Visitor Agreement.
TIA
Ray
Great, free fix! Thanks a million!
On my 2003 Windstar SEL while using the A/C MAX or VENT setting to blow out the front vents in the dash, it stops as soon as I start to go up hill.
It will begin to blowing out the windshield defroster vent, or the floor vent (stays the temp I set it to, I fixed that problem already in December) until I tap on the brakes while doing 75 MPH, or start going down hill, is when it will only begin to blow out the proper front dash vent (what I have it set to).
What, Where, and How do I fix yet another problem with this van. "89000 miles and 3 warranty transmissions later" CAN YOU HELP? :confuse:
It's the Blend Door Actuator. There are also youtube videos that help with replacing it, very helpful.
oops here's the link
im new to this site and im writing from sweden.
I own a 2000 ford windstar 3.0 . Having problems with the heat too.
But im not sure what may be the problem, I cant get no heat. or I can get a litle heat, first i thought that i had air in the system after i replaced the thermostat.
But now im not sure anymore. I have bleeded the system and I now cant see any sign of air in the system.
so now im thinking of the thing you guys talking about... blend door actuator.. ?
but how can I know if that is broken? what are the symtoms of a broken blend door actuator?
sometimes I have a little more heat but not enough. but most of the time no heat...
any suggestions?
