At this point, I'd say simply to drain and refill your transmission's fluid, if it's never been done before. But do not have it flushed, and don't go back to the shop that said it has to be rebuilt. It sounds like they have $$$ signs in their eyes!
replaced and very unusual for it to happen. January 28th 2011, my son drove my Camry from South Carolina to Pittsburg, PA. Just as he arrived at Pittsburg, the transmission started slipping. Next day on the way to the dealership, the car just stopped in the middle of a very busy street. So....this is now transmission 2 fried and 3rd transmission to my car. The Car has 52,000 MILES! My son is stranded in PA. I call Toyota Corp and ended up screaming at the idot on the other end. They are acting as though I am having my muffler changed instead
of 2 freaking transmissions in 52,000. I own two small businesses and would never treat my customers this way. The dealer that just replaced the 2nd transmission cannot tell me why
the transmission failed. I argued that at this point it is clear that it's not the transmission stupid, it's the CAR. I believe there is a problem being sent by the computer to the transmission that is incorrect. The service manager told me that when they connected the car to the computer that he had never seen so many codes on the screen. I asked howmany transmissions he had replaced at his shop and he told me this was the first. Looks like Iam in the market for an attorney....this is just plain wrong.
If you aren't sure, you can lockout the overdrive I believe with the "hold" button and then test to see if the transmission still does this.
Certainly, checking the fluid level of the transmission is the first step.
It's important for you to dial in your diagnosis and determine whether it is only in overdrive that it drops out.
Toyota transmissions are perhaps the most durable in the entire world market place.
If you can, sit him down, and explain to him exactly how to operate the transmission, and tell him that the next time it happens, that you will not pay for it, but that he must.
Stop throwing your good money at your sons problems.
The noise rises with engine/transmission speed, then falls as the shift is made, rises again in 2nd until the next shift, and then disappears. Shifts are smooth. From a cold start in the morning, the noise does not appear until the car has gone what is probably enough distance for the tranny to heat up. It almost sounds like a high-bypass airplane turbine whine, though the frequency sounds a bit higher, and obviously the decibel level is lower!
Does anyone have any thoughts? Am I perhaps imagining a problem that isn't there?
thank you.
I took my car to a transmission shop and the technician told me that there is probably something wrong with one or more of the solenoids, which I figured as much. But even without looking at the car or test driving it, he told me that based on the high mileage (235k miles) just replacing the solenoids would at best be a very temporary fix as the reason things are getting plugged in there is because parts of the clutch, gaskets, etc are starting to disintegrate. So, his recommendation is to rebuild the transmission.
On the surface his explanation seems to make sense. On the other hand, I have purchased this car new, most of my driving is on the highway and I never push the car hard at all and have changed transmission fluids at the recommended intervals. Is this technician telling me the truth (he is just basing his recommendation of rebuilding the tranny based on mileage, have not seen or driven the car) or is it possible that a transmission with over 200k miles can still be perfectly good, if driven smoothly? Also he gave me two quotes: one using non-OEM parts w/ a 2-yr unlimited miles warranty and the second using OEM parts w/ a 3-yr unlimited mileage warranty and the difference in price is about $1000 ($1,800 vs. $2,800). I know you get what you pay for, but $1,000 is a big difference, but not sure if I should skimp on something like a transmission. Any recommendations? Thanks for your feedback.
Joon
