Visitor Agreement.
First, check to see that your emergency brake is released. Next check the brake fluid level. If everything there is fine then change the brake pads (if needed). Next to check would be the brake lines and master cylinder. You maywant to have a technician check the brakes, brake lines, and master cylinder unless you have done it before.
Thanks for the help
Thanks in adv
TIA Bill
When you first start the van it will run rough for 30 seconds and runs fine and idles fine then and i do not get a check engine light. The van has 114,000 miles on it.
pepper4
The code says there is a misfire on one of the injectors, the injectors have all been replaced within the last two months, as has the alternator. I've also replaced the spark plugs and the wires.
Any ideas? My van is a '96 GL and I really do like the ride, am not crazy about the gas mileage, but it serves me fine
I recently had a similar problem with the kids 2003 van, Check engine light was flashing, took it to Auto Zone and they checked it on there hand held computer. It said check wires, plugs, coil, injectors.I replaced wires, plugs and coil and had same code show up. Finally took it to dealer who checked the injector, which were ok. They did a compression test and found a broken exhaust valve spring on #3 cylinder. This caused the engine to run rough. Replaced the spring now everything is all right.
It's safe to drive with the ABS not working as long as you remember how to brake a car before ABS was a feature.
Chances are you blew the engine.
code : B2499 (COURTESY LAMP OUTPUT Failure)
I will never change another injector in this stupid van. I will pay someone $500 to do it for me just to save myself the blood(and lots of it), sweat, and tears. I even had the man helping but his arms were too big to reach some of the bolts. He's 250lbs. Even my arms (and I'm 5'4" and 120 lbs) were slightly too big (that's where the blood came from). So unless you are a very small 5 year old with an genius knowledge of cars I would suggest paying the shop.
12 hours for ONE lowsy fuel injector.
Anybody know what could be going wrong??
Sounds like a blown head gasket. Don't drive it or you'll blow the engine. Take it to Ford and tell them to fix it under the recall.
My van sucks the coolant, but as long as I keep the overflow tank filled we are fine. It seems like it sucks more down running the heat than the air.
There are no noticable leaks and I have checked.
Thanks again for the info.
Pete
Why are you trying to red line it anyway?
When I approach 60km/h the vibration starts and at 70km/h the vibration gets worse but if I go faster to 80km/h or above the vibration goes away. Also, when I get to 70km/h with the vibration happening I hit OD OFF, the transmission shifts and the vibration goes away. If I drive around for a while the vibration will come back at about 70km/h with OD OFF. Also when I am driving with the OD ON and the vibration starts I hit OD OFF and nothing happens but most of the time when I do hit OD OFF the problem goes away. What am I looking at here, the torque convertor? or is the 4th gear the problem?
The transmission fluid is fine, changed 5000km ago
Thank you, DTF
