Visitor Agreement.
Hope that helps,
Netwon
NAVI Commands
Command Alternate Commands with same function
Current position Current Location
Map
Cancel
Zoom In
Zoom Out
Right Map Zoom In
Right Map Zoom Out
North Up Change to north up
Heading Up Change to heading up
Map direction Change to map direction
Right map north up
Right map heading up
Right map direction
Dual map Change to dual map
Single map Change to single map
Mark this point Mark
Home Go Home
Repeat Guidance Repeat voice, Repeat
Louder
Softer
Arrow guidance Arrow guide, Change to arrow guidance, Change to arrow guide
Turn list guidance Turn list guide, Change to turn list guidance, Change to turn list guide
Entire Route map Entire route, route overview
Delete next destination Cancel next destination
Delete final destination Cancel final destination
Delete all destinations Cancel all destinations
Suspend guidance Stop guidance
Resume guidance Start guidance
Compass mode Change to compass mode
Lane guidance Change to lane guidance, Guidance screen on freeway
AUDIO Commands
Radio
AM AM Radio
FM FM Radio
FM1
FM2
CD
DVD
CD Changer
DVD Changer
Cassette
Tape
Audio Audio on, Audio off
Seek up
Seek down
Type up
Type down
Fast forward
Rewind
Reverse Program
Next track
Previous track
Skip backward
Play
Track up Next track
Track down Previous track
Disc up Next disc
Disc down Previous disc
Climate Commands
Automatic Air Conditioning Automatic Air Conditioning On, Automatic Air Conditioning Off
Raise Temperature Warmer
Lower Temperature Cooler
65 Degrees Temperature 65 Degrees
82 Degrees Temperature 82 Degrees
83 Degrees Temperature 83 Degrees
84 Degrees Temperature 84 Degrees
85 Degrees Temperature 85 Degrees
Help Commands
Help Command help, Command list
Everything but the phone commands, you can also ask it for a "command list" apparently.
Hope that helps,
Netwon
Netwon
I'm wondering if any of you owner's know if a text message will display on the NAV screen.
Will the Bluetooth interface retrieve an instant message and display it on the screen ?? I use a Motorola Pebbl phone.
I'd like to get in my car in the morning and have it tell me important messages that I have received from my job.
(I've been using the bluetooth phone almost daily but I don't routinely use the text message option)
Thanks for the input in advance
Press Menu
Press Volume
Press the Top Left Corner of the Screen
Press the Bottom Left Corner of the Screen
A Menu will come up.
Press and Hold Override for 5 seconds or until you hear a beep
Hit back
I've tried to re-connect the phone with bluetooth sys. but it won't get re-connected until I re-start the engine and it gets reconnected automatically?? Please help if anyone has the same experience or there is any way to get the phone and bluetooth reconnected? Thank you.
You said that you have "tried to re-connect the phone with bluetooth sys, but it fails". Have you tried turning the phone off and back on ?
To re-connect I usually have to physically turn off the phone and turn it back on. This way the phone re-pairs to the Bluetooth system in the car. It always works for me. Your method of re-starting the engine will do the same thing (basically a re-boot). However, if you are driving and don't want to pull over, just try the cell-phone off/on.
I have been bashing my head trying to do this for too long without success !! :confuse:
also, when programming a pause into a number, it does nothing. it just dials the number like usual and doesnt send the digits.
when programming a wait, during the call you have to hit the 0-9 button and then send the tone. seems kind of odd.
I'm a first time Lexus driver and have a question about the navigation system in my 2007 IS250. When I go on the freeway the nav has been telling me to exit off the wrong exit. For example, I was going to 3rd Street Promenade in Santa Monica the other day and it told me to exit off some exit in downtown LA, which is about 15 miles away from Santa Monica. When I don't exit, it would recalculate and tell me to exit off the following exit until I finally exited at the correct exit. Has anyone experienced this problem? Is this a system issue or is it a user error? Please advise. Thanks!!!
When you don't follow the directions, it calculates a new route which may be reverse to the original route or all together new, depending on which it thinks is quicker/shorter, etc.
You may also have input the destination incorrectly as you have to watch which city on places that have the same names, etc. Hope this helps, my NAV system has actually shown me new and better ways to get some places I have been going to for years.
I just keep all options on all the time. The preferences are persistent so you don't have to set these each time.
the directions for setting speedtones were not included with the owners manual. For step by step setup instructions, contact your local dealership's service manager, and ask him/her to get with their shops diag specialist for a copy of the step by step instructions issued to them by the factory.
I have a 2007 IS 250 w/navigation. Playing around with the navigation I accidentally put Chinese restaurant, banks and gas station icons on the screen. All of these icons appear wherever I go now if they are in the area. I was wondering how I will be able to delete these icons without deleting my memory points such as my house and work areas. Please advise! Thanks!
Andy
Net
Thanks in advance
I know on the TL (with Navi), it has voice command to control the navi/audio/temperature.
How about the Lexus? Does it ONLY control the navi? Thanks
on the TL, you can say "Disc 3 Track 4" and it plays that particular song. Or say "60 F" and it turns the A/C to that temperature.
I am confused now.
Is there a setting that returns to the NAV screen and makes the audible prompts while i am on the phone using the bluetooth hands free?
This other salesperson called me and I asked him again, and he said it only controls the NAVI.
So thats why I ask if you have the Mark Levinson
