Acura TSX - Interior
I have ordered my TSX and have to wait 8 weeks to get it. I live in Australia, and here we call it the Honda Accord EURO. The only difference between the US version and ours is. No Nav system offered, 16" wheels instead of 17", No Milano Red color. Did you know the laether is a "Synthetic" leather, Yup thats right its NOT real leather. Hence no leather smell.
The wife says I would be going from bad to worse. Of course, these discussions become moot when I turn the key...
But I don't know, the longer I own my TSX, the less I think it needs anything else.
BTW, congrats on your new ride...I LOVE the TSX in black (it has those deep purple metallic flecks in it, doesn't it?).
Right now, I think several makers are using this approach. It turns out that leather on the curves of seats has a tendency to sag and pucker after a while.
I have the grey leather interior and from the first day I have had problems keeping the leather clean. Whenever someone sits in my car, the persons pants or belt leave discoloration on the leather. I just found it annoying to have to clean/treat the leather multiple times a month. But this last time the dye from my suit belt (which I have owned for a long time) rubbed off on the seat. I tried leather cleaner but that did not work. I took it back to the dealership and after they tried several times, they ended up eating away some of the leather.
Now 4 weeks with this car, I am forced to have my seat ripped out of my car so they can re-cover the seats. I very upset and Acura is not standing behind their car!
Anyone else have this problem?
I think that there is some Scotchguard for leather that should be used on the light colors.
I hate to break the news to you, but air seeps in the car anyway. No mass-produced car cabin is air-tight. (I have a hunch that they're not supposed to be, or you'd suffocate.)
What you described is merely the fitment of the dashboard to the body and the door panels to the doors, not the alignment of the weatherstripping-lined seals made by the doorframes to the body. Seriously, I don't think that a .15" variance in fitment is a deal-breaker. Do you?
Wrong choice of words with the air. What I meant was wind noise.
Btw, check out Edmunds link... If you look at the silver trim, that width on the driver side is a lot wider on the passenger side.
http://www.edmunds.com/new/2004/acura/tsx/100278146/photogallery.- - - html?pg_type=Sedan&imgsrc=%2Fpictures%2FVEHICLE%2F2004%2FAcur- - - a%2F100278145%2F022589-T.jpg
Car reviewers make a big deal about fit and finish and gaps and all that. Just a mere observation on my end initiated by "I didn't close the door fully" when sitting on the driver side.
I have found them on eBay for $280 and it seems easy to install. According to the directions, it seems that all you have to do is use the adhesive backing and apply the components to their respective areas.
Has anyone here gotten them for their car?
Are you happy with the decision to install it?
Did the dealer install or did you?
Was it easy to install?
Any other comments or suggestions??
Thanks RSF
Just noticed a large amount of water on the floor in the back seat of the passenger side.
Scanning the msg board, I've seen two other similar cases of this...one where they discovered the plugs that keep the water out of the cabin were not installed AND the other where the AC drain hose was not connected properly.
Any other advise to bring to the dealer with me tomorrow? thanks in advance.
I haven't seen this in the owners manual, so I'm curious what the tsx dash material is made of, so I can keep it properly cleaned and maintained. I forgot to ask the dealership, and while I'll be going in shortly for service, I just thought someone might know.
and ive only had my tsx for less than a month, and the dash is relatively easy to maintain. im anal-retentive-obsessive-compulsive about the cleaniless of my car, to give u an idea where im coming from, so take it from me, u wont be disappointed with the dash materials.
Here is my problem. I pulled the mats up to clean them and the carpet was a mess underneath. It was moldy and rusty. It only happened on the passenger side both front and rear. I cleaned up the mold but the rust is too much to clean. I took it to the dealer today and they said there is nothing wrong with the car and they don't know how it happened. They said it would cost me about $900 to replace the carpet. Has anyone else had this problem. We were using winter mats. Neither of us spilled anything that we remember. I don't understand how it can rust when there is rubber on carpet. They did pull up the carpet and said the floorboard is OK. Can some of you with a few miles on your car take a look under their mats on the passenger side.
I also feel there is too much air noise when the car hits 60 mph. The dealer tells me this is not a defect but a characteristic.
Acura should be fixing this for free, no way it's the owner's fault!
Craig
There is actually rust and mold on the carpet. It looks like it does when you move a file cabinet that has been sitting on a carpet for many years. How can you get rust between a rubber mat and carpet? A neighbor suggested that it may be the heater core. That would explain the rust because it would bring a corrosive element into the mix. It would also explain why it is only on the passenger side because I guess the heating core is typically on that side. There is also a vent under the seat to get heat to the back seat passengers so that would explain how it got to the back seat. Yesterday I ran the car with the heat on for a while and did not have a problem.
Does anyone have any suggestions? I'm baffled.
Johnny
It sounds to me like your dealer is trying to get away with something and hopes that you will just go away. Corrosion of any type is unacceptable on a one year old car. You paid a lot of money for your car, and to just accept this is wrong. The car is under warranty. Force their hand on this.
Of course, this is all moot if indeed this "rust" is the result of something you did. But, if you're sure it's not, MAKE THEM FIX IT! And don't take no for an answer.
Something is causing this. The fact that the floorboard looks OK is a little strange, but if you really feel it's rust, it's up to the dealer to rectify the situation.
Johnny
Acura seems very bad at honouring their warranty. I have 3 more years to go on my lease and then I am dumping the car back to Acura. Like Mr T. says: 'I pity the fool' who will become the next owner of my car. In the meantime, I will make sure to 'Enjoy' this car really well, if you know what I mean
No more Acura's for me.
I had another question about the accessories. Do the splash guards help? I mean since I live in Minneapolis, MN, would they protect the underbody from snow/ salt/ corrosion? Does anybody have any experience in that?
Also if I buy the IPod, instead of the acura MP3 player (which I think is kind of costly!) is there any other method than removing the stereo and hooking up through the auxiliary input at the back. I am getting the one with the navigation system so that is another issue. Do those FM modulators work good?
I would really appreciate any feedback.
Sud
I put splash guards on our TSX, and they do a good job blocking spray from the tires.
Craig
I just ordered my '05 TSX non navi. The dealer wants $119 for the cargo net, even though I pointed out that it's a $32 item on Acura's site. -He claims the extra $87 is for installation.
I'm thinking of purchasing it from another dealer's parts department once I take delivery. Should this be easy?
Craig
http://www.handa-accessories.com/tsx/08L96.pdf
I feel much better about my dealer now. I thought it was just as simple as hooking the net on a couple of hooks. Now I don't feel like it's a total rip off.
Why don't car manufactures design the interior trunk panels with the hooks, or a simple punch out. -I'm sure dealers pressure them not to so they get the installation revenue!
But, he did seem a little confused and asked if i would still take black ones if parchment weren't available afterall. So, we'll see when they get here.
