Visitor Agreement.
in any case, they did tell me that the rear brake pads are thinner than the front pads to begin with (i think someone else mentioned that before). according to the dealership, although the car is a front wheel drive, when you brake on the acura tsx, all four brakes brake; sort of like a four-wheel drive... if that's the case, then why are the rear brake pads thinner than the front? so annoyed.
Problem solved. Stand your ground. Make them replace the rotors that now have prematurely shortened life caused by manufacturing problem!!!
parking brake being too tight might be the cause... but the dealership said everything was in proper working order.... ???
i did call acura headquarters and they said that they will inquire with the dealership to get to the bottom of the problem. hopefully, they can resolve this issue for me.... the discrepancies between the front and rear pads seem too high... if it is the parking brake, i'll definitely have to ask them to replace the rotors too... like you suggested... thanks...
Called acura client services to see if they would cover, they would hear none of it.
I've had Fords and Hondas before, and I have NEVER seen brake pads last under 30K miles before. To have to replace them on my first Acura at 17,800 miles (11 months!) is truly disappointing. And for the record, while I may drive slightly harder than the average bear, in no way do I drive like a formula 1 driver, and I drive this car no differently than I drove any other car I've ever had.
This is when it's time to ask some questions. How much pad material is on them when they're new? How much is on them now -- right vs. left, BTW (it matters)?
If you bend over and let these people treat you this way, it'll continue. If you ask and they give you real answers that make sense, it could turn out that you're using your brakes harder than some others do.
The dealerships will take you to the cleaners all day long, so long as they can get away with it. :shades:
But, for completeness sake, wear on each was symmetric, both were 2/32" left, was told they were borderline and could go another 1-2 months at most.
Again, I'm willing to concede that I may drive harder than some others, but again, this is not my first (or second, or third) car, and I have NEVER had brake pads wear this much at 17K miles or 11 months.
Seems others on this forum have had this issue, too.
That's a good question. I would go the parts dept and ask to look at a new set of rear pads. Then I'd go here...
autopartswarehouse.com - they sell PBR rear pads for the 2009+ TSX for $40/set.
http://www.autopartswarehouse.com/sku/Acura/TSX/PBR/Brake_Pad_Set/2009/Base/4_Cy- l_2-dot-4L/W0133-1827349.html?loc=Rear&tlc=Brakes%2C+Suspension+%26+Steering
Maybe they've changed the pad formulation since '08; I don't know. In any event, you've made me curious to some extent. Whether I'm curious enough to actually inspect the pads & get back to you remains to be seen. In general, rear pads/shoes last 2 or 3X what front pads do. You could well have a defect somewhere in the system. How's your fuel mileage? With dragging rear brakes, I'd expect lower than normal, but there are so many variables at this time of the year that it'd be pretty hard to assess.
I put carbon pads on my last car at ~40K miles & they're still on and have remaining life, at 128K miles. You may want to consider carbon or ceramic pads to: 1) slow down the wear & 2) minimize dusting on the wheels.
I'll have them look at the parking brake next time, but again, I haven't noticed anything.
This car is a lease, so hopefully this is it for repairs. Just surprised because my previous car was an 06 Accord coupe that made it through its 3 year lease (32K miles) with only oil changes/tire rotations. Was expecting the same from acura, so brake pads at 11 months (<18K miles) was a surprise. To look at this forum, looks like there are a few more out there with similar rear pad problems in the 09, maybe it was a change with the new model for 09.
Either way, I hope this is my only repair until i turn it in in 2012.
Assuming I get the car and I run into the problem with the brake pads getting worn down quickly AND the dealership does not replace them as a warranty issue.. does anyone have a recommendation of some better brake pads that can be installed, instead of getting dealership / Acura pads that are going to wear down quickly again?
My wife has a 2004 TSX. The rotors were replaced twice under warranty by 30,000 miles. The pads also didn't last very long. Her previous car was a 1997 VW Jetta. The pads and rotors on this car lasted a minimum of 60,000 miles. Same driver, same commute. Her previous car was a 1992 Passat that my records show had the first brake job at 80,000 miles.
I question Hondas brakes. Either it's the pads, rotors, or venting. Still a great car.
Honda Settles Class-Action Suit Over Brakes - By CHRISTOPHER JENSEN
Type the title in google. The NY Times carried the article.
So far so good on my TSX, but I have less than 10 K on the car. So, I'm keeping my fingers crossed.
