Toyota Camry Suspension Questions
I have 113,000mi. Thinking about replacing the struts. Do you think I should replace the front only? Or would I notice a big difference replacing the rear also. Also would the KYB GR-2 give a stiffer ride compared to genuine Toyota replacements?
I have a 97 with 103K miles, no leak from the struts and didn't really give me a reason why I should replace them.
Unless you want a stiffer ride? If you decided to replace them, I think you should replace them all (4). Please let us know the outcome too.
Do you think new struts would help?
i don't know if a new set of struts will help when riding with 4-5 adults but it probably might help.
I just notice this morning when I made a big loop turn to get into the freeway ramp, my 97 felt a little lose and bumpy. lot's of body roll. I should chk my struts too, I guess :-)
If any tire has unusual wear, that's the sign of bad struts. The shop can inspect and determine which struts are bad and need replacement, usually by finding oil leaks.
Bad struts can cause loss control of cars in emergency lane changes or tight turns, esp. in FWD cars. Can be very dangerous.
New struts prevents unusual tire wear and improve both tire and gas mileage. Some brands offer lifetime warranty.
Do you know if the KYB GR-2 gives a much stiffer ride compared to genuine Toyota replacements? I think it would be best if I tried to match the original ride quality. What would you recommend?
If there is no leak, the struts should work OK.
You should not rely on your feels to determine whether the struts are working properly or not. Chances are you cannot feel it. You should rely on hard evidences, such as oil leaks or unusual tire wear patterns, i.e. scalloping or feathering etc...
I has 2 bad front struts that wore out tires prematurely but the ride was OK. When replaced with new Japanese gas struts with lifetime warr (forgot the brand), I felt no difference in the ride and handling of the car, but the tires stopped wearing unevenly and made less noise.
With the bad struts, I got into a very scary loss of control of the car on freeway when I did a quick lane change to avoid merging traffic while cruising at about 65MPH. The car wobbled very hard from left to right and careened on 2 highway lane for about 30 sec. I really thought it would roll over. Luckily there was no traffic at night or I would have wiped out many cars, or crushed in a big multi-car accident. I am not easily scared but was very scared in that incident.
Dealer said bad struts are known for causing lateral instability in FWD cars.
I have 2001 Solara with new KYB struts with old mounts, and there was struts rubber fiction noise coming from the back. I replaced it, and problem is gone.
Now the front strut mounts are giving me problem.
I have 215 55 16 tires not OEM 205 60 16 with 4 KYB GR2 struts. It handles good, and ride good with Michelin Pilot.
Most European & Japanese touring (coupe)cars have 55 aspect ratio, and there's more tire options.
For those who replaced their struts, I want to know the general cost for parts and labor so I or others can get an idea about the cost.
Can struts for a 2003 Toyota Solara SLEv6 be replaced by a "normal" guy like me, or will I need any special tools?
You do need to have special tool to compress the spring so you can remove/install the struts.
Loosen the top nuts can be difficult too because they are very tight.
For me, I ended up returning the struts to the store and went to SEARS auto center to get that job done.
I would not recomment replacing struts yourself.
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vert- ical=TOOL&pid=00947057000
It isn't really all that hard to change these, but you've gotta obey the tool instructions to the letter because you are dealing with a massively powerful coil spring, and if the tool isnt clamped right and the spring comes loose it'll half-kill ya. No need to be afraid of it as long as you are careful and not rushed though!
And remember you will almost certainly need a wheel alignment after changing the struts (I could be wrong about this though, never done it on that kind of car)
My car has approximately 60k on it.
Is there anyway I can find out if the car has undergone 60K servicing?
Also what are the things to be taken care of in a 60K servicing for a Toyota Camry LE.
All answers will be highly appreciated.
I don't think you can tell whether your car has a 60K miles service or not by just looking at it. But I will assume it didn't have one otherwise, I think the dealer who sold you the car would use it as a selling point to make this car more valuable to you. Don't you think so?
$300 for a 60K service, I WILL NOT go to MIDAS. Just had some bad experience myself. I took my car to TOYOTA dealer and it's about the same price, maybe a less more. BUT I will not take it to Kirkland because it's over price in my opinion. The one in Everett is very good, service manager will not ask you to do this or do that. I have 2 TOYOTA myself and been to both dealership, by far, the one in Everett is way better.
For 60K miles, you should have your cooling flush, replace transmission fluid and air fliter.
When the oil is BLACK it show POOR vehicle maintance. I agree with MIDAS. It is ovious that you did not get the vehicle past history, so the 60K is RECOMMENDED.
I had a 60K on my 1992 Camry. My car has 185,100 and I have NOT done a major service. I will do a mayor service when it reaches 200,000 miles.
:shades:
I bought a used 1998 Camry with 85000 miles. The front struts , had a clanking noise, so I had them replaced the brand was Monroe Sensamatic.
But still when I pass over bumps or , passing over man holes etc on the road, I hear a small clanking noise. When I took it back to the mechanic who replaced the struts he says its normal, but I have a gut feeling that the noise shouldnt come. I had a Corolla before this and was 5 yrs old, it didnt give any noise.
So I would like have your advice what can be done t fix the issue.
Although I don't own a Camry, in general it sounds like you need sway bar bushings. Many of the people at Midas, only know about installing struts, and brake pads. Unfortunately, they probably won't be able to help you with this.
Frank.
is strut replacement on a '97 Camry a reasonable DIY job?
HAS ANYONE REPLACED THE SE SUSPENSION WITH THE XLE, OR LE BEFORE? I KNOW THE XLE VERSIONS HAVE A SOFTER RIDE.
It would probably be cheaper to get another (used) Camry at this point than replacing the suspension. The SE is designed to have a stiffer ride, so it sounds as though you should have gotten the LE or XLE originally.
If your car is in great condition, you shouldn't have any difficulty selling it since SE models are relatively rare.
Anyone with experience with this and where I might find a lower fee to fix?
I started to notice a strange clanking/squeek noise from the from suspensions of my 1998 Camry which has 78K miles on it. This is more significant if I drive over speed bumps, but it is not there all the time. The guy at the local Firestone suggested that I might need new Struts and strut mounts. He also said that this is a big problem with the '98 Camrys and that the problem develops around 60-80K miles. What do you all think? Thanks.
Mike
IS IT SAFE to leave the car in its present condition? :confuse: Can I just live with the rattle and drive on, or is there some risk in doing that? It seems a shame to throw $800 into a car that is neary 10 years old for asthetic reasons.. but I whouldn't hesitate for safety reasons. Aside from that (and a few past issues) I really like the car.
So... after writing my post, I went back and read an earlier post on suspension issues which said that 1) they had their front strut mounts replace 2) it still made noise and 3) they just needed to tighten the nut on top to eliminate the noise... mentioned that you lift the hood and "bounce" the front of the car and look at the front suspension mounting nuts... they shouldn't move.
Well.. I did that check on mine, and they moved a little.. not much... and it turns out that the nut is the same size as the wheel lug nut... and I happen to have a torque wrench... so I simply tightened the nuts about 1/4 turn on each side and did the bounce test... I didn't see any movement.
So... I jumped in the car and backed out the driveway.. and when it went over the driveway lip... just the bump bump of the tires... no rattle... and when I drove over the manhole covers... just the bump of the tires.. no rattle.. over the jostly bumpy street... (driving slower so I can hear)... no rattle...
Hmm.... did I fix it????? We'll see. I'll post again tomorrow after starting out cold in the morning.. and after starting out at work (covered parking lot) where I seem to hear it the most... I'll let you know.
I'm keeping my fingers crossed... :shades: Wish me luck.
It's apparently fixed... I have a 15 mile drive to work and 15 miles back... rough highway, bumpy city streets, etc.. and when in the covered parking lot at work (where I could hear it the loudest) it was perfectly silent. Drove all the way home and not a single rattle...
SO... it appears that folks can elminate the strut mount rattle (or how ever you classify the noise).. just need a deep socket that fits (same as the lug nuts) and a socket wrench with a long handle (my torque wrench is about 20 inches long.) I barely turned it.. maybe a quarter turn.. just enough reduce the movement...
NOTE... I am not a professional car repair guy.. just someone who doesn't like to blow a lot of money on needless repairs... There is no guarantee that what I did will be a long lasting fix (although you can bet that if it rattles again in a year or so, I'll try another quarter turn.)
Good luck all!!
A few days later and no rattle. And this is after having the problem for two years. I've been thinking, and it appears that Camry's and possibly Avalons can have a suspension rattle that can be easily fixed as I have done above. I'll come back in a month or so and report on whether the minor adjustment fixed it. It would be great if folks could resolve the problem without having to replace the upper strut mounts... after all, I just barely tightened the nut, and the problem has completely disappeared. I couldn't be more pleased!
Really annoying. I guess I can try tightening the nuts you guys are talking about. So..where the heck are they?
Then, I noticed that the noise was still there, but different and sometimes worse. Brought it back to the shop, they said it was normal.
A week goes by, the raddling, banging noise was worse. I made my manager friend sit with me for a short drive. He brought it back and called me personally and told me that my right stabilization link was loose and that I needed Strut Mounts and might as well change my struts as well. Additional cost: $490.95 + Tax.
Well, its been 11 days and my car drives like new. Well, with the discount that my friend gave me, I still spent a total of $826.35 for the suspension problems. :confuse:
Thats a hefty expense for some annoying noise. But I am glad it seemed to be fixed finally.
Mike
