Pontiac Grand Prix Brakes
I hope someone can help me. I have a 2000 grand prix and yesterday my abs light came on as did my trac off light. I took it to a repair shop and they used a scan tool and it came up with no codes. The mechanic took it for a drive and did a 4 wheel abs test and it worked fine(the light wasn't on at this time) Now when I start the car the lights are off but after after a few minutes I feel a quick grind in the petal and the lights come back on. Please help me...
I made the mistake to take my 2005 Grand Prix GTP to Germany. I am stationed at the U.S. Army Regional Medical Center in Landstuhl. Apparently, Pontiacs are neither sold nor serviced in Germany or Europe for that matter. Usually, there is some kind of service (military sales) for members of the Armed Forces but all the information I get from GM is completely useless (non-existing phone numbers and e-mail addresses). So much for my warranty. Anyhow, because of the different driving conditions, I ran into problems that I didn't realize while in San Diego. First of all, starting at a speed of 110 miles per hour, there is a terrible noise coming from inside the dashboard. I cannot detect any vibrations and it does not sound like wind noise but more like a mechanical noise. It's so loud that you cannot even talk in the car. This is my main problem. Perhaps somebody else stationed in Germany and accustomed to the German Autobahn has had the same problem?
The second issue is that the car won't go over 200km/h, or 125mph. There is apparently a limiter built in/programmed that does not permit the car to go faster. So most German compact cars can easily pass me. I understand that the domestic engines are not made for constant high speed driving (unlike the BMWs for example), but I would like to have the ability to mobilize speed when needed. Does anyone have any idea how to solve this while being overseas?
Finally, the brakes are disaster. I had everything checked and had a full service before shipping the car. However, these brakes are completely unfit for the speeds that are commonly driven here. Does anybody know about any upgrades that could remedy this situation?
It's very frustrating. My other car is an old (92) 318IS BMW. The engine is not even half the size of the GTP engine, it only has 140bhp instead of the 260bhp of the Pontiac, and it is 13 years older. Yet the little BMW kicks the Pontiac’s [non-permissible content removed] any which way it wants to. The Pontiacs handles like a boat on the narrow, winding roads. Unlike the BMW. And on the Autobahn, the beamer's top speed is 215 km/h as listed in the title while the GTP quits at 200km/h. I love the way the Pontiac looks. But I hate that almost any German compact car is faster than my GTP while only consuming half the gas.
Anyway, if anyone has a suggestion how to fix any of the above problems, I would greatly appreciate. I would hate to sell my GTP, but in Europe, it is next to useless. Oh well.
Tom
I am also relatively new to the "GTP" experience. I purchased my 2002 GTP 4 days ago. I have been doing ALOT of research on mods and tuning the last few days. The solution to most of your problems would be to get the PCM (Digital Horsepower Inc. v1.0 PCM for Grand Prix GTP ). This will take the limiter off, and increase hp by changing shift points and temp check points. There are a few mods that also need to be done in order to get the best gains (and least amount of knock) out of the GTP. A great site that has all the parts your looking for is : link title
This site explains what each component will do as well as anything needed. To get best results these mods need to be done:
Developed with the average 3800 enthusiast in mind, this calibration has been designed and dynamometer tested and proven for the following vehicle modifications installed:
- 3.4” - 3.25” pulley
- Cold air induction system (brand not applicable)
- Cat-back exhaust system (brand not applicable)
- Premium fuel (91+ octane)
FEATURES:
- Speed limiter removed
- 3-1 and 4-2 skip shifts (Active in performance shift mode only*)
- Transmission line pressure increased (Active in performance shift mode only*)
- Shift points moved (5800-6000rpms) (Active in performance shift mode only*)
- Fan turn on points altered:
- 186 degree turn on
- 2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
- MAF calibration adjusted for proper operation and year
- Digital Horsepower Inc. fuel/spark adjustments:
- En-richens fuel delivery for critical problem areas
- Provides a consistent power gain across the entire power band
- Reduces spark retard (knock retard)
- Removes “40MPH WOT lag”
- Dynamometer testing has shown up to 20 HP gain in 60 degree temperatures on a development vehicle. Click here to view the dyno results and detailed explanation.
*NOTE: Cars without the performance shift button will require a wiring harness modification for these shifting features to be enabled.
This is the best mod and most cost effective way to increase your gains accross the board. The PCM is like $100.00 (pretty cheap mod), but the exhaust can run 300-500 bux, and the intake runs 250-350 bux. So with about 7-800.00 bux you'll have a low 14 sec car, with no limiter and about 280-290 hps. Quickest and simple way to answer all your problems. I have also heard that these are relatively simple engine mods. My buddy is in the army and is in Germany as well, he is a Hummer mechanic. He always is telling me stories about the audobon (sounds like it would be fun!!). His name is Kelly Dood (nickname NEMO), If ya know him tell him Adam said "what up!" and good luck with your GTP. Peace
Adam Johnson
Thanks for your input. I already found the Digital Horsepower DCM at www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=GP3901&P- roduct_Count=18&Category_Code=04UNDER
But it says that it is not intended for the stock GTP. Moreover, installation will void my warranty. So unfortunately, it will have to wait until after warranty is up. There should also be a way to reprogram the original part. I will look into that too.
My main problem is the awful noise I am getting at 115mph. But I hope to get this solved. While GM in the States is completely clueless regarding Pontiac in Europe, I managed to find a GM dealership in the area that honors the warranty for military personnel (found it in the military finder's guide). I have an appontment on Memorial Day and hope that they can fix the problem.
The other problem, however, is that the brakes are already a disaster at a speed of 125mph. When I had to hit the brakes at that speed, it scared the [non-permissible content removed] out of me. While the brakes on my 14-year-old toy BMW have no problems with even higher speeds, the Pontiac is definitely not up to the task. My conclusion is that the car was never meant to be driven that fast. It's a shame. It is beautiful. It got muscle. But it doesn't have what it takes. It's all show. Like I mentioned earlier, the handling is also a disaster. I never realized all this while in the States. But it is a completely different ball game over here.
As for your body, ask him where he is stationed. I am in the K-Town area. There are about 50,000 Americans in this area alone. And a lot of GTPs too.
Thanks again and all the best for you and your GTP.
Tom
I didnt even realize the year of your GTP. I've got a 2002 so its a bit different set-up. I was up around 123-124mph on the highway today, and I didn't feel any knocking, or hear any sort of noises. The motor felt quite strong but I could tell I was not gonna get more than 4-8 mph's faster ( I had to slow up a bit due to traffic in MY LANE!! LOL) But anyways I haven't been able to top her out yet (not sure where the limiter is set at on my year, Ive got the series II motor) I love my GTP, maybe its just the year, car companies always seem to screw up perfectly good models and engines with their "performance" standards. My brakes felt pretty good as well at the higher speeds, I didn't slam on them but I did do a little VERY LIGHT tapping. I forgot where my buddy is stationed (yeah I know I was pretty vague with his location and I forgot how much military is actually in Germany at all times...lol). I think he is in the eastern part (sorry not very familiar with Germany). Anywayz good luck with everything, I have a great amount of respect for all US military. Thank You and Hopefully you can get those GTP probs figured out. Peace, AJ
Hope this stuff helps.
I have a 2001 Grand Prix with 130,000 miles, 3.8L engine and a recently rebuilt transmission.
That being said, the latest trial and tribulation we have going on with my car is that there is a strange sound coming from the front end. It sounds like a pump running for a short period of time, (like the water pump in my dad's RV!). This occurs only at slow speeds (under 20mph). The ABS light and the low trac light do not always come on at the same time nor do they always come on when this sound occurs. The low trac light appears when there is not a problem with traction :confuse: . And to make matters more confusing, the brakes work fine. We will not take this car to the dealership - because they've lied to us in the past and I do not trust them. Other than dealers, do other mechanics have an ABS tester? And does this describe a possible problem with the ABS system?? Thanks for any and all feedback - it is greatly appreciated!
I can't tell you if all your problems are related. But my experience has taught me that the dealers have a way of "only fixing what they have to" when they know that more will need to be done at a later date. This way they can charge you again for labor. (that lesson was learned with my transmission!).
So get many opinions if you have to - please let us know what you find out.
As I mentioned before, I am stationed in Germany and took my 2005 GTP with me. Apparently, the car is not made for the high Autobahn speeds over here. Top speed is limited to 125 mph, tires are only "H" rated, transmission overheats (oil pan too small) during long Autobahn drives, and the brakes are a complete joke at high speeds (i.e., very, very dangerous). Compared to the brakes of a BMW, a Porsche, or even a Corvette, one can clearly see where the problem is: the rotors are way to small in diameter to give adequate performance. Again, driving conditions here cannot be compared to the conditions back home. When you drive 120 mph or faster (150 mph is not out of the ordinary, 200 mph are not unheard of especially with bikes) and a car going at half the speed decides to get in front of you without warning, you need brakes that can handle a situation like this.
My question is, can I upgrade the brakes on my 2005 GTP (not just the rotors) with the ones installed on the 2006 GXP? Would they fit? Could I keep my rims? Does anybody know?
I would appreciate any help.
And while I am at it: Did anyone here try the transmission pan cooler for this car? Did anyone here put in an additional transmission oil cooler in his 2004 or newer Grand Prix? If so, which one worked out good for you in terms of ease of installation and fit.
As always, all help is appreciated.
Braking performance is same or better but no more brake dust!
Others seem to be having the same brake wear.
Your mileage is about correct for the performance brakes with Metallic pads.
Most of the tweaked GXP's use ceramics as replacement or a pad from EBC or other aftermarket co.
Cost for this at dealsership $230.00.
The brakes have been bad since I purchased the vehicle.
I noticed this after taking delivery and returned to the Pontiac service with my problem. I was told there was nothing wrong with the brakes.
I again returned and complained the brakes do not stop the car in an emergency stop but are adequate when normal stops are required.
I explained, I have more stopping power at a medium pedal, than when I step hard on the brakes. It's as if I'm easing off and using less pressure for a more gentle stop when I apply them hard.
This time they replaced the brake pads, I believe this was at around 6000-8000 miles. This, however, did not correct the problem.
I then had premium pads & shoes installed elsewhere, this did not correct the problem either.
I again went to the dealer for a repair solution but my car was returned untouched with the explanation I voided the warranty by having the brakes worked on elsewhere.
Now I was on my own!
I replaced the master cylinder for a few hundred dollars, again no improvement.
Another shop said it was the power booster and $600+ later I still had bad brakes.
I then replaced the rotors on all wheels and pads again, no improvement.
I replaced the calipers, no improvement.
Then I had installed race car pads and had vented rotors but still no improvement.
I then suspected the anti-lock brake unit. I wanted to replace it but was told it works as the factory built it.
I suggested a different unit but was told it could not be done due to violation of some law regarding brake mods and I could be sued if I had a wreck because I modified it, plus my insurance company would then have reason to refuse the claim.
This car will run faster than I want to drive it even if I had normal brakes, thus the 150 mph tires it came with, but it won't stop.
I have driven it less than 52,000 miles in 15 years for this reason.
Does anyone have any suggestions? I have spent thousands of dollars with no results.
Thanks for your time.
John
Another VERY common problem is the large wire harness on left (drivers side) front. The harness rubs the Air Conditioner Accumulator mounted below the air cleaner box. After it rubs enough, it will start to cause "Ghost" ABS problems as the ABS wire shorts to the accumulator. It WILL not set codes (usually). It WILL actuate the ABS system for VERY short periods of time (milliseconds).
Talking with my auto parts dealer, he tells we that these cars need to have the rims torqued on or they become unbalanced and warp the rotors as u brake, so I always make sure every time the wheels are off that I torque the nuts to 110, so what gives??? 8000km and the rotors are warped!!!???? give me a break, my in laws have the same car, year and everything and have had the same problems with the brakes and tires.
Does anyone have any suggestions or has this happenned to them, I love this car its great to look at but If I have to replace the brakes yearly its not worth it!! Please let me know back here or you can email me at kcsap@hotmail.com thanks
-Kris, Ontario Canada
Took my 07 Base Grand Prix to the dealer, a scraping sound in the rear when I lightly apply the brakes. They look at the brakes and said fronts and rears are fine (only 7500 miles). I later figured that it only happens when the car is cold. Also only with partial application of the brakes. Anybody got any ideas? When the car is warm and been drive no sound is made.
Gary
Second, the engine runs hot when on a climb and is variable, I've had it to the dealer who changed sensors, rodded the radiator, flushed the system, changed the thermostat and says there are no error codes and no co-mingling of fluids so not to worry! This just ain't right! I know that something is wrong. Any ideas?
