Visitor Agreement.
(Just for the record over the past couple of years we've redone the power steering, front rack, transmission, new engine, serpentine belts and alternator....)
Thanks for information.
They found a bad fuel injector. Replaced it and now all is well.
Just replaced my tranny at 112K. Acutally rebuilt with 2 yr warranty via local shop for $2800 so $4200 seems like too much.
Word to the wise though: Don't buy a Chrysler minivan!!! All their other cars are fine, but NOT THE TOWN AND COUNTRY OR VOYAGER. They're crap.
I didn't know Ford Winstars have all those problems.... maybe looks are deceiving! We loved the one we test-drove, but maybe there were some underlying problems. Thanks for letting me know! I know now to look for the Hondas and Toyotas! :shades:
Thanks Mark
A 2001 Windstar SE with 87,000 miles has average retail value of $6287, according to edmunds. A 2201 Odyssey LX has average retail value of $8698. So the extra reliability costs $2400 in this case.
Meanwhile in the TCO area of edmunds the 5 year cost of maintenace and repair is $6987 for the Ford and $6640 for the Honda. So the savings is only about $350, due to the greater reliability. Note that the M&R costs are based on 2002 models, as that is as far back as edmunds goes.
Overall the average Windstar saves a net of about $2000, if edmunds data is accurate.
Suppose one ford vehicle in 10 has a $5000 repair while for Honota it is 1 in 50 that has that $5000 repair bill, that translates to an average extra repair cost difference of $400 per vehicle. I think it is probably something along those lines is the basis for the difference in average repair costs.
If so, then you have to ask is it worth spending $2400 now to reduce my chances of possibly paying that $5000 later. It could be put this way...would you rather pay a sure $2400 now and have a 2% chance that you will have to pay an additional $5000 later or would you rather just have a 10% chance of having to pay the $5000 later.
There is an assumption that all Fords are crap and all Honotas are bulletproof. I have found very interesting reading on the Accord problem board here. There are people posting there about huge repair bills on relatively new cars, too.
The edmunds figures for repairs are averages and are supposed to based on cost of extended warranty for the vehicle in question. I'm not a fan of extended warranties but I wonder...what kind extended warranty could one buy with the $2400 savings from buying the Ford?
Later checked transmission fluid and added some Mercon V. Runs a little faster in Drive, but soon started flashing O/D light.
After about 2hrs of resting the van, started the van, the O/D light did not come on again even when driving but the speed issue returned - runs in Drive, but would not auto shift gearup to higher speeds, runs as fast as 40 in gear 2. Check engine light still on.
Please advice.
The air has been replace, the original rack and pinion has been replaced twice, the rear wiper motor has been replace and is down again. The paint is chipping away.
If you can offer any advice that assisted you, we would trulyl appreciate hearing from you. Thanks. Helen McLaughlin
The lights and chimes can be a little slow to stop, but not like before. I plan to use it often and hope the problems don't reappear.
Thanks,Doug
It's your lucky day since I was researching a problem on my Windstar when I came across yours. I bought a 2000 Windstar a couple of years ago that had a similar problem. When I went to change the air filter I noticed motor oil in the intake plenum. I panicked at first thinking the thing was burping up motor oil! After a closer examining I found the problem was a bad PCV valve. Now PCV valves usually don't go bad at 27K but I figured all was okay after I replaced it. Well the thing was still sucking up some motor oil but not nearly as much as it did before.
I figured everything was okay until one day my wife comes home and says the check engine light is one. Since the vehicle was still under warranty I had her take it to the Ford dealer. To make a long story short the OBDII code was PO171/PO174 or 'lean burn bank 1 & 2'. By the time we got our van back the dealer had replaced the front valve cover, intake gasket, egr valve, and pvc valve. The dealer then told us our cost would be $10 since the PCV valve wasn't an original part!
Being I never heard of a valve cover causing a 'lean burn' condition I did some research in forums like this. As it turns out there is TSB 03-16-01 that details this exact problem and how to correct it. What it boils down to is there is so much intake vacumn at the PCV valve it litterally sucks the motor oil out of the engine! Once it has hosed up the PCV valve the oil will be drawn into the intake plenum where it will clog up the emissions garbage. Over a period of time it will build up carbon deposits on the heads until the engine literraly self destructs!
My recomendation would be to pull the air cleaner apart and look down the intake plenum. If there is a lot of motor oil in it then I would take it to an honest machanic and get his opion before you purchase the vehicle. If the front valve cover is tin instead of aluminum then the vehicle is still sucking up oil. If the motor pings or knocks real bad under load then the cylinder heads are crudded up so I would say it's too far gone.
To have the modifications done according to TSB 03-16-01 will cost several hundered. Luckily mine was still under warranty repair and the engine had under 36K on it. Besides this problem our Windstar hasn't had any other magor problems. We really like the vehicle and it has served my familly well without taking us broke. Good luck.
Erik
Doug
Contact cleaner should be sold at most hardware stores. It's alcohol based and will evaporate.
It worked wonders with my 96. I had to take the door apart to spray the conntections.
Any help is greatly appreciated?
Two days ago I drove my 1996 windstar out of the driveway and around the streets for a few minutes. I noticed white smoke coming out of the engine and pulled the van into the driveway to check it out. When I opened the hood I couldnt believe what I was seeing but there was an isolated fire in the engine compartment. I scurried around got hold of a water hose and just let it rain inside the hood to put the fire out!
After I managed to stop shivering down to my bones and got my senses back in order I started pondering how and where this fire was from. I kept looking, smelling, and touching for burnt parts until I came upon the speed control pressure switch under the master cylinder. It was partially melted and smelled of smoke. At this point I had no clue that Ford engine fires was a not so uncommon occurrence. As I read more on the internet I realized that the Ford recall (2005) for this problem didnt even include the '96 Windstar even though the same switch and design methodology is being used on it as it is for the recalls. My call to the local dealer yielded the same reaction - "96 Windstar is not part of the recall".
All I can say is that if you've got a 96 Windstar you MUST disable this speed control pressure switch (or atleast find some other creative means to keep it from catching fire!). Loss of cruise control ability is a minor issue compared to losing your life or that of people you love.
Furthermore - I was feeling sorry for myself that my garage was so stuffed with junk that I didnt have space to park my van inside. Well I've managed to do my spring cleaning and clear out the garage but after this experience I will never park a car in my garage!
I have not tried it, but they say that AutoZone will read the codes from the engine lights. They might be able to tell you what the van thinks is going on.
I spent many trips with interior lights on because my van was convinced the doors weren't closed properly. It might take a couple applications of WD-40 to get it done.
Good Luck!
