Buick Le Sabre: Electronic/Battery Issues
in Buick
I love this car. Engineering,ride and drive are superb. I would recommend this car to anyone in the market for a premium sedan. However,there are some annoying glitches which mine has. The worst one is a dead battery which happened twice in three months. the dealer says it was a bad cell. HAS ANYONE HAD THIS EXPERIENCE? It also had the dreaded kazoo windshield noise which was fixed. Now it is also making a popping noise from underneath the car, which I suspect is the exhaust heat shield. The car died and was restarted immediately once on a hot day. The people at my southwest Missouri dealership are first rate and are cooperative. I now carry walking shoes and a cell phone. When the battery goes, so does the standard OnStar. I also fixed a rattle in the dash by installing an old cut up windshield wiper blade between the windshield and the trim covering the A pillar. Thinking about an extended warranty? You bet.
Take tha alternator down to the parts store and have it tested. If bad, get a new one. Have that one tested before you leave. Install in reverse order.
It will take longer to drive back and forth to the parts store than to actually do the work.
You can probably do this for $100US. Ask the counter guy for the best lifetime warrantied alternator and you should be all set.
Again, test the new one before you leave so you don't repeat the R&R.
TB
Beware of the lights left on....
Please post your fix here. I am still a little worried about this. Otherwise I still love this car.
Have you contacted the Buick 800 number????
Your dealer should have kept the car for several days while giving you a loaner to drive. During that time they could have looked for a drain on the battery or alternator problem. You have a dealer problem, not a Buick problem. You could insert any favorite name here, Lexus, Honda, Toyota, Infinity, Volvo, etc., and they could all have the problem with batteries.
Come on here. Let's not be so brutal on the brand, when it could be any car having that kind of trouble.
Good luck. And try another dealer while you're under warranty especially.
But two batteries and lots of jump starts later, another neighbor who's a used car lot type repair what comes in mechnic's knowledge, replaced the starter. Replacement battery from Walmart and no more problem.
Somehow something on the starter was causing a drain that zapped the battery. Relay or ???? caused the drain. But it wasn't always happening.
Buick has so many lights and so much of electronics, something gets left on and it is easy for battery to get drained.
93 LeSabre 70K replaced. Still running at 150K.
98 LeSabre 120K -running fine.
03 LeSabre 20K - running fine.
89Century traded at 120K okay.
87 Century traded at 98K okay.
I thinks there's something wrong with certain Bonnevilles that causes alternator failure. Neighbor had 3800SC Gran Prix that had battery drains for 3 years. It had an alarm that seemed to drain the battery and something had burned up a wiring harness early in the cars life. REplaced under warranty.
But the neighbor, a shadetree mechanic who had worked with used cars all his life, changed the starter and the drain was gone... after 80K.
The neighbor's dad has a used car lot. He says 3800 in large cars is good for 300K. He sells a lot of used ones with high mileage.
It seems to me the battery should have lasted at least 4 or 5 years and is another indication of poor quality of GM parts. Has anyone had similar experience?
Did you check the battery hydrometer indicator every few months to see if it was showing green? That usually will give an early warning of some failures. Otherwise the battery can just simply have a cell short out as a conductive path between anode and cathode is built when the battery is recharging and then you've lost a cell.
I would have replaced with a Walmart Maxx battery with 960 cranking amps and long total replacement free guarantee and a 7 year or 8 year prorated replacement. Interstate seems to have an aura about it from advertising that didn't mean quality in the battery based on some coworkers who bought them in the past.
I think the location under the back seat is great, but I don't want to put the wrong type of battery in it. I was thinking about putting in an Optima battery, storing the one in it now, and switching them at trade in time and using the Optima in another vehicle.
If you come up with a good replacement let me know. I've seen people on other groups mention making the vent tubes fit the vents on batteries so they'd vent the hydrogen under the car.
Since it's on its sixth year, you're wise to start looking. If you don't get any symptoms of weak battery you're probably sitting with some time. Usually batteries fail in the heat and in the cold of winter. We've already had the heat here. The original Delco batteries on GMs are good batteries in my experience. They last long times.
Looks like the host was kind enough to make a separate Lesabre electrical issues topic for us.
The volt light will come on and I have to pull to the side and the car will cut complete off sometimes it will start right back up other times I have to wait maybe 30 minutes before it starts.
Do anybody have an idea to what maybe causing this problem.
When I take it to the dealer it will not do it and they did to duplicate the problem in order to find out what codes may show up.
Check the battery for a broken post inside the battery that makes contact and then doesn't make contact.
So any more suggestions.
highroller, "Got a Quick, Technical Question?" #2854, 13 Sep 2006 12:34 pm
Or check the fuse #19 in the underhood fuse panel--it has the black cover that snaps over it on the passengerside of the underhood--with the large red battery cables going into it on one end.
I picked these up from another discussion where someone had similar problems. One person said they cleaner the crankshaft position sensor with WD40 spray through the access hole without replacing it.
You may email the address in my profile if you need more info to check for yourself. You may be able to email from the MySpace here on Edmunds to my name in MySpace??? I haven't figured out most of that stuff.
My question is do you know where the crankshaft position sensor is locate on at 2001 Lesabre Buick?
Thank you for your help
First question: is this risky? And if not, do I simply loop each wire around the terminal, starting with the negative one? Thanks in advance.
Kevin
Of course, a solar panel is to maintain the charge on a charged battery, not to charge up a dead one. Seems like you know that already.
Kevin
I'M WONDERING IF THE CAR IS KILLING THE BATTERIES AND IF SO WHAT COULD BE CAUSING IT.
