Patience! It's Christmas and many people are on holiday break.
Enjoy the rest of it.
Is this something worth repairing? The car is pretty old so I don't want to put too much more money or time into it. but if it's something simple, i don't mind. thank you!
So, was the fuel pressure ever tested? Often a lean mixture can cause the random misfire at highr rpms. Hope the dealer checked that. When I reread you said after crank sensor bad miss so again was timing checked and did they pull plug wires and reconnect drivers side #1 and #3 wrong cause they go 3-1-5 on that side of cap?? Have to ask and easy to look at. Cap is marked. Then was the dist taken out of engine and possibly reinstalled a tooth off - runs like crap then.
the sandman7
sorry, forgot to mention, i did all the work myself with help from friends. had a dealership mech test the fuel system, on his recommendations, i replaced the fuel system parts. had another mech friend from another gm dealership bring an OBDII system diagnostic tool. after half hour of diganostics and testing, all sensors read within correct tolerances and values. double changed the fuel filter, same thing. cleaned the crank sensor, same thing. the miss is annoying at idle but bad when in drive. when i rev it up to 3000-4000 rpm, it revs fine. no miss or sputter. let the idle settle, it settles fine but after a few seconds, the miss returns like a long lost friend that you never want to see again. i'm now leaning towards the distributor. i see no arch in the dark but that does not preclude the possibility of an electrical leak within. before i tear it down, does this distributor take a pick up coil? i've had experiences with bad pick up coils in HEI systems and these symptoms are similiar. this is not an HEI system but the newer EDI system. its bveen suggested that the timing chain may have jumped a tooth but then the misfire would be constant and it would not clear up at all. i'm still at a loss and running out of money. still open to suggestions.
4.3 vortec,overdrive tranny and 4 x 4, dash light were pretty when workin speedo works mph and kmh swithc works no battery side or oil pressure side lights i am stymied where is fuse is that the problem
this is the first for me posting i am stuck arghhhh the lights have gone out on my pretty dysfunctional dash board except for the speedo it works can u help me with a suggestion
Big Dave (ve3eay)London Ontario Canada :mad:
the plastic hold down 'ear' was broken off leaving no solid thread for the screw to catch. i carefully super glued a flat washer, a star washer and a nut onto the bottom of the distributor making sure they all lined up. then i carefully replaced the distributor in the engine. using a small mirror so i could see what i was doing, i threaded the bolt thru the cap, washers and onto the nut, tightening firmly. been running great ever since (knock on wood)
again, thanks for the help, i am ever so greatful to find a site and people so willing to help. i just hope my suggestions help y'all out.
sandman
While called the ignition switch its actually the wiring and connector in the column and not the key/tumbler. Many GMs have seen a low voltage condition due to this and the PCM senses a low voltage and shuts the vehicle off but then restarts - usually at idle only.
A code P0171 may mean that one or more of the following has happened: The MAF (Mass Air Flow) Sensor is dirty or faulty. The use of "oiled" air filters (K&N, etc.) can cause the MAF to become dirty if the filter is over-oiled
There could be a vacuum leak downstream of the MAF sensor.
Inspect all vacuum and PCV hoses, replace if necessary.
Check for a dirty fuel filter and proper fuel pressure.
I checked out the ebay store you mentioned, and he's in Florida?? Even better! Thanks again for posting that info!
Free read at Advance or AutoZone.
After the fact I have noticed my temperature rise after turning the Air conditioner on, when idle or stuck in traffic.
Hopefully someone may have some idea of what could cause this. I love my Chevy, is been good to me and is still looks new at 118,000 miles!
Any comments will be greatly appreciated.
Rob
SUVs and Smart Shopper
i cant find the dammmmm thermostate
is it possible for someone to find a diagram and show me where it is at exactly is it easy do i have to drain the fluid if so how do i do that ?
i cant figure out how to get to this thermosstate i know its only like 10 or 15 dollar part but i cant figure out how to do it thank you please helpp
ross.g
or mess it up in any other way
also i was told that i have to find out what typ of radiator i have for the difrent kidns of stuff they have do these 97 jimmys have aluminum or copper radiators ?
and i can see it leaking and it looks like more then just walker from the ace
and they ran it and he iddled it on and off for like 20 min uts and the temp didnt rize up highten 210 and now i drive to the store i buy a new rad cap couse there is no presue or low on it they sayd
and when i pull on my street the temp start rissing almost to 220 and then i get out and see it leak wtf is going on with this help please
