Scion xB Safety & Crash Test Results
                    Sorry if this has already been posted, but here's some crash test scores from Japan.
http://www.osa.go.jp/anzen/html2002e/as115.html
Also I posted the crash test scores for the xA in the other topic, but I'll post them here too for anybody who's interested.
http://www.osa.go.jp/anzen/html2003e/09.html
It is quite small and light and looks like it is an old design. The crash tests could be really bad and there are no side curtain airbags.
Side-curtain air bags are available as an option on the xA and are not offered at all on the box.
The design is about four-years-old, using the same "platform" as the Toyota Echo, whatever platform means. I imagine the engineering on the body is quite a lot different.
http://www.nasva.go.jp/assess/html2002e/as115.html
Maybe 2005 or 2006.
I wonder when the xB redesign is going to be.
In message #880 you said that the 2006 xb probably would have side and curtain airbags.
We would like to buy one, and were wondering when you think we can expect the 2006 to arrive.
Thanks, Niels
IIHS also just started running side impact tests, but they went one further than the NHTSA - a heavier impact vehicle, at truck/suv height, with a contoured (for greater penetration) front end.
While the xB and xA were not tested (and have done well in the milder NHTSA tests), 14 out of 16 other small cars failed the IIHS test miserably. It is worth Googling and reading the press release. The main thing that comes out of reading the lenghty news release is that side curtain air bags are a must have for anyone willing to plunk down the dough on a new car, regardless of the size of the car; and "size matters," small cars are going to have to be redesigned to pass the new test.
In fact, the Honda Civic is currently being redesigned and given Honda's extensive safety testing facilities, should pass by the time it is released (Honda made running changes to the CR-V when it failed its initial side impact test). The Accord with side curtain air bags passes. It would be a shame for Honda to release a new generation Civic that promptly failed this new, well publicized test.
Anyway, I love the xA and xB but the IIHS test is a real wake up call. Even the New Beetle with side curtain airbags got a Poor.
There are two existing (dull) vehicles which pass (barely). The current Corolla, and the new Chevy Cobalt. We can only hope body structures and air bags will be upgraded on the upcoming xA to also pass the new test, and that, as recent posters have noted, that a new side curtain airbag friendly xB will be released....
I'm trying to decide between the Scion Xb and the Honda Element for a car that will be used 90% of the time in city driving. The Xb's mpg and space is very appealing, but the AWD and added safety features of the Element appeal to the parent in me (I have 2 small kids that I'll be toting around).
Anyway, the Element's crash test ratings were so-so (better with side impact bags), but I can't find anything on the Xb's crash ratings. I live in CT, so I'm wondering, from a safety perspective if anyone has experience with an Xb in snowy and wet weather and how it handles. If anyone knows when/if it will be crash-tested that would also be helpful. Any thoughts would be welcome.
I can't find any crash test data on the Scion Xb, does anyone know if/when it is scheduled to be tested. I'm reluctant to consider buying it without this information.
To put it into a different perspective, the car is much better than most cars sold five years or more ago, due to ongoing advances in engineering. Still, it is a small car; assuming you have gotten past that hurdle it is probably as safe as a Civic or Corolla or Matrix unless they have side curtain airbags, in which case they are safer (side curtain airbags are not an option in the xB).
On the other hand, the xB has stability control and ABS, which improve the safety factor.
It costs a little more and fuel efficiency is slightly under xB, but I think I'd rather buy a Matrix. Not to mention it's faster and bigger.
Then again with options added to Matrix, I could buy a 4 cyl Sonata which has 162 Horsepower and a much larger interior. All safety features are standard and high crash test ratings (including airbags)! :P :P :P
Would consider xB as an less expensive alternative to a Sonata if it had airbags. I love how all these entry level cars have low MSRPs but once you add all the popular options your paying the same as next tier prices or very close!
http://carsguide.news.com.au/story/0,20384,20148974-21822,00.html
Now that does not inspire much confidence!
I stuck a silver Dot-It over the mirror, and black Dot-Its on each side of the trunk area. I got mine from Amazon but saw them later in a checkout aisle at Meijers superstore. Here's a 3-pack for $20 from Amazon:
http://www.amazon.com/Sylvania-Self-Adhesive-Bright-Silver-3-PACK/dp/B000ES41HQ/- - sr=8-2/qid=1161359534/ref=pd_bbs_sr_2/102-0625716-2908137?ie=UTF8
http://www.iihs.org/news/2006/iihs_news_121906.pdf
Car model Front Crash Side Crash Rear Crash
Nissan Versa Good Good Good
Toyata Yaris Good Good Marginal
Honda Fit Good Good Poor
Mini Cooper Good Acceptable Marginal Chevolet Aveo Acceptable Marginal Poor
SCION XB Good Poor Marginal
TOYOTA Yaris Good Poor Marginal
HYUNDAI ACCENT Acceptable Poor Poor
/ KIA RIO
I typed them all out for you. Hope that it is useful.
Dan
