Acura TSX Navigation
I have had this issue with my Nav where the disclaimer screen appears and I get the "Ok" button but cannot press it.
Basically I turned on the car and ignored the navi system. After about 1min, I hit the joy stick to turn it on and the disclaimer and Ok button came on. For some reason I was unable to hit the Ok button or say OK. I restarted the car and problem was fixed. This happened once.
Questions:
1. Has anyone had it done and if so, what did it cost?
2. Were you able to find a module for the steering wheel controls to work with the new deck? I know they make them, but I don't know if they have one out for the TSX yet.
3. Is there anyway to get those Nav controls to work with an after-market deck, similar to how you can make the steering wheel controls work?
Obviously, if you don't have a Nav system and want to replace the deck, it's no problem... there's already a kit out for that.
This happened to me also--only once. Hopefully it won't become a problem.
However, if you want NAV and want to save money an excellent aftermarket NAV is the Garmin Deluxe ( used to be called Street Pilot III with voice) for about $700 actual price.
That said, there are two main advantages of the Garmin that are worth considering 1) With a portable GPS, you can move it from car to car as you see fit. So, if your family has more than one car, you can take it with you. 2) Some drivers don't like the way the NAV system absorbs controls on the dash. Its actually more than just a NAV system, since it alters the entire way your interact with the stereo and HVAC controls.
Personally, I have the Acura NAV in my vehicle and can't say enough good things about it. It was worth every penny that I spent on it.
1. You CAN pick your FM presets directly if you have NAV. Push the AUDIO button and the NAV screen brings up buttons you can push. Personally, I don't mind scrolling through the presets (six at a time) myself with the controls on the steering column.
2. If you don't want your NAV screen to go to "night" setting automatically, go to the set up screen and change it to always stay on the setting you want. I find the need for three settings personally: day, night and rainy day when I have my headlights on. On rainy days, I just alter the brightness with the black twist knob on the dash, go all the way up to override the NAV preset, then back down a few clicks to return to NAV presets. Works well.
3. The car does remind you if you have your headlights on by beeping at you if you open the door with them on. Of course, you can ignore this and the lights go off automatically.
4. In addition to the yellow low-fuel light on the dash, go to the Trip Computer with NAV to find out "exactly" how many more miles you can drive before you run out of gas. I put "exactly" in quotation marks because I haven't and don't plan to put it to the test--but I did get down to about 30 miles on one tank.
I love the trip computer, though it does a fair amount of rounding off so the average fuel economy is slightly optimistic....maybe. On the other hand, comparing odometer miles to gallons put into the tank isn't exact either, but calculations made that way are as a rule 1-2 miles per gallon "worse" than the trip computer. Nonetheless, I'm happy with 24.5-26.5 average mileage with normal driving and 30+ highway.
5. I don't like the HID headlights because of the issue with oncoming drivers and because it is a propagation of a myth--that we have to eliminate nighttime with ludicrously bright lights in the name of 'safety.' In fact, glare and the excess contrast between what is and isn't illuminated by bright lights (HID, gas stations, etc.) is more of a problem than if all headlights illuminated moderately. If you let your eyes become accustomed to a level of light, you will see fine. I'm going to ask Acura service at my next (first) oil change to tilt the headlights a little lower so they are less likely to blind oncoming drivers on uneven roads. When I grew up, headlights were for more for letting other people know you were there, not for providing more light than in an operating room. : (
I like the car VERY impressed with the i-VTEC and I may be having to move away from my V6 need in my next car purchase..
so you does the screen come on to control the heating/AC?? or is it off and you are left with only the manual controls??
in your opinion and anybody's opinion for that matter, is the Nav system a pain or is it good, is it a pain to try to use the stereo and the nav and climate control all from the same screen??? or is it make it nicer to use??
thanks for your time
I am definitely biased in that I wouldn't buy a car without a Nav system, but I don't think the use of the screen gets in the way. I had a loaner TSX without the Nav system and was not impressed with the standard dash setup. You don't need to use the screen for most audio functions, either. The small LED that is a clock on non-Nav models shows a great deal more information if you have the NAV system (even if the Nav screen is off).
But I strongly suggest you visit a dealer and ask to see/play with both Nav and non-Navi models so you can decide what you prefer...
What i'd like to do is put a Pioneer or kenwood Navi in it, or maybe get one of those magellan GPS's and put it in.
Anyone done anytihng like this? If so, how did it work out? Any siggestions?
On the way toward my home, I deviated to a twisty road in the opposite direction of my home and, on every crossroad we passed, the system voice interjected, "Make a U-Turn". I couldn't find a way to cancel the set destination, so the drive proved both annoying and frustrating as I punched the Nav buttons w/o effect...
I've got to believe that I've missed something obvious in the manual, but remain clueless... How do I QUICKLY cancel a Nav destination?
Please have pity on a TSX newbee...
chase53
I'd take the time to read the manual or at least play with the nav and voice command while you aren't driving. It does a TON of things. I love that you can tell it what temperature you want the car at, even though your hand is like 2 feet from the temp up/down button!
Thanks~
If I do a category search by type of restaurant, that usually finds close matches, but if I enter a search by a place name, it finds places far away.
-Cj
-Cj
Anyway, I have a RAZR phone that works well with the Nav system, but is there a way to use name dialing? I have only been able to make a call by either manually selecting a listing in the address book in the Navi system, or by vocally saying the number. Can I, for instance, say, "Call Bob" ? If I have that number stored in my phone as Bob ?
I'd love to know the solution...
Also, there is no real-time traffic option on any TSX. The closest equivalent would be subscribing to XM and listening to their traffic channels, which are for major metro areas.
Thank 4 any info
:shades:
