Have you shopped for a car recently but decided to hold off on your purchase because prices were too high? A reporter would like to speak with you; please reach out to [email protected] by 9/30 for more details.
Ford Windstar Problems
13468950
  • svofan1svofan1 Member Posts: 1
    Bought a Windstar 2001 SEL...fully loaded ..leather seats do not have seat warmer..anyone knows if it is possible to add a seat warmer for the driver seat?. Thank you
  • abeauchabeauch Member Posts: 2
    I have been going through the same pinging problems mentioned in earlier post. The dealer finally agreed to replace the intake manifold after I showed them the responses I had found here. At first they told me they were replacing the intake at their own expense but magically they found TSB's that reported the intake manifold and valve covers were redesigned and were a valid recall associated with the pinging problem. About a week later after the "fixes" were applied to my van the pinging has returned. Not as bad as it was but it is still there. Anyone had a similar experience or actually have had the problem cured? Thanks.
  • dnj2dnj2 Member Posts: 4
    We have been back on the road for about a week - no sign of pinging yet. But, we do not have optimum conditions to induce pinging as it is too cold. This Windstar needs hi ambient temp, fully warmed up engine and AC on to produce the pinging condition.
    Our Dealer here in NC has been super once FoMoCo owned up to the problem and devised the "fix". Suggest you get back to your Dealer ASAP.
    You need to ascertain if they reset the PCM, reset the Octane setting to 87, were diligent in cleaning carbon from the engine as well as simply replacing the valve cover.
    Factory only "allows" 1.5 hours to do this whole job, a job that takes somewhat longer to accomplish. Maybe you only got 1.5 hrs worth of fix!
    Good luck with your Service Dept folks, and please keep all of us in the "Ping Club" updated.
    I'm going to take our Windstar out on a vigorous test drive tomorrow!
  • cmhdiamondcmhdiamond Member Posts: 11
    I have a 2000 Windstar LX and I have not had any major trouble with it to date. I do have a question about TSB's though. I have found listings of TSB's on several websites, but I haven't been able to track down the full text of TSB's anywhere on the 'net.
    I have reviewed some of the titles and there are a couple that I would like to read more into before I go through the hassle of setting up service for my van. For example, I occasionally experience a single tone from my van's dash. There doesn't appear to be any reason for the tone. It just beeps for no reason. I have seen a TSB that looks like it is related, but I can't find the full text to see what the problem might be.
    I have also seen TSB's related to the pinging problems related above. I have a friend who is having his van serviced for that problem under what his dealer says is an as-yet un-announced recall by Ford. I would like to look into those further just in case my van develops the problem.
    Does anyone know of somewhere on the 'net that I can find the full text of the TSB's that are related to problems I'm having? So far all I can find is the list on the NHTSA.GOV and that only gives brief summary info, which isn't always very descriptive.
    I dont think you will find the text of the TSB's readily available. You may need someone on the inside at a dealership to pull them off OASIS for you.
    If you find the info on the internat, please share with us all.
  • rjj6rjj6 Member Posts: 1
    My wife has a 97 Windstar(75K), and at the end of last winter season (NY) and now the beginning of this season, when it gets even a bit cool out, ALL of the side windows fog up. Even with the defroster on high, it can barely keep the front window clear.
    It is almost like the defroster is pumping moisture laden air into the car.
    We've had our fair share of problems with the WS,
    (abs, computer etc.) but we've not been able to solve this one.
  • bblahabblaha Member Posts: 329
    Ok, up till now our 99 SE has been basically flawless (25k miles). And we really like the van. However, twice now in the last 3 weeks, we've been temporarily stuck because we couldn't shift out of park.
    Once it happened to me, and once to my wife. I can't vouch for my wife's diagnostic abilities (well I can, but I'm prevented from speaking out by the "If you can't say something nice..." rule :-) ), but when it happened to me I noticed that the brake pedal went most the way to the floor (it didn't push back firmly like its supposed to). And when it was down near the floor, I noticed the brake lights went out!. With the brake lights off, the park/shift interlock won't disengage.
    I was able to get it to shift by pressing lightly on the brake enough to illuminate the brake lights, then shifted straight to neutral before stepping hard on the brake. I test drove it around the parking lot and the brakes seemd to be working fine, so I drove it home. When I got home, the problem had disappeared (and of course the dealer the next day was unable to reproduce the problem).
    When it later happened to my wife, she was fortunate to have a Ford technician waiting to have his eyes examined (my wife is an optometrist). He looked at it and said it was the brake light switch. He showed her how to "make it work" until she could bring it in. She hasn't showed me yet what "make it work" means. :-)
    Has anybody else had a problem like this? My memory is too poor to recall any prior posts.
  • jamesl3jamesl3 Member Posts: 12
    ON 1-13-00 THE VANS HEADGASKET'S WERE REPLACED AND THE HEADS WERE SHAVED.0N 1-25-00 IT DEVELOPED A LEAK BOLTS ON HEAD WERE LOOSE. ON 3-27-00 THE VAN WENT BACK IN AGAIN REPLACED BOTH HEADS AND GASKETS. THIS TIME EVERY THING SEEMED OKAY UNTIL YESTERDAY TEMP GAUGE WENT TO HOT SHE PULLED OVER TO THE SIDE OF THE HIGHWAY MOTOR WAS KNOCKING AND WHITE SMOKE WHAT SHOULD HAPPEN NOW. BY THE WAY VAN HAS ABOUT 37,000 MILES ON IT NOW.
    Take it back to the dealer. The head gasket on 95s is warranted to 100,000 miles. If the head gasket failure damaged her engine, she'll get a new one for free.
  • penguinpenguin Member Posts: 32
    I had the same problem one time and it was simply a hose that was not connected. It was sucking in outside air and actually making the windows worse. Check to see if any hoses are loose, or if you can't locate any, take it to your dealer. If that's the problem, they should fix it for free.
  • monsbrikmonsbrik Member Posts: 1
    We have a 98 Windstar with 46,000 miles and now need to replace rack and pinion steering assembly and the power steering pump at $1,000+. Pretty significant failure for a vehicle of this age. Dealer noted problems with rack and pinion but not this early (mileage wise). Has anyone had similar problem?
  • argyletxargyletx Member Posts: 6
    We finally have a permanent fix to our chronic sliding door problems....a 2001 Yukon XL w/2nd row captains seats. Same interior layout as WS with more room!
  • cptpltcptplt Member Posts: 1,075
    The original WS had a problem where if you put it into Park on any sort of slope (no matter how gentle) without first putting on the handbrake, it was very difficult to get out of Park again.
    Don't know if thats the problem you are experiencing or not. Had it in my 95 and it drove me nuts till the dealer told me the "fix".
    My 2000 has a totally different problem. The shift lever was falling apart, you could never tell what gear you were in by looking at the dash! Something had broken in the housing on the column!
  • bettyd1bettyd1 Member Posts: 5
    If anyone is thinking of buying a 2000 Windstar, or any Windstar for that matter, I suggest you reconsider. I wish I had read all these posts before I bought my 2000 in March. The dealer, Koon's Sterling Ford, in Sterling, VA has had my van for 2 weeks now and there is no end in sight, there are so many engines on back order!! Plus, they have been awful to deal with. You would think that they would try to make a customer happy, especially in this type of circumstance, but it seems they are doing everything they can to aggravate the situation.
    My suggestion - Run to the nearest Honda dealership and get an Odyssey! (As long as it isn't a Koon's dealership!!)
  • the5foursthe5fours Member Posts: 7
    Had mine in now for 29 days, 30 coming up to
    replace the sterio. Dead battery, sliding doors
    going in dead battery mode, fuel milage
    dropping-see several older models doing the same.
    Any problems i would be interested in hearing about
    as the dealer called Ford because they can't
    duplicate the problem so ford won't let them try
    anything.
    Should add that its the SELs I'm interested in since there is a recall in Stars that don't have a message center to replace the PCM even though the problems are simular
  • jmhansenjmhansen Member Posts: 2
    I have had a 1996, 1998 and now a 2000 Windstar, totaling more than 85,000 miles to date with NO warranty repairs required. The front brakes seem to wear faster than I would like, but other than that I am totally happy.
  • winnipegwinnipeg Member Posts: 1
    I have had my windstar for less than 12 hours and
    now the antitheft device is having a problem
    recognizing the keys... tried both keys numerous
    times before one of them worked and then I tried
    the other key again and then it decided to work
    also.... The problem only seems to occur when the
    vehicle is cold... ( -30c ) thats what I figured
    out so far.. she's heading back to the dealer
    tomoro would appreciate any comments on similar
    problem
  • teedoff2teedoff2 Member Posts: 1
    Our '98 Windstar has only 28,000 miles on it and this should not have gone on it. Dealer said warranty expired 4 months ago! We also have gear shift problems - it makes a loud clunk when shifting especially into reverse. Dealer said they couldn't "hear" the problem! We're going to get rid of this lemon ASAP!
  • mjwhetstmjwhetst Member Posts: 5
    We bought a 95 GL in Nov 94 with 600 miles on it. We are relatively happy with it, currently have about 160,000 miles on it. Here goes the history for those interested : We drive it just about every day. Front brake shoes lasted about 50,000 miles each, the rears lasted 125,000. Had some transmission sensor replaced at 20,000 miles while traveling, got it fixed under warranty the next morning while waiting in Council Bluffs, Iowa. Sliding door recall (Ford paid), loose hood recall (Ford paid). Had anti-lock brake problems, took $100 to disconnect a ground wire to fix problem around 60,000 miles. Had check engine light on, took a few visits but was mass airflow sensor, problem resolved. Replaced oxygen sensors (2) with updated design at 60,000. Had the full service transmission services every 30K miles at a transmission shop. Change oil every 3-4K miles, 5W30. Put semi-sythetic in at wintertime. Coolant flush/fill per the owners manual. Water pump at 110,000 miles ($400, a [non-permissible content removed] to get to). Changed the starter myself at about 100K, had not failed yet. Had head gasket replaced under recall at 100K miles, was only leaking a quart every 6 months or so. Replaced plugs every 60K. Transmission had aluminum shift piston break at 120K, had local transmission shop rebuild and replace anything that was marginal, not just what was broke. Cost $1000 parts and $800 labor, included new differential and steel shift piston. He stated FORD sends their transmission work to his shop and only allows the part broken to be replaced, and charges the customer (or whoever is paying) the full cost of a rebuild. Maybe that is why some people have problems with their "new" transmission so soon after "replacement". EEC went out at 125K miles when traveling, about $400 plus renting another windstar to complete the trip. Put in new struts/shocks at 130K, but did not really have any problems. Put transmission cooler on and started towing a box trailer of about 1500 lbs, have about 1000 miles of this. Have five kids, they are growing, so we put in stiffer springs in the back to keep from bottoming out. Really helps. (added 1500 lbs more strength) and only added an inch or two to the ride height when empty.
    Cost of ownership : Total costs of vehicle (5 year loan, 8%), insurance, gas, all repairs, tires, normal maintenance, etc came out to $0.34 a mile. Anti-lock brakes still work, A/C still works. Min-vans work great for what we need, am looking to get a full size van next time (12 passenger Ford) but waiting for the windstar to blow the engine or something not worth fixing to kill it first. Must have gotten relatively lucky with this van. We also own a 95 Mercury Tracer (econo car) for 100K miles and the only problems were the dome light and a front wheel bearing went bad ($100). I will shut up now...
  • kamdelkamdel Member Posts: 1
    My power steering pump went when my 98 wind star was only 11 months old with 9,000 miles. Had the rack and pinion replaced at that time as well. Tie rods and front main oil seal went at 43 months with 29,000 - lucky I purchased an extended warranty.
    I will not be replacing this van with another wind star.
  • mroz3mroz3 Member Posts: 1
    I had a pinging problem with my 1999 Windstar which the dealer totally ignored. Get this, the mechanic who did a road test with me claimed he could NOT hear the pinging ! My 6 year old daughter in the 2nd row seat COULD ! Ford's position was, lets wait until something really big happens then we'll fix it.
    If you live in the Vancouver BC Canada, steer well away from dealers that sound Rich. Better still steer well away from automobiles that seem to need fixes or repairs almost daily.
    Cheers.
    p.s. I assure you I am NOT a Ford competitor !
  • lsg1lsg1 Member Posts: 42
    I have a 2000 Ford Windstar LX. I posted last month that my van was in an accident and we were thank G-d fine. The question I have is about my van after it has been fixed. The van was fixed by the body shop(the whole front end was shifted over to the left), and after they fixed it, attempted to drive it, and it would not drive. They put it on the comptuer and it showed a problem with the transmittion. They opened up the tranny, and there was a crack in the aluminum wall of the tranny, and the gears were all shifted forward. They now put in a brand tranny(they said it is brand new from detroit, and not rebuilt). The shop said the tranny (and everything in my front end that was fixed) is now guaranteed for as long as I own my van. Is this how it works? Will my van work as well as it did before the accident now that I do not have the original trans. in it?
    I am really upset, because the body shop guy said that if the original adjuster saw that there was damage to the trans. they probably would have totalled it, and I could have had a brand new van...now I am stuck with this one, because they did the work already.
  • drew_drew_ Member Posts: 3,382
    I'm surprised that they didn't total it in the first place, especially after such a serious accident in a brand new vehicle. After an accident (even a fairly minor) in which the frame of the vehicle is compromised, the structural integrity/crashworthiness will never be the same as with a brand new vehicle. Hopefully your powertrain will be about as good as new though.
    Best of luck!
    Drew
    Edmunds.com Townhall co-host
    Vans and Aftermarket & Accessories conferences
  • irbellesirbelles Member Posts: 1
    I have about 17000 miles on my '99 Wind star (3.8/200 hp). I have been having intermittent transmission problems similar to those described in prior messages. When I try to enter traffic quickly... not a jackrabbit start, there is sort of a 1-2 second hesitation between gears (2-3...I think) and then it sort of slams into gear, the whole van shudders. (The sensation is similar as if I was spinning on ice, and then hit bare pavement.)
    About two weeks ago, the dealer had my van for a week replacing seals... the suspected problem. This did not solve the problem. I've seen other posting with similar problem described, but I don't believe I saw a fix... has anyone ever actually gotten this problem resolved?
    Thanks in advance for whatever help you provide!
  • kjclowkjclow Member Posts: 29
    My wife was rear ended last month. She was parked at the curb and pushed about 10 feet after contact. About $4000 damage to our 97 Windstar. Now, while on our Christmas trip, the speedometer has gone crazy. It will change from 40 - 120+ while the van is on cruise. Has anyone else experienced this problem? I tried to look through the postings, but there are too many and too little time. The dealer says that he needs at least two days to fix it. Is this a "normal" problem or something that could have been caused by the accident?
    Also, I have been getting some moisture on the carpet between the front seats. Does anyone have any sugesstions as to what to look for? I have about 84000 on it and have no major problems to date. Is this just the tip of the iceberg?
    As for the problems of load noises when shifting out of park on an incline, I think that I have finally figured out how to avoid this. From a previous post.... Come to a complete stop. Set the parking brake. Ease off the brake until the van is fully engaged to the parking brake. Push the brake pedal back down and shift to park. When starting, push the brake down, shift into gear, relate the parking brake and go. Seems to help
    Thanks for your help.
  • throbinsonthrobinson Member Posts: 1
    I have had this car just over a year and the power sliding door had given us a problem. Sometimes it would not close once it was open and sometimes it would not open. Trying to close it manually when this happens is nearly impossible. The dealer said they would order the "part" and when it finally came in and I left it for them for two days they said they needed to order another "part". Finally after they "fixed" it I had trouble again with it while on vacation. Also there has been a terrible "sucking" sound occasionally when starting the car. They looked at that three different times and could not find any problem. They finally said it was normal and was the choke. Why doesn't it do it all the time? One other thing, the plastic trim on the passenger front seat broke and they claim we must have jumped on the seat in order for it to break. I am not impressed with the dealership or with Ford over this vehicle. I doubt I will buy another Windstar.
  • bakes2bakes2 Member Posts: 1
    We have a 1999 Windstar with 42000 miles with major transmission problems. There was no prior warning. We are now looking at a $2700 bill to replace the transmission and whatever the rental car expenses total. My dealer tells me its my problem because the warranty ran out at 36000 miles. Anyone with ant similar experiences please respond.
  • crkeehncrkeehn Member Posts: 513
    Yes, that is a fairly common problem with the Windstar and Taurus. You mentioned that it happens when you are on speed control, does your actual speed remain constant, ie are you moving at about the same rate, does your tachometer seem to remain steady?
    Apparently the speed reading is electrical, not mechanical. You might try looking under the dashboard and wiggling/reseating the wires to the speedometer. I had a similar problem about a month or so ago, in reaching back to feel I had jiggled the wires, the problem has not come back so far. From other reports, to replace the speedometer head would run about $500.
    Thanks, crkeehn
    The dealer quoted a price of 475 plus tax to install a new head. I'll play with the wires on the back this weekend and see if that fixes, or temporarily solves, the problem. I hate to part with that amount of money just after Christmas. Especially since we have to replace the windshield, too. Rocks and/or kids throwing things off an overpass. Best price on Windshields, at least in Charlotte, NC, was $250. We may end up trading the thing in this weekend on an Olds Silo, if I can figure out where the money is coming from.
    To answer your other questions... The tach remained fairly constant and the driving speed did not change. Just what the speedo said we were doing. It's fine on the highway to run by the tach, but I haven't paid enough attention to where the tach runs for the lower gears to try to use it in the city. I sure don't want to support my local law enforcement agencies, not that way at least.
  • mr_toadmr_toad Member Posts: 1
    The speed sensor which is located on the top side of the tranny is either loose or shorting out. I had one replaced with the exact same symptom, wild variance in speed indication and eratic cruise control and gear up/down shifting which is directly related. In my case it was a worn speed sensor gear (nylon) that was the culprit. Total cost of repair was about $280 US Currency.
  • blambblamb Member Posts: 10
    We currently have a 1999 SEL. We leased it for 24 months, and the lease is up next month. The odometer just changed to 25,000. We are extremely happy with this vehicle, and are going to lease or buy a 2001 SEL. We owned a 1995 Windstar, and sold it at 25,000 miles. This 95 was also trouble free. Due to the low miles, we were probably lucky we did not encounter the numerous problems that other 95 owners experienced. Our 99 only had a few minor problems, and they were taken care of the first time by the dealer. So, perhaps some of the people unhappy with their current service may try changing dealers. I also feel that the SEL is one of the best looking mini-vans on the market!
    At least for us, the 99 has been very dependable and reliable. Thanks for listening!
  • seabee9seabee9 Member Posts: 1
    I'm a new user to this site and it looks like there are a lot of us in the same boat. We purchased a 2000 Windstar SEL and have had it in the shop four times already. Anything from the battery going dead, windshield gasket not sealed right, rattles needing fixed (sounded like a '74 Econoline Van), and of course the door problem. The doors seem to have a mind of their own. They can be closed and will open on their own at any given time. Imagine coming out of a store and the doors wide open on your vehicle. And of course the problem everyone else has, they don't want to close properly, and god forbid if someone has a finger or arm in the way it doesn't reverse itself like it is supposed to. This is a good site to gleen info from other people on the problems and possible fixes that might be out there. But we need to contact the NHTSB with the problems that are safety related. Doors are definitely safety related. As of today there are three postings on the NHTSB site directly related to the door problem. We, as consumers of defective items, and apparently no help from Ford, need to let the NHTSB know our problems. Maybe they will send Ford a Happy New Year letter telling them to find out what the problems are and fix them. It is evident that the people who keep this company in business by buying their vehicles are not getting the attention back from them that is needed. Time to get into their pockets and make them do things right the first time!!! The NHTSB site address is
    www.nhtsa.dot.gov/ivoq/oscripts/IVOQ/VOQ/voq1.cfm
    Let 'em hear from you.
    If I have a 2000 Windstar LX that I want to trade in, but has been in an accident, how do I find out how much would be taken off the blue book value of the van when I go to trade it in? It is perfect condition(now after being fixed after the accident), but I would rather not drive it anymore.
    My lease for my 1999 Windstar SEL expires at the end of January. I leased for 24 months. The SEL was 32,000. My payments were $457 with zero down. I just paid the first payment.(no sales or security) I felt that this was a really good deal. Now, I am looking at 2001 SEL. I have been finding that they now want around $520 or so. One dealer quoted $588, plus sales tax down. Would you let me know if anyone out there have any lease quotes for the Windstars for 2001? Thank you.
  • peter26peter26 Member Posts: 4
    These are the problems we are experiencing at 10,000 miles after one year:
    1. Sometimes the passenger side sliding door would not close using the key fob remote control or the overhead button. Manually pulling on the door a little and pushing it back seems to do the trick. It could be that the motor does not pull the door all they way back to engage properly for closing. I will complain about this at the next service.
    2. The driver's right arm rest keeps drooping and then falling off. The dealer ordered us a new one, but problem persists. This could be a design problem. The clip on the armrest appears weak and the post to which it attaches has no detent position. I wonder whether others have experienced this and have a solution.
    3. The engine shudders when accelerating slowly from a low speed.
    4. I had the dealer install mud flaps. They installed it too low to the ground. When I hit small bumps, the mud flaps scrape on the road.
    5. We drive the van short distances at fairly low speeds everyday. As a result, we get very low mileage.
    6. The third row bench seat is very stiff and uncomfortable. Long rides would be unbearable.
  • czubaczuba Member Posts: 1
    Has anyone else experienced a shuddering , sometimes significant, running at highway speeds , usually going up grades ?
    Can avoid by backing off the accelarator or flooring it -
    Is this a famous transmission issue ? thanks
  • liebedaliebeda Member Posts: 13
    I have a 99 Windstar LX with about 12,500 miles. Recently, I noticed that there is a pinging / beeping sound when I turn on the heater or defogger. It lasts only about a second or two. Does anyone know anything about this?
  • grregggrregg Member Posts: 2
    I have 95 WD LX with 80,000.Engine replaced at 65,000 miles at Ford expense(hg failure).Now my Windstar is shuddering when going over 65mph(same problem- post#288).Any1 know if there is a recall or "secret warranty " adressing this problem.Also is a buy back program applying to trans problems?Thanks!
  • snachimsonsnachimson Member Posts: 2
    We've just leased a 2001 SEL after being happy with a 99 SE. However, we've just noticed that accelerating past about 10-15 MPH, we hear a "scraping" sound from under the car. We'll go back to the dealer ASAP to have it looked at, but has anyone had this experience?
    Sorry I can't help you with your problem of the sound you are hearing. I have a 1999 SEL with 26,000 and it has been basically problem free. See my post #286. Did you lease for 24 or 36 months on the 2001 SEL? We are getting ready to lease again. If you don't mind, can you tell me what kind of payments you are looking at? Thank you for any assistance you may give.
    We leased a 2001 SEL with family securiy package 2, floor console and side air bags. Lease was for 36 months. No cash out of pocket, payments are $585 month. Rebate covered first month's payment, rest went to capital cost reduction. Note that in Maryland sales tax is 5% of total cost of car, + tags of about $100. We put no money down at all.
  • djacob62djacob62 Member Posts: 5
    We bought our 98 Windstar GL (3.8L) in the spring of 00. So far we really like it but after reading a lot of these posts I'm getting a bit nervous. Anyway it has 46k on it now and twice in the last 4 weeks my wife has been driving it when the ABS light illuminates but other electrical devices like dash lights, radio and turn signals go out (luckily the headlights stayed on). In both cases she pulled in to a parking lot, shut the van off and then re started it and everything was fine. Anybody have any ideas?
  • worm4worm4 Member Posts: 1
    Our '99 Windstar has been plagued by a variety of small but frustrating problems.
    For the past 10 months ALL THE INTERIOR LIGHTS (dome, reading lights, door courtesy) just FLASH ON AND OFF intermittantly It doesn't matter if the head lights are on or not. This becomes quite a safety issue at night. The van has been in the shop numerous times with no success. HAS ANYONE ELSE HAD THIS PROBLEM ? If so how was is repaired? We are close to the end of the warrenty.
    We had other problems with the van. Most frustrating was a cruise control that only worked once in a while. It took the dealer a year to fix it. All the radio speakers and door locks/switches have broken and been replaced. During the year and a half since we bought the car there has always been some thing wrong with it.
    I'm worried about other electrical type problems down the road. It just seems like one thing after another goes wrong.
    Do you think we should get rid of it?
  • mrcoffeemrcoffee Member Posts: 1
    I have a 1996 wind star and I have a Head Gasket leaking I have bought the van used with low miles. Does any one out there know if there is a Recall on this. I hear is a big problem with the 3.8 v-6 E-Mail me with any information. [email protected]
  • jeffreywilensjeffreywilens Member Posts: 10
    I am assembling data on the problem we have had. Every once in a while, some sort of electronic problem arises whereby the power side doors will not open or close from the buttons in the door frames. They will usually still work from the driver's station buttons and the remote control. However, on a couple of occasion, the battery was drained dead and had to be jump started. Eventually, the dealer told us there was computer chip that needed to be changed but that really has not fixed the problem.
    It returns every few weeks and lasts about a week to 10 days, then just magically goes away....for a while. There seems to be no correlation to the weather, how we drive it, how often the doors are opened with or without car engine running, etc.
    Anyone with data on this problem please email me at [email protected]
    I am an attorney and I have had the Van in a few times already for "service."
    When your interior lights are flashing, do you also get the chime like you would if the key were in the ignition? It is possible that the door sensors are causing you a fit. Try cleaning the four round silver contacts in the sliding door frame. They will get dirty and cause that problem. A pencil eraser or something that is very mildly abrasive should do the job.
  • mnmommnmom Member Posts: 1
    We have had our 99 SEL in for service at least four times for the doors as well as the battery had died 3 times for no apparent reason. One of the three dealers we have been to put in a new battery thinking that the battery had a bad cell. It died again. The doors seem to be working again but not because of anything the dealer had done. Another gripe is, my overhead compartments rattle. The last dealer put little foam tape pieces on the latches. That worked great until I opened them!!! I will never own another Ford. I had an Explorer in '94. They do not make good quality. We are dumping this Ford SAP.
  • rudyw1rudyw1 Member Posts: 1
    I had the original 25 gal tank on my 98 Windstar, 3.8L replaced with the "improved" model soon after the initial purchase in Nov 97 so now being on 'E' means there is still 5-7 gallons (this is said by the dealership to be an acceptable characteristic of the tank). I am curious if the 20 gallon model of the 98 year has a more normal setup, and if 25 gallon tanks from other years act like the 98. Anyone able to shed some light?
  • windscarwindscar Member Posts: 2
    Help!!!! can anyone out there walk me through the buy back procedures for wind stars. I have a feeling I will need to know and certainly forewarned is forearmed. I sure wish I had read this before I bought this bonafide piece of --t. If they offer me a buy back I will jump all over it. I truly don't want this thing back again. You have to have a certain amount of faith in your vehicle to get in it and drive it every day and I have none in this van!
