Chrysler 300 Seat Memory
My front seat does not go back when I pull key out, some times the stering wheel does not go up.
The dealer put in a new memory seat chip, but I still have the same problem.Now they say the are working on a flash system. I have be waiting been 4 months.
Is anyone using this feature?
What is working for me is the seat and wheel moving when removing the key, then moving back when the key goes back in. I have also set Memory Position 1 via the door, and have pressed 1 to recall the settings after the dealer changed seat position, etc.
With only one driver, I have not tried to "lock" the fob to setting 1.
I've had this "loss Memory on seat" it seems that the seat has to be set forward more then the 2" stated in the manual to stay set. I'm playing with different setting to see what the tolerances are, keep you posted..
See my car http://photos.yahoo.com/jlsy2001
Put the car in park and take the key out of the ignition. Adjust your seat, steering wheel, mirrors and radio stations to the desired position. Press the set button, press the 1 or 2 button and then press the door lock button on your key fob.
If you do this, it should work correctly. I don't know why you have to use the key fob to get the memory to hold. I have the personal settings for the key fob set to OFF so the seat shouldn't move when I unlock the door. Don't know why but it seems to work this way. Haven't had any issues since I set it with the key fob.
I'll let you know if the dealer comes up with a reason why it has to work this way. Don't hold your breath.
I was trying to get the dealer to install a factory sirius radio for all the the time I spent there with the seat problem,no luck from them. br>
Finally the service manager to talked with his district manager and they installed it at no charge. Try it and see if they will pop for something you want.
Lost it's memory !! Been back to dealer 4-5 times, cannot fix problem. Can anyone please help me ???
Thanks, RJO
Thank you so much, I have been wondering what was going on, and now it is fixed! The seat moves back on exit. :shades:
I have the Navigation System with Sound Group II and I’ve learned to use both with very satisfactory results. If any of you need help on using either one, let me know. Perhaps I can help.
Regards, Gary
Cheers, Gary (GO TU!)
I will come here for more tips when any electronic things go haywire. The moving seat back on exit now works great thanks to Gary!
I don't have a consistent pull to one side or the other in my '05 300C. I do seem to have the "crown sensitivity" that the dealers mention - if I'm in the left lane it pulls slightly left and if I'm in the right lane, it pulls slightly right. In the middle lanes of interstates, it seems to be very true to center. I noticed the sensitivity was lessened after switching from the Continentals to Michelin Energy tires (235 55r18 vs. 225 60R18). Was the pulling issue limited to certain manufacturing months?
thank you.
Worked for me, I've only done it once about 2 years ago, and never had to do it again. :shades:
To fix the 300C seat failure to retract on exit:
"Try this: Move your seat full forward, then full back. Then tilt your seat full forward then full back. After you have completed the above, re-set your adjustment memory to your desired settings and then try the easy exit feature again. Good luck!"
Thank you for Post #12, Gary. Now I can say "Wheeeeee!" when I turn off the key again!
I was skeptical about the below method to fix the issue. I moved the seat forward and then back. The leaned the back of the seat forward and moved the whole seat forward again. Then I leaned the back of the seat all the way back. After that, I turned the car on, and moved the seat where I wanted it. I pressed the set button and memory 1. Took the key out and sure enough the autoglide feature worked again. I tried it multiple times again and it worked each time.
Thank you for the great advice.
