Pontiac Sunfire Starting and Stalling Problems
I have a 1998 Pontiac Sunfire with a rough idle. I have replaced the spark plugs, the plug wires and the coil are good. There are no fault codes and I still have a rough idle. If you may have any idea to what the problem may be please email me.
Euphorbia
You might also want to post your question in the Idle or Stalling Problems: All Vehicles to see if the folks there have any input.
Euphorbia
You might also want to ask your question in the Idle or Stalling Problems: All Vehicles discussion.
I've recently bought a 1998 Sunfire SE with 95k on the clock. She was fine until about a week ago, now whenever I start the engine it fails to start sometimes, it fires but almost seems like it's stalling straight away. There's also a very odd niuse coming from the steering column area, almost like a kind of buzzing but not quite. After one, two or maybe three tries is fires up and if I apply gas starught away she fires up and should be fine. This happens 9/10 times I start her up!
Also the horn doesn't work :sick:
Any advice would be greatly appreciated!
S x
If you don't get an answer here, you might try asking the folks in the "No Start" Problems discussion. Even though your car starts, it doesn't seem to want to "stay started", and the people there may have some insight for you.
I have a 2002 2.2L Sunfire with 85km on it. Recently [as recent as today] the car has not been starting. This has only happened twice in the last month or so. I took it to the dealership and they say they can't find anything wrong with it??? It started right away when they got their hands on it. Today the cars starts an stays on for about 1 second then dies..? Anyone with any ideas? 2 Months ago I had the fuel pump replaced and the dealership said, nothing wrong with it.
Thx.
Does anyone out there know what the problem is? Any suggestions? I was thinking the fuel injection? When I try to not let it stall and I give it gas, it doesn't want to go.
I love my car so much, and have only owned it for a yr. I really want this car to be good for another few yrs...what can I do?
Confused in Ontario Canada
Another place that you might want to post about your problem is the Idle or Stalling Problems: All Vehicles discussion. The folks there are likely to have an answer for you if you don't find one here. Hope you get this solved quickly :-)
Sometimes when the key is turned there is no fuel pump pressurization noise and the car will crank but stalls almost immediately or just won't even turn over. You can sit in it for 5 minutes, crank it and it starts right up or sometimes it won't crank for a day!
Or, you can hold the ignition in the 'start' position for a few seconds and then it'll crank up...? Any suggestions? :confuse:
1. Blowing thick black smoke
2. Stalls intermittently at traffic lights
3. Misfires
I had it checked completely and the mechanic suggested an engine replacement! He gave me a printout of results and said there are two cylinders misfiring and there is a little crack in head gasket. Now I can't even drive the car as the pickup is terrible. Should I get the engine replaced? I can't even sell it in this condition (it won't even pass the emission test). Mechanic said, he would find me an engine with around 77000 clicks for $1100 - $1300. Is it worth? This is my first post, I would really appreciate any inputs.
Thanks :confuse:
If not, what is this garage talking about when they say they have to replace the sensor and everything else. All I want is a new switch, that should be cheap enough. They want $650!
The car never actually stalls, it runs rough while driving and while idling. And this starts happening right away, the engine isn't even warmed up yet. It only gets better when in neutral.
On top of all of this my car shifts really hard (auto.) and I've had my car up on the hoist and the fluid is fine.
Please help and give me some suggestions as I am really fed up with my car. I've only owned it a year and have sunk too much into it.
Thanks so much :lemon:
issue. My 96 died again and i took the dash apart and
played with the wires and once a I got the dash board
lights back on it started. You can email me at
jfass_17@yahoo.com
:sick:
Please let me know what you did to fix
Jeannie
It did the trick for my daughter's Sunfire.
