I've got a '99 Windstar LX that suddenly stopped blowing hot air from the front and rear heaters. I checked with the dealer and discovered that these have independent heater cores that are not controlled by a single valve switch. Can anyone shed light on this issue. They want $500.00 to pull the dash just to investigate. Thanks
Does anyone know of a recall that includes 95 windstar brake lines that have rusted out. The one that is leaking is the line between the front brakes. The leak occurred right above the wiring harness for the oxygen sensor,this caused the plastic retainer to break down and let the connector for the o2 sensor rest on the catalytic converter. Anyway, this is a friends car. She asked me to take a look at it be cause she almost rear ended someone and that she smelled something burning. The other things I noticed was that all the brake lines are rusted and the exhaust system was also in the same condition, with the rubber hanger snapped in half. If anyone has had a similar experience please let me know.
See, the dealer meant it would be the worst thing for HIM if you didn't immediately pay the $3,000 for the transmission rebuild. If you need to replace it, obviously it can't hurt to try the flush. You may get lucky and squeeze another year or two out of it.
This also goes for #1611: Blend door failures are pretty common on Windstar/Taurus models of that era. The assembly is pretty flimsy and tends to break in a number of places. Unfortunately it requires close to ten hours of labor to replace. Sorry.
My 2000 Windstar has been blowing the fuse that runs the module that controls the odometer, speedometer, hot/cold air, ABS light and cruise ctrl. It is random as to when it blows, sometimes when I start it, other times when I'm driving. Any ideas?
1995 Windstar......just returned from a 600 mile out of town trip with no problems. Got in van next morning and started van with a terrible miss. Just pulled all the spark plugs to look for firing of cylinders and cylinder numbers 1, 2 and 3 were competely black and wet and cylinder numbers 4, 5 and 6 looked to be burning fine. Also looks and smells like raw fuel is being thrown out the exhaust pipe. Can an entire bank of injectors go out all at once or does a sensor controll an entire bank of injectors that might cause this? Any suggestions where to go from here would be appreciated.
If your Windstar is so equipped, I would first look at the Intake Manifold Runner Control (IMRC) for that bank. Check the control rod to see if it's bound or jammed shut. Sometimes the IMRC butterfly valve sticks shut with carbon buildup in the intake. Do you have spark on the bad bank? Buy a $5 spark tester and check 1,2,and 3. Could have a failed coil pack. Could be injector drivers stuck open in the PCM, but it's unlikely all 3 switches would fail closed.
we bought a used van 3 days ago and it is now overheating when we (try) to drive it. When in Idle it is fine. NEw radiator, thermostat, flush, almost everything has beeen replaced at some point. HAve reciepts.I have 95 ford windstar 130,000 miles
I just bought a 99 Windstar SE, the transmission kind of fluttered from first to second for about 2 weeks and then went completlt out. We put in a rebuilt transmission and now the battery light comes on and off at times. We have had the battery checked and the alternator. They keep telling us that they are okay. Does anyone know if Windstars have a history problem with this?
Has the charge voltage been tested while the light is on? It's possible there is a loose connection somewhere in a wiring harness near the transmission.
Hi. I'm new to forum. Hope this is the right place. I want to replace spark plugs and wires on my 98 Windstar 3.8L. Any suggestions/hints/ideas for the rear bank? Come in from underneath? Remove cowl? Forget about it and leave it to the "pros"? Thanks I've done em on a 97 Town & Country from up - top. First time was about 7 hours. Rgds/LA
Yes, those are the electric fans. If they're both turning on when it overheats, then they're working. If you have a new radiator and thermostat (assuming the thermostat was installed correctly), next you have to see if the water pump is actually circulating. It's possible air is trapped in the system on you need to open a bleed valve to blee the air or have a mechanic vaccum the air out. If that fails, then start looking for combustion gases going into the coolant from a blown head gasket.
Before I do any of that, I would get back to the person who sold it to you and pick his brain. Sounds like you bought his problems.
i've had that problem too!!!! it just started recently with my 98 windstar. the problems started over a year ago when my mom owned the van. it was with the back door so my mom's ex-boyfriend took all the lights out. so if i use the wd40 i can get all my lights working again. i can't wait to try it!!
what can i do to get the door light off for my backdoor? i sprayed the wd40 on the other doors and they are fine, it's just that my back door light is on. i sprayed them down but what else can i do?
hello all, i own a 2002 windstar se recently, seems like in colder weather, my brake lites stay on even after shutting down vehicle. i tap on the brake pedal and this rectifies the problem until the next time. is this the switch on the pedal? anyone else with this problem? any help is appreciated. thanx
I have a 2002 as well with the exact same problem, but I was fortunate enough to find out that it required a flush and refill of my power steering pump and lines. The whining was gone after that.
I have a 2002 that has been in the shop multiple time for the same reason and I throw my hands up in the air not knowing what this is. I get a rather intense vibration/shaking in my front end intermittently. There is no repeatability in this. It can happen at 30, 50, 65, 80 mph, in any gear with over drive on or off. It only lasts a second or two, but it's quite intense. My van has 104,000+ miles on it so it is out of warranty. The dealer ship wants it for a whole week with an approval of $1000 and there is no way I'm agreeing to those terms.
Approval of $1000 to do what? I don't understand. That's what they want for diagnosis? It shouldn't take more than a half day to find the problem, assumig they can duplicate it. I'm guessing there was miscommunication and what they meant was they assume it is a torque converter failing (based on your description), and if they are right diagnostics+ converter replacement would be around $1000. It's not an uncommon failure in Windstar transmissions.
My 98 windstars inside lights stay on for a long time. I've cleaned the contacts on the sliding door a few times...it works sometimes for a while...any ideas?
I am having the same issue with my 2002 xl, please let me know what you got back on this.. Mine just started yesterday...it happens as soon as the key is turned to the on position, before the engine is started,,,then it continues intermittently. thanks...dan
How did you steering problem come out? I have a 98 windstar and have replaced the pumps three times and the rack once. I suspected a line obstruction but this is hard to verify. I have been using rebuilt pumps and rack but was considering buying a new one from Ford ($$). It moans and power steering is weak. I had used synthetic ATF fluid based on a forum a while back. The fluid stays red (unlike regular fluid) but steering performance is poor and it is noisy. Would think Ford would know how to install an acceptable power system in a van.
We are 500 miles into pump #8, and it is working. We did not replace hoses. The racks came from Delco. I was told that they used OEM pumps after the first failures. A different tech worked on it this time, and they claimed to have flushed >4 gallons through the system. Fingers crossed!
I replaced my plugs about six months ago (not wires). It turned out to be not too bad; I think it took about 2-3 hours. I replaced the rear plugs by raising the front wheels about a foot off the ground and accessing them from underneath from the rear side. Access wasn't too bad. One of the few tasks that turned out to be easier than expected.
Hi Wink 1. Thanks for the reply!! I am reading this after just finishing. I went from underneath from the rear bank. Not that bad with 3/8" ratchet and extension. About 2.5 hours. I have another question for you and/or the forum. I got Motorcraft "direct replacement" from Autozone. They said nomenclature had changed slightly. "Pure platinum, yadda yadda......" Only concern is owners manual says you must use different plugs for front bank of cylinders vs rear bank. Referenced underhood sticker - I've got underhood stickers; none of em reference spark plugs. Autozone knew nothing about; had nothing in their computer. Are you (or anyone else on the forum) aware of this. Maybe it's been changed since manual was written to identical plugs? BTW, I agree. Access to rear bank of plugs on the Windstar wasn't that bad. My 97 Town and Country took me about 7.5 hours going by the OEM manual over the top; no access at all from bottom. Tx again. Rgds/LA
Not to worry, Ford changes spark plug specs and part #'s as often as I change socks. LOL The original thinking was that with coil packs firing 2 plugs at a time, one with the current flowing from the centre to ground electrode and vice versa on the mating plug, different spec plugs were required. To consolidate part #'s, the same plugs are used front and rear for service replacement.
P.S. 10-4 on the Chrysler mini-vans. Even with the wiper module removed they're a bear to do. Easier with the alternator removed, but not much.
My 99 windtar LX had similar problems. The interior lights would flash on/off sometimes in the middle of the night (ghost car) and the chime would come on when the driver door was open even with the key out. It turned out there is a switch on the ignition that detects the key being inserted. This switch had broken off. You can check by removing the cover under the steering column so you can see the ignition switch. Look for a small black piece of plastic with a single wire going to it. I used JB Weld epoxy to glue it back in place. Problem fixed.
hi maybe i can help take the wd40 and spray inside of the door where your door lock spray inside in the jam repeat couple times on each door and light is gona go off most of the cases the driver door's are problem
you have to spray wd40 into pasanger drivers door's locks use the whole can and it will go away that problem it's coused by rust and other problems dust and weather conditions i had same problem and i fixed it
Re: 95 Windstar with 200,000 Km. We recently had the Engine trouble light come on, for no apparent reason. The van seemed to be running fine. Then a few days later it started to run a bit rough. I took it in to a mechanic (not dealer this time) who checked the code and said it was showing #6 injector problems. the #6 plug was "completely dry" the plug wires were "showing a high resistance" but still within acceptable range. The mechanic said this meant it was a injector problem and that it needed to be replaced. My spidey senses are tingling and I am wondering now, in hindsight, if I got ripped off for the $500 to have the injector replaced. The reason is that when I gave the ok to do the work I questioned if the plug wires needed replacing (they were original), he said they still seemed fine but would let me know how much to replace them if they needed doing. When the work was done he had gone ahead and replaced the wires anyways (cause it was all apart and easier and quicker to do it now) so now I dont know if it was just the wires or if the injector actually needed replacing. I'm wondering also, in hindsight, if maybe the injector just needed cleaning. I phoned the Ford dealership and they say it is uncommon for an injector to need replacing on a Windstar. I guess that's probably because everything else needs replacing ie: two trannies, one headgasket of course, numerous sensors at &350 each time. So what of this fuel injector, did I get ripped off on the repairs, what do ya think???
The transmission was clunking when shifiting sometimes and then the service engine light came on and off intermittently. We lost some of the transmission fluid by blowing it out of the air breather and transmission was hot. When it was checked at a Ford dealer while we were traveling out of state and they found nothing wrong other than low on fluid and the computer showed a torque converter problem. They replaced the screen assembly and flushed and filled with fluid. We didn't have any further problems on the remainder of our trip (1500 miles)and appears to drive fine but is it necessary to have the transmission rebuilt or can it be determined if there is damage before it is torn down? What should the cost be of rebuilding a transmission?
Whenever I turn right or left I hear a popping type of sound. It seems to be worse when I am backing up. This only occurs at slow speeds like backing out of a driveway or turning from a stop sign. Any ideas on what this could be?
I have a 2003 Windstar and a question for you experts out there. For some odd reason, my lift supports for the liftgate are now shot. I have to hold the liftgate open. I'd like to have these 2 lift supports replaced. Called several Ford dealers - they all want 48 bucks apiece. I cannot find any lift supports online for less than that price for the year 2003. Although, plenty of online retailers such as JCWhitney and CarParts.com do carry lift supports for 98 through 2002 Windstars. My question is this: can I purchase lift supports for a 2002 and will it fit on my 2003 windstar? They cost only 32.99 and I figure I'm saving at least 30 bucks. If they will fit with no problem, then I'll just order the ones for 2002 windstars and install them on my van.
Thanks much Alcan! So far van runs great, but I would rather know now than later, that I'm burning up plugs and have to go through same drill at 5,000 miles. On the Chrysler, I didn't remove cowl or wiper module but followed the OEM manual exactly. Still........what a pain!! I'm ready for direct fuel injection; let's get rid of weight and complexity of these big cast AL manifolds!
With my chrysler, I was able to turn the key in a certain sequence and the the dash lights would flash a number of times. By counting the flashes, I was able to cross reference that to a diagnosos chart to find out what the problem was that was making the check engine light come on. Is there a way to do that with a 2001 Windstar? Any help would be greatly appreciated!
I've had my 95 windstar (the lemon from hell) for about 5 years now. I bought it for the roomieness and found it very comfortable, but what nightmares. So far we've been through 2 trannies, both before 110,000 miles. Just replaced the head gasket last week at 126,000. Had I think they were the intake valves replaced at 67000 miles. Now we've found there was damage done to the sensors because of the head gasket, but mechanic said it may work itself out after driving it around. Have the same problems with the door buzzer. Have WD-40'd them numerous times, lasts about 2 weeks and then starts up again. Every time it rains we have to replace all the main fuses (door, horn, etc) and at 12 bucks a pop, it gets costly. Switch for back windows doesn't work and of course it stopped working with the window open, so now we can't shut the window. Airbag light stays on, and we've had it checked and both airbags are there. Now, there is a light, last one on the left, looks like an oil can with a drop, but I know that's not the oil since the dipstick is for the oil, well that light keeps coming on now. Ask me why I still have this car, can't afford another one. Figured eventually at the rate I'm going with this it should be like brand new in another year or so. LOL Believe me, there was a lot more work done to this car that I've forgotten, have been at war with Ford ever since the tranny problem, but to no avail, just tons of paperwork. Thanks for listening and if anyone knows what that light is on the left side of the dash please let me know.
I'm new to this forum but not new to Windstar problems! My wife has had a '98 and now has a 2003 w/50,528 miles on it. I drive it infrequently and usually to diagnose some potential problem that she complains about. The latest one is what she referred to as the tires bouncing a bit. Cut to the chase. OK between speed of 55-60 when the converter locks up there is a noticeable shudder. Especially so under a load. No load or downhill, no shudder. Also, with the selector turned to "OD Off" there is no shudder. Is there any adjustment to the converter? After reading many of the posts here, I'm getting a little gunshy to the Windstar world. "> Thanks, TL
I have a 2001 Windstar SEL with a problem. On cold mornings, when making a left turn and accelerating, I hear a grinding or shaving noise coming from the left wheel area. It sounds like the tire may be touching something, but I checked and found nothing loose or out of place. Also, it happens even with just a slight left turn, so the wheel does not have to be turned all the way left to hear the problem. Also seems to only happen under power.
I’ve had CV-joints go on some other cars in the past, and this is not the same noise (cluck-cluck). I also searched this forum and could not find any problem that resembles this exactly. My Ford dealer is one of those where you have to do the troubleshooting yourself. They could not find anything wrong when I had the car with them the last time. Also took it to some trustworthy transmission guys for a service. They found the transmission to be in good order with little wear.
We had a similar problem with our 2001 that ended up being caused by low power steering fluid levels. When we would turn left, the fluid in the system would slosh to the right and apparently cause the steering system to be "unlubricated" briefly. The way it is designed, it wouldn't happen if we turned right. We topped off (dealer actually) the fluid level and it hasn't happend since. They could not find out, nor explain, why the fluid level was low.
Sounds like the first signs of CV joints going out. They usually make this kind of noise when the wheels are turned full right or full left and rolling at slow speeds. If that's it the problem will only get worse. Usually you can check the rubber boots on the ends of the drive shafts and if they're showing signs of cracking, more than likely that's the problem.
I've got a '00 Windstar SEL and the driver's side door lock actuator seems to be on the fritz. It's getting to the point where it won't go up or down completely. Has anyone replaced them theirselves that can provide me with some advise. I'm in search of actuator part numbers, and possible suggestions of where to buy them (other than the "stealers"). And any advise or lessons learn on removing the door panel.
Rgds/LA
Any one else have this problem?
Any help would be appreciated
Tx again. Rgds/LA
Jason
Thank you in advance!
Kurt
Thank you very much for your reply and I guess I will just have to take it in to the shop and pay the diagnosis fee.
Kurt
TL
Any advice on where to start looking?
Thanks you
Christian
Have Tie-rod checked and link kit .
Autozone will scan and read the codes for free and can reset (turn off) the light.
If no Autozone, perhaps another parts store would.
Rgds/LA
Please advise... Thanks
DB
Here is the information off of the work ticket:
Dealer:
'Found that the door lock actuator is very weak in it's operation, door latch/lock cot sticking at this time. Replaced door lock actuator.
1 3L3Z-25218A43-AA Actu Frt Dr
2 94978 Lever Clip
1 94566
I hope this helps.
