Chrysler Pacifica Audio & Entertainment Questions
huh. Ya know, all this time we've had the car, I just ASSUMED the DVD changer would play MP3 discs just like all the DVD players in my house. Man, was I disappointed yesterday when we finally popped one in and it errored out.
I just want to confirm this is true and not just a disc problem. Is this what everyone else here has found? No MP3 capability?
I must say that I am a proud new owner of a 2005 Pacifica Limited AWD, completely loaded with no options missed. So far, 600 trouble-free miles on Goldie (Linen Color).
I do have a serious question for those who have the SIRIUS radio option on the Pacifica. For some reason, the radio equipped with my model does not display the actual NAME of the song playing on the Sirius music channel? I have seen other radios (including my previous XM radio) display the station ID in addition to scrolling the current song being played across the screen?
Thus far the dealer has no clue as to why this model will not display more than the station ID. However, whenever listening to plain ole FM radio, for those stations that broadcast RDS signal, my tuner will display all of the station ID information in addition to the song title being played at that time?
My radio code is: RBP and has the 6 disc cd changer below, in addition to the rear entertainment system.
If anyone could shed some light on this, it would be greatly appreciated!
Ingeniousguy
Wonder if Chrysler will come out with an update to remedy that soon?
IngeniousGuy
I have a Q about the stereo system that I'm hoping somebody here can help with...We selected the Intermezzo stereo upgrade because the standard stereo on the T&C just wasn't up to the task of powering that whole huge cabin. Plus, with the Rear DVD and all, it seemed like it would be fun and, well, that's kind of the purpose of the car ;-)
Here's my question: the face of the stereo system is exactly the same as what we had in the T&C, and that one didn't have the upgraded stereo. How can I tell if this is the 5.1 ch stereo unit, then, from looking at the dash. I see no markings about Dolby (other than the standard NR button), no trademark for infinity intermezzo, nothing about setting the surround sound options (my Volvo gives me the choice of 3 channel and prologic II)...it just looks like the regular stereo... (i know, it lists it on the sticker, but I'd like to learn about whatever different features there might be, if there are any, and I can't find them...)
Now, I can count the speakers easily enough, and they're all there. But, should I be seeing any different functionality with the CD/Tape/AM/FM unit itself? Thanks much for any input. I tried to find photos on the web, but came up with nothing conclusive.
Thanks much!
Scott
so how is it you set yours up? like i said, the one i tried worked fine in my dvd players in the house. The disk has no folders or anything. Its just a whole mess of mp3s in one big list.
so it should work in the single-cd, too? i'll have to try that and see if i get any different results.
I purchased a Visor Screen and it only has 4 wires.
Two for power and a V1 and V2 video input. The video cable are white and yellow, not sure what the deal is on them either. I do not have much experience connecting radios, etc........... What Pins on my 2004 PAC should I connect to? Can I just splice in to the existing wires.
I found this wiring info from other posts.
1 Grey/Tan Fused B(+) (didn't use, used power from 2nd row power outlet instead)
2 Yellow/Grey Igition/ACC signal
3 No connection
4 No connection
5 Grey/Lt Blue Video Control(didn't use)
6 Grey/Orange Video Signal(This is center for RCA connector)
7 Grey/Dark Blue Video Return(didn't use
8 No connection
9 Violet/Orange Video Play Signal (didn't use)
10 No connection
11 No connection
12 Shield (This is outside of RCA connector)
In case anyone is wondering, here are the various pin descriptions from the OEM CD/DVD Changer (p/n: P05094031AA). There are two connectors, a 12 pin and 16 pin. This is the labeling off the unit (I’ll do my best to interpret it).
12 Pin Connector:
1) VSM Batt (Video monitor constant battery lead +12v)
2) VSM Ignition (Video monitor ignition battery source)
3) I/R Transmitter enable (infrared transmitter enable)
4) Audio Lch (Audio left channel)
5) Video Common (Video common source)
6) Video Signal
7) VSM Ground (Video monitor ground)
8 ) N.C. (No connection)
9) DVD Play
10) Audio Rch (Audio right channel)
11) Audio GND (Audio ground source)
12) Video Shield
Based on these labels, one would have to imagine that these wires are run directly to the OEM LCD panel in the headliner and it also supports the audio signal (via infrared) to the OEM wireless headphones.
16 Pin Connector:
1) Batt (Constant battery lead +12v)
2) N.C. (No connection)
3) Ill – PVDM (Illumination source)
4) N.C. (No connection)
5) N.C. (No connection)
6) N.C. (No connection)
7) N.C. (No connection)
8 ) Audio Rch (Audio right channel)
9) GND (Unit common ground source)
10) N.C. (No connection)
11) IGN (Ignition battery source)
12) J1850 (?? Must be some kind of control wire to the head unit)
13) N.C. (No connection)
14) N.C. (No connection)
15) Audio Gnd (Audio ground source)
16) Audio Lch (Audio left channel)
Do I need to get the overhead power from the DVD player in order to send the video signal to the screen when the car is on. Please reply to my email if possible
Reginald
I pulled ACC/Power from the keyed plug-in outlet. I spliced in to the wires and connected the new screen.
I also spliced in to the shield and the grey/orange video wire and connected to an RCA plug for the video signal.
So far so good. The only problem now is that I have no remote control for the 6 Disc CD/DVD changer.
Does anyone have any suggestions?
got a 12 pin connector kt from a dodge dealer and just used the pins since the connector did not fit.
I cannot figure what to do witht he dvd play. without it the dvd sits at the menu waiting for me to press play.
other tha that it works great!
I would like to find a monitor that does not have to be hard wired or hard mounted in the car. just be able to plug it in to the 12v outlet for power , i saw a few like this online but was curious if anyone has done this thanks
Bottom line is dealer system is over 1000$ and you lose it with the van.But it is neater and more finished.
Aftermarket or portable is 3-500$ and it is yours. Granted that the technology changes fast. The portable one has worked well outside teh car for camping, cottages and parties.
To create ours, I simply dump the Mp3 files right on the disc.
Next to that, the FM radio only recognized unequal frequencies like 102.7
So it can not find 96.8 (equal number). This is neccasarry in Europe. Does anybody know how to change this?
Thanks...!
ya know, i'm beginning to think PACs are just inconsistent across the board. I can't play MP3s, yet others say they can. I can't shift my tranny at low rpms, but you say you can. Then there is the guy on the other pac board who says his seat won't go fully upright. Oh, and then there is the memory position on the mirrors. Some say it works well, some don't (mine refuse to go where I set them).
its all very strange.
chris5639 - if you could post the build date of your PAC, I'd greatly appreciate it. Maybe this will help me decipher what unit I have.
Is there any way to tell if a person has IR or RF?
Believe it or not, we've had the PAC for almost a year now and the headphones are still sealed in the box. We have never once turned on the rear video unit. I'm not sure why my wife wanted to get it. I supposed she figures it will be good for our son once he is facing forward and actually cares about watching TV.
http://members.aol.com/mlt113/myhomepage/dvd.html
That's the older unit. The newer unit which I recognize the headphone and remote as the same as mine looks like this,
http://members.aol.com/mlt113/myhomepage/dvd2.html. I'm really hoping I'll get the right dvd player and that it will once again play mp3 files.
I've also used Roxio Easy CD Creator 5 to burn MP3 discs and gotten the same result with those.
You should note that it may take a while for the player in your car to read all the files. A 3-4 minute wait is not unusual at all. Incidentdally, the single disc player does not play MP3s. You have to use one of the 6 slots in the 6 disc CD/DVD changer. My Pacifica has both. Hope this helps.
The dealer sat up and noticed when I put in a regular CD and it showed no tag. But my FM stations show artist and song title. My Sirus won't show them either. I'm going to demand a new player after being nice and giving him another chance to step up and fix it.
Seems really silly that, as you said, I can see all that info on FM stations and not satellite.
They've already replaced our Sirius unit, by the way, for a different issue. It still doesn't show the info. So I don't think getting yours replaced will change anything.
The dealer told me it is a TSB, so yours should be able to look it up, as well.
I'm going to look for a pinout on the Sirius.
Anyone have one?
What about Chilton/Haynes for the 2006 PAC?
I've used various programs. one being Nero (although I don't know the version), another being Musicmatch, and I believe I've also tried just drag and drop.
Thanks in advance.
Also, how did you get the cables under the carpet to the headrest?
How do I know which is compatible with my factory 6 disc DVD.
