in trade for another set of tires?
Glad you are enjoying the car.
We just drove my Audi A62.7T from Mass. to NY and if I enjoy my next car as much as this one I'll be more than satisfied. Lease price has gone way up on '07's so far.
J
The tire dealer said I may need to go to the dealer to reset.
S
Supposedly the G series uses a different computer, and will figure out what is there somehow, but, at least in the 2006 (don't know if they changed it for 2007), you can't do it yourself on the M.
If someone has successfully done this with a scantool, I'd really like to know!
B
However, my question is: Does this affect the stability control functionality if the car cannot read the sensors? The dealer is kind of far away and it is not that much of an issue not to have the tire pressure being monitored, but if it's a safety issue...
Thanks in advance for the comments.
S
Summer max performance tires. Bridgestone Potenza RE050A. Excellent dry handling tire. Pricey but down to a mere $245/tire at Tire Rack.
The car handled beautifully in all road conditions, from dry, to wet, to snowy, to ice. Obviously, the traction control is a big contributor to the performance.
In fact, I much prefer this setup to my old car, an Audi A6 Quattro with high-performance all season Michelin PS-2's.
Bart :shades:
