-June 2024 Special Lease Deals-
Toyota Camry Audio Questions
Anyone know the difference between the premium JBL system offered and the '03 Camry LE V-6 and the standard system -- excluding the cd changer option?? Power?? Sound?? Speakers?? Appearance??
Thanks ---<Rick
Thanks ---<Rick
Does anyone know of an after market CD Changer (six disc) that will work with my 03 Camry navigation head unit. I do not want to use the FM modulation type or pay for a dealer's model, normally they are aftermaket any way with the Toyota name on them. Does any one know of such an item?
I think most aftermarkets can be mounted into the car, under one condition. A mounting gear is needed. Because the factory audio unit is huge compared to aftermarkets, you need a mounting gear to hold the faceplate in place. The aftermarket shops will tell you the specific mounting gear you need for particular controllers/faceplate.
I am not sure, however, if you can keep the factory audio unit as a controller to control aftermarket CD Changers. But as you said, the Toyota so-called factory systems are actually aftermarkets with their name on it. So you might want to ask the shops (not Toyota because they probably want you to buy the factory Changer from them!) if you can do it that way.
Good luck in finding the right system!
Does anyone have any information or success story on replacing a 2004 Solara stereo? I want to get a regular DIN MP3 stereo in there in a bad way. FM Modulators are too much of a pain.
Solara really missed the boat on the enormous stereo panel, lack of xm, and lack of auxiliary inputs.
I have a white 2004 SE 4cyl stick without a roof. This is a very impressive car for the money.
Thank you,
If you have the nav unit, you can still do some cool stuff, but shoot me over an email and I'll give you more information.
Scott
And for the person who wanted to get keyless entry: Try an after-market alarm system. It shouldn't cost more than $275 installed and will give you keyless entry as well as an alarm with rocker detector, glass detector, panic button, remote trunk release, etc. You'd be getting something more than just keyless entry.
First, disconnect the negative cable from the battery. This will ensure you don't have an encounter with "Mr. Air Bag."
Use a thin screwdriver tip with masking tape over it and remove the plastic cover plate surrounding the center console of your current head unit (the factory stereo.)
Once that is off, you can see the mounting screws that need to be removed to pull the unit out. You will likely need to adapt your factory wiring harness to your new head unit. I simply used the existing wiring by cutting off the old harness and splicing the new harness (that comes with your new stereo) to match the power, speakers, and ground.
Get a Haynes or Chilton manual for Camry's and it will provide the factory color code for speaker wires. It's a good $15 investment for many items.
stan1223 - I would check out Crutchfield online as well. They have nav systems to fit your car from $400-$2500.
I just wired up a 12" sub and a small amp this weekend. Just a little something to supplement my 2000 Solara LE non JBL stereo. Had it installed in under an hour. I'm thinking of putting a set of Lexus IS 300 rims on my Solara. Anyone have any experience with this besides cam2003 (post 123) ?
Good or bad?
The subwoofer available is only for 6-speaker systems (per his manuals). Hope this helps.
I cooled off on the dealer-installed subwoofer; how do you find the infinity system?? does it need more punch??
BTW, my 17 year old who is inheriting my wife's '99 v6 Passat just had an impressive subwoofer, amplifier, another amplifier and new front speakers installed for $1k!! (yes, he's a big shot). My wife liked the sound, and I'm afraid there will be pressure to do something similar in the new Camry!
Anyway, enjoy your beautiful new car!(is it the v6?; do you love it)?
Has anyone sucessfully replaced the stereo system??
Anyone replaced these with good results? Thanks.
Here is what I know so far:
1. Front door speakers are 6 X 9 BUT only 1.653 inches deep (per my conversation with the crutchfield guy). I don’t think I will be able to find replacement speakers with these specifications.
2. Rear Speakers are also 6 X 9. Crutchfield guy told me that I might have to remove the seat to access/ change these speakers, and might have to improvise a little to make after-market speakers fit.
3. The head unit is a double DIN unit (see picture in page 8 of the above link), and I guess after-market housings are available to fit a single DIN unit (I already have one from my last car) in the space provided. Crutchfield sells them for $20.
Here are my questions-
1. Where can I find the replacement front door speakers? I am thinking that I might have to go with 5 1/2 speakers to fit them in 1.653 inch depth. Might have to improvice a little to fit 5 1/2 speakers in 6 X 9 speaker opening.
2. I am pretty sure I will lose the steering wheel mounted controls. Any way to reatin their functionality? One option would be to install an external amp, then the question would be - is there a way to get line-out from the factory head unit (I am guessing- NO). I have seen amps with 'speaker level inputs' i.e. they take their input from the speaker output from the factory head unit, but I have also read that that kills the sound quality. Anyone had any experiences with 'speaker level inputs' ?
Any comments/ suggestions will be greatly appreciated. Thanks.
I found few instructions for removing rear speakers but I have done it yet. If you are going to do it, take pictures and post them. Good luck!
Rear Speaker Assy REPLACEMENT
REMOVE REAR SEAT CUSHION ASSY
REMOVE REAR SIDE SEAT BACK ASSY RH(TMC MADE)
REMOVE REAR SIDE SEAT BACK ASSY LH(TMC MADE)
REMOVE REAR SIDE SEAT BACK ASSY RH(TMMK MADE)
REMOVE REAR SIDE SEAT BACK ASSY LH(TMMK MADE)
REMOVE REAR SEAT BACK ASSY RH
REMOVE REAR SEAT BACK ASSY LH
REMOVE ROOF SIDE GARNISH INNER RH(W/O CURTAIN SHIELD AIR BAG)
REMOVE ROOF SIDE GARNISH INNER LH(W/O CURTAIN SHIELD AIR BAG)
REMOVE ROOF SIDE GARNISH INNER RH(W/ CURTAIN SHIELD AIR BAG)
REMOVE ROOF SIDE GARNISH INNER LH(W/ CURTAIN SHIELD AIR BAG)
REMOVE ROOM PARTITION BOARD ASSY(TMMK MADE)
REMOVE REAR SEAT SHOULDER BELT COVER RH
REMOVE PACKAGE TRAY TRIM PANEL ASSY(TMC MADE)
Pull the package tray trim panel assy upward to disengage 4 clips.
Put the bezel and anchor part of the seat belt through the slit part.
Pull it as shown in the illustration to disengage 5 claws.
REMOVE ROOM PARTITION BOARD LH(TMC MADE)
Disengage 4 clips and remove the room partition board LH.
REMOVE ROOM PARTITION BOARD RH(TMC MADE)
Disengage 4 clips and remove the room partition board RH
REMOVE REAR SPEAKER ASSY
Disconnect the connector.
Remove the 4 screws and rear speaker assy
INSTALL REAR SPEAKER ASSY
Install the rear speaker assy with the 4 screws.
tips for removing the OEM unit?
Is the Metra 99-8203
or American International TOY-K979 the better kits?
Did you every find out about removing the JBL radio deck? I'm got a 2001 Carmy collector's edition and would like to remove the radio as well. Any help would be appreciated...
Jim
start from the cup holder, just pop it up and move toward the front.
it's very easy, no tool required.
That whole piece can be pull out so you can see the stereo. Just unscrew it.
What did you decide to do to your Camry?
What head unit did you go with and what were you able to fdo about the speakers?
thanks!
I have a 2003 LE V6 Auto with Standard (Non-JBL) Stereo and I upgraded to a JVC head unit and a 12" Pioneer Sub with a Pyle Amp.
One of these days, I gonna shatter the back glass !
But it sure gets some attention !
Good luck
My set up before consisted of an amp and a subwoofer, while still using the jbl head unit. I used a high-to-low converter which tapped into the front left/right channels. The stock JBL amplifier is mounted vertically behind the glove box. The output (speaker-level) is the thicker set of wires. That will give you a set of RCA pre-amp-level signal outputs (left/right). Then I ran an RCA cable (16 ft, which might be a little too long) from the high-to-low converter to the trunk and connected it to the amplifier. To power the amplifier, you will probably want to get an amp power kit which is readily available at best buy, circuit city, crutchfield, etc. I can post some pictures if you're still figuring out how to set it up.
I just purchased a 1997 Camry XLE and the front door speakers need to be replaced. How difficult a job is this? Does the entire door panel need to be removed or just the lower panel? Should I replace with OEM speakers or purchase an aftermarket set? If so, any recommendations? Any assistance would be appreciated.
RLJ50
I would buy aftermarket speakers. For the money you will get a better product.
Jayme
Thanks for the response. If I purchase a set of speakers from Circuit City, for example, will I need a special speaker adapter that fits these speakers in order for them to fit on the door and will I need a special speaker wire connector to connect the new speakers to the Camry's OEM speaker wire connector.
RLJ
You probably won't need an adapter for the front speakers to mount them, and probably not for the speaker wire connector either. Try using the websites for Circuit City or Crutchfield, etc. to see what sizes will fit your camry. I know from expirence with calling Crutchfield, their reps will tell you what you would need to do your particular install. I assume Circuit City, Best Buy will do this as well. Just make sure you get the install sheet to properly remove the panels and you will be pleased.
Jayme
I've done some searches but have come up empty thus far. My 2005 Camry LE once played 80 min CD-Rs I had burned using high quality CD-Rs (TDK). Recently, it now won't play them without starting to skip and blip around the middle to end of the CD-R. Has anyone else had this problem? The car is almost 1 year old.
I specifically bought the vehicle with the CD player knowing it could play my CD-Rs, but now that's no longer the case. It's not a question of new CD-Rs either. Ones that used to work now no longer do and its across the board. Normal CDs still play though. I've looked into replacing my CD player with a JVC one that supposedly plays CD-Rs, but I'm really used to the controls on the steering wheel and have been told they can't install a new CD player and maintain that, which is a big negative that has me second guessing doing that.
Does Toyota sell a player for the Camry that will play CD-Rs guaranteed that keep the same wheel controls or should I call them to get a replacement unit. As best I can tell, I have L17146 installed.
Thanks in advance for any advise/experiences.
After buying the vehicle, I found the manual for the Camry does state that CD-Rs and CD-RWs, etc may not play in the CD player. Guess I found that just happens "with time" in my particular circumstance. Sounds like real player that claims it can play CD-Rs is the way to go, though I would love to hold onto the wheel controls to the system I have now as I'm quite used to using that for volume, mode, and track control with both hands on the wheel.
Thanks! :shades:
I tried looking for the antenna, but can't find it. I've heard that Toyota mounts this on the rear window package by the rear window stoplight, but I don't see it. Maybe it gets installed elsewhere when you have a navigation system?
Anyhow, I can't believe my listening experience is normal or XM would be losing customers left & right. If anyone has any ideas, let me know.
Mitch
On the other mobile applications (all with the XM Roady 2), the small antenna requires that it be mounted on a metal surface for proper reception. All work perfectly.
I share your concern as I have a V6SE w/ NAV & XM ordered. It's due to be built the first week of June. I've read several posts about "iffy" reception in new Camrys. I did see one installation w/ the antenna on the package shelf (looked like the stock XM antenna that is supposed to be mounted on a metal surface). On another Camry (on a dealer's lot), the car had NAV, but I couldn't find the antenna.
We need to get to the bottom of this.
However, there are XM antennas made especially for mounting on fiberglass or other non-metallic bases -- these antennas are typically used for marine (fiberglass boats) and fiberglass RV applications.
So, I have found kits two different places.
here and here
I am fairly handy, should I try this at home?
