Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
Ford Windstar Problems
Actually, I had one of the more in-famous 95s with 128k on it and had it totaled a few weeks ago by a fellow who ran a red light. The insurance company set the price at $6,940 as the replacement cost. Not all that bad actually. After about 50k it ran like top. This was to good of a deal to pass on: $16,450 for an SE with less than 20K. Except for one or two little scratches it looks new. I contacted the old owner and they upgraded to a 2001 SLE to get the video system and leather along with "financing to good to pass up". I know what people say about the value but if you keep them for as long as we do it balances out. While I was happy with my 95 I was not dumb when I purchased this one I also got the 6 year, 100k none deductible warranty. ($1,500 for it and now for the next 6 years I really have no concern.)
A year ago, I had a minor crash on the front bumper (that I can live with without repairment) and since then I noticed there is clicking noise coming from the dash broad when I drive above 50 miles per hour.
Then about 6 month ago, the speedometer needle started to shaking (swinging) when it goes above 60 mph. I took it to a dealer, and they said I need to change speedomter head as well as cables. And they want $800 for parts + about $100 per hour for labor. Yes, I live in silicon valley and labor is very expensive.
Since then I talked to two other repair shops since I don't want to speed a lot of money and also don't believe that I need to replace the whole thing. One of them said he needs 2 hours to do diagnostic, and may need more than 10 hours to do the repair. The other said he can find out what's wrong in 10 minutes and can repair for me for below $600.
I would like to find one that can do the repair for about $300 to $400. Is it possible? Does anyone else has the similar problems with their speedometer? I saw a few post on the internet for the similar problem, but none of them mentioned how difficult it is for fixing the problem and how much it could cost.
Thanks for the help.
I had the problem about a year ago. At that time, I reached behind the dashboard and made sure that all the wiring was tight, jiggling the connections to make sure that each was a clean connection. I haven't had the problem since. I have heard of others that have tried the same technique and it didn't work.
This is my first used car. I have always bought new but this one was in really good condition and I was able to get the new car extended warranty on it since it was still under the 3/36 new car warranty. I may never buy new again depending on how this one turns out.
You are 100% correct about the luck of the draw on getting a new car. The 95 Windstar had a bad rep since it was the first year. However, mine was just fine except for the head gasket. I only had one repair after 75K and that was for a broken ground wire. I have the dealer do all the major maintenance as called for by the manufacturer and it just kept on going. I would still have it if not for the accident.
I had the speedometer replaced, only to have it come back and make a grinding noise again once the warranty was up. The only other thing I can remember replacing was the driver's door regulator under warranty. Overall I think the 97 has been the most reliable of the Windstars. We plan on keeping it another year or so, and then replacing it with a pick up truck with additional pulling power.
Does it have rear air? That is what usually makes the difference in the price. Unless it has rear air and tinted windows to help keep the sun under control you may want to give it a second thought if you need rear air and it does not have it.
Given the fact that this car has never had any problems and was driven mostly freeway miles by a very unaggressive driver makes me give it strong consideration. In any case I am taking it in for a professional 125 point inspection today before I decide.
I use a soft-sided luggage carrier only because it was much cheaper and I could jam all kinds of big odd-shaped stuff in it.
Our octane grades are 85, 87, and 89 for Premium. It has always been my understanding
that at the higher altitude areas 85 octane should perform equivalent to 87 octane at
lower altitude. I have never had any problems with 85 pinging in my other cars, but now
with the Windstar being over 20,000 miles it seems to ping with 85 octane gas. Just wanted
to know if other owners find it difficult to run the regular octane gas. The car is doing much
better with mid-grade gas. Wondering if it needs an adjustment since there was no ping
problem in the early miles of the car.
---I had my local Ford dealer check the heater & was shocked when informed the estimate to repair the front heater would be $1250.
---I was told newer Ford, GM & Chrysler vehicles all have their heater/vent/air conditioner doors & controls mounted into one common heater/air conditioner unit or box and this is mounted under the dash and replacement, not repair of this box is the usual fix.
---To replace this box, the dash & steering column must be removed which would take many hours resulting in a major labour and parts bill.
---The Ford dealer after inspecting my heater box, stated no repair could be made and it would have to be replaced.
---I obtained a 2nd opinion from an independant mechanic in my area and he was able to repair the heater box for $160 labour charge.
---The problem was the hot/cold air flow door had broken & jammed closed in the cold position.
---I suggest, for any costly or major repair to have a 2nd opinion from an independant, reliable mechanic.
raykrol
I have a question for the forum. My 2000 Windstar LX is getting rotten gas mileage (12 mpg). I have taken it back once and they reprogrammed the PCM and replaced the front control module (whatever that is). This appears to be to no avail. Still getting rotten mileage (12-13 mpg). Any ideas as to what I can try before I take it back to the dealer? Any info would be appreciated.
Last week, while STOPPED in a McDonalds drive through, the rear window on my 2000 Windstar SE exploded outward. Thankfully my children and their friends in the car were not injured.
We heard 2 pops, then I looked in my rear view mirror and watched the rear window crack. When I exited the van, there were two large holes, one on the left and one on the right of the window, with glass shattered all over the ground. the glass that still remained in the frame was completely cracked. No glass had fallen inside the van. The witnesses (the woman stopped in her car behind me, my other adult passenger, and the McDonalds' employee who was outside taking the orders) all reported the same thing - nothing hit the van, and the glass exploded outward. It was a warm day, so there was no heat on or the rear window defroster.
My Ford dealer, of course, said they couldn't help me and I needed to go through my insurance. Someone I spoke with recently mentioned he had heard this happening before.
Has anyone had a similar experience? I'd appreciate any info you could provide. Thanks!
My Ford dealer
It was blamed on the Texas heat and the dealers refused warranty replacement.
Might be interesting to see if any more "pop" up here...
I also have a groaning noise coming from the front suspension when I hit rough pavement. I too thought maybe it was something loose like the exhaust system. The mechanic thinks it may be the front bushings, which I'm sure will be pretty expensive to replace. I'll leave them for now, since it doesn't affect handling and is only a minor annoyance.
