What are the best V8 engines ever made?
1356710
  • nrd525nrd525 Member Posts: 109
    He was the NHRA champion that year,as usual back
    then.
    I kind of think the owners of some of these cars baby them,or detune them for better streetability,and it makes them run slower than they should.
    There was a guy that ran at the track with a Buick GS that ran in the high 13's without headers,just screwing with the carb,dual exhaust,timing etc.His rear end didn't last long though,but that thing was strong,it ran 14.20's right off the showroom floor,spinning the hell out of the 70 series tires.
    As far as the GNs and T-types:
    It wasn't the Buick V6 engine itself,that was so good,it was the turbo attached to it!.The 4.3 they put in the T/As,Syclones and Typhoons were better yet!I wanted a Typhoon bad,my neighbors son had one,and I got to drive it once.There's a nearby 1/4 mile "finish line" painted on the road where the Belvedere blew the motor.The city keeps trying to remove it,but it somehow keeps reappearing!I ran that Typhoon on it,and I'm guessing it was about a 13.8-14 flat.Fast enough for a stock Jimmy!
    But in an F body,as far as I'm concerned,the choice comes down to two,a 454 Chevy,or a 455 SD Pontiac.If money doesn't matter,I would take the SD,if money is a concern,then the 454,parts are cheaper,and a lot more plentiful.But the SD was more impressive to me.But then,the 400 with the 6-71 I rode in was pretty good too!
  • captaincarlcaptaincarl Member Posts: 21
    Back in '86 and '87 when the GN/T-type came out, I was impressed with the times they turned at the track. But on the street, I was able to beat several of them with a 5 liter Mustang LX that ran a best of 14.6 in the 1/4. I have a theory as to why. I live in Arizona, so I wonder if the 3.8 turbo had knock detection. If so, the hot weather here might cause the engine mngm't system to dial back spark advance or boost, causing it to run weaker. At the track, better gas could be used, allowing more boost/advance. Can someone out there let me know if my guess is close?
    In '87, Buick made about 500 special GNs, called GNX's. The press test car ran low 13s, and had an advertised 300 net horsepower. But at the local track, I heard production examples were actually slower than the regular GN/T-type. The only one I personally saw ran 14.2s. I never saw a real road test of one, just the promo runs with a Buick driver in the pre-production GNX, at Milan on a very cold day...not exactly a typical test environment. Given the improved hardware in the GNX, I'd expect a performance improvement, so what gives?
  • modvptnlmodvptnl Member Posts: 1,352
    I was using current times the modified Regals are running at the track. There's actually a Mustang Vs Turbo Buick showdown every year with the Buicks holding their own. Maybe they weren't such a terror stock? I still think they are one of the ultimate Q cars.....fast without being flashy. Another reason I liked the Buick V6 was before Indy went to "spec" engines the V6 was the only other stock block motor to run at Indy(although it didn't stay together very long usually, it was fast.) along with the Ford small block years ago. Again racing history means a lot to me on this list.
  • chris396chris396 Member Posts: 53
    Those Buick's are just amazing. With a few very minor modifications you can run a GN in the 12's.
  • moparmadmoparmad Member Posts: 197
    When I posed this question I wasn't too worried about history and legend.I think alot of very good points have been given by all.Being a Mopar guy(obviously) I would like to defend the small block LA Mopars,by saying that they have stood the test of time being nearly unchanged in their approximately 35 years of existance.As for power potential the 323 cube(318+.30)smallblock in my 70 Cuda dyno'd at 343 horsepower.I have about $1100 into the motor,and strongly feel most any engine can produce power with the proper balance of parts.
    That being said I guess that my main requisites for this list would be factory power,balanced with long term dependability.
    As for the Chrysler Hemi I think it is safe to assume that no engine recieves the kind of reputation it has without being able to back it up in some manner.
    Finally the biggest thing that impresses my with all muscle cars is the fact that they could run in the 13's or 14's(depending on which magazine writer you believe)with skinny little bias ply tires that produce less grip than the tires on your boat trailer.Couple that with the fact that most manufacturers made a couple of trannies that serviced all of the cars they made,not tuned to the engines they were hooked to,and the standards shifted about like a modern dump truck,and you realize that these engines had alot of high hurtles to conquer compared to your modern day cars.This fact alone makes any old high performance V8 a winner in my book.You just cant beat the sound of a real vintage american V8,the rumble,the vibration and the mechanical presence is music to my soul.
    Thanks for posting everyone.
  • carnut4carnut4 Member Posts: 574
    I agree that the small block Mopars deserve a lot more credit than they've had. I've had a couple myself, and they were both bullet proof as well as producing good power/gas mileage for their size. And that sound-I remember that 340 motor in the light Darts and Valiants. With a Torqueflite and some tuning, these were dynamite.
  • sharkskinsharkskin Member Posts: 11
    400 Big Blocks! Back in the day those Ram Airs were hot. Can't find a clean one today. The best I did was a 78 Trans Am with 400 T/A engine. Its a smogger with the best passing time of 15.2 in the quarter (cars loaded). Fortunately back in the mid 80's a good buddy of mine was also a Pontiac Freak and he purchased a 71 T/A and then a 71 GTO. The Goat is still around and has been worked to the point that in now runs in the 12's. As for the list of best engines.....too many to list. I love all the old pre-smog era engines. My daily beater is a 73 olds with a tired 350 rocket. The engine doesn't smoke and it still has a nice rumble to it. Granted it wasn't a tire smoker new but still those old engines were a breeze to work on and with a little help from the after-market you could turn a 350 Nova into a Blvd burner. Nice to see people still talk'en about the great ones. I was getting tired of listing to all those owners of rice burners brag about their turbo charged, fuel injected 1.8l engines. Its just not the same!
    Amen...brother!
  • denniswadedenniswade Member Posts: 362
    Yeah, there's so substitute for cubic inches (or torque, which is based on cubic inches). I like both, for different reasons. But a tired old V8 will definitely smoke a tired old 4-banger!
    Dunno if anybody's mentioned the Buick V8s. Their 350 was about 100# lighter than the Chevy, and their 455 was about 150# lighter than the 454. They're good engines, very stout and easy to work on. The Caddy 472 is another alternative to the 454, and is more compact. There are also plentyof hop-up parts for it now, and most haven't been beat on the way the Chevies were.
    There really IS a substitute for cubic inches, but it's usually EXPENSIVE!
    Amen to that!!
  • stickguystickguy Member Posts: 53,470
    I know this is the classics topic, and I am ducking, but it souldn't be hard to argue that some of the current V-8s are the best ever. Not just US (ie the Ford modular or current Chevy small block), but some of the European/Japanese engines. Look what BMW does with a 4-litre in the 540 (even worse is the M5). And Nissan is supposed to be plopping a 350HP V8 in the next Q45 with just as much torque. Couple the brute force with civility (and even reasonable mileage) and you get quite a package. Even the Northstar is quite a package
    I know, not cheap and loaded with high tech gadgets but you can still get a nice rumble with the right exhaust system.
    And how about a tweaked Northstar in the current malibu to give the old Nova SS a run for it's money (not to mention a record amount of torque steer).
    Will only set you back $7k. That's a lot of environmentally friendly, low maintenance bang for the buck! I'll take that Nova in Midnight Blue with the black interior! Bad Asssssss!!!!
    Some of the new V8's will undoubtedly make a best ever list of mine someday.But right now they all lack history.No way to prove thier durability,will they still be rebuildable in another thirty years?Maybe...maybe not,time will tell.
    I don't think many of the new cars will be restored, what with all the formed plastic and worse yet, the computer boards and sensors which will be horribly obsolete soon enough. Ever try to get parts for an 8-track tape deck or an Apple IIe computer? I'm not so sure vendors will be burning new ECUs for "old" Chevies 25 years from now. Of course, perhaps there would be ways to get a 2001 Corvette engine running again, but I don't think in "stock" form.
    they'll make parts for it. The aftermarket BEGS for opportunities like that. Look at all the stuff available for classic Fords -- you can build your own out of brand-new parts! People always seem to think that everything is gonna get so advanced a few years down the road it'll make everything else obsolete. But we STILL ain't flying to work in our gyro-cars, are we?
    Yes, but I can't see it being cost effective to re-create boards for each different car...that is very expensive technology, and the cars themselves are not going to be worth that much since they are not very rare for the most part.
    flipping through the catalogs for a new rear-deck spoiler for that 20 year old Geo!! And all those aftermarket speed parts [and rust treatments] for the "classic" Honda Civics!
    Oh, darn, I'll probably still be alive in 20 years.
    Obnoxious title: "The Hemi Cuda/Challenger Was a Joke"
    Don't get me wrong, these cars were fast, and they looked awesome. But they were a ripoff; you could do better with your money. If you take a look at some of the road test from that time, they handled terrible. That Hemi weighed over 700 pounds, and there wasn't much car behind the rear wheels to balance it out. And those Mopar E-bodies were porkers, weighing 200-300 pounds more than a big block '70 stang or camaro. For the money, I think a Mopar man would do much better with a Road Runner. A Hemi RR in the post coupe body would only weigh about 100 pounds more, and have much more weight over the rear wheels. It would have a less restrictive exhaust system, a usable back seat, and a huge trunk, too. Road tests bear me out; the 1/4 mile times for the E-body Hemis were no better than those for B body Hemis. And the handling of B body cars was often praised by the testers. And no, you can't bring up that 13.1 time that HotRod/CarCraft got from a Hemi Cuda, they tweaked it, as they did to many of their test cars.
    So what do you think, was the Hemi Cuda/Challenger a dud?
  • zinheadzinhead Member Posts: 4
    Personally, among American makes I am a Ford man, Mustangs in particular. But Boss 429 be damned, there is no greater muscle car than a Hemi Cuda. So what if the thing overheated at every stop light. So what if the front end was so overwieght it would plow any and every guard rail. So what if the stock engine was so undertuned a 383 would beat it in a 1/4 mile. You had a 426 c.i. Hemi which was the pinnacle of American V8 engineering (ignoring the Ford 428 SOHC).
    Besides, the Hemi Cuda was available in purple and other day-glo colors. Try that with your Boss 429 or SS 396.
    That would be a 427 SOHC.
  • mjc440mjc440 Member Posts: 76
    I agree with all that said that the HEMI was one of the best V-8 s of all time, however, aren't we forgetting the 413 and 426 Max Wedges?
    These engines were in light Belvederes and Coronets (B-bodies), and this made these cars extremely fast. A friend of mine has a factory 426 Max Wedge '63 Plymouth Belvedere hardtop (black with red interior and pushbutton automatic). It's hard to believe this car came with factory headers with factory 3 inch exhaust with factory cut-outs. The crossram intake is also exotic, with one 4 barrel carburetor in one corner and another way in the other corner. This car is also supposed to have a 14.5 to 1 compression ratio from the factory. (I think its a Stage III)
    Anyway, I thought that these engines should be mentioned due to their racing heritage as well as having two Beach Boys songs about them (Little Old Lady From Pasadena and Shutdown (even though the fuelie 327 beats the 413 in the song - I doubt it would happen in real life))
    Does he ever drive it? Have you ridden in it? What a ride!
    I remember a magazine article about a Max that came in an odd car. It seems an elderly couple came into a Dodge dealership wanting a tow vehicle for their travel trailer. I guess the saleman didn't know of the poor low end torque that comes with a Max Wedge, so they ordered their STATION WAGON with the most powerful engine on the option list. Great engine, but not for towing!
    A max wedge station wagon - what a sleeper.
    I wonder how many of these station wagons are out there.
    My 70 Cuda with its 318 weighs 3119 pounds,I dont imagine a Mustang or Camaro with a smallblock weighed much less.
    One thing I find very funny is how much we car people are so hung up on how quick our cars can do the quarter.To say a car was .5 second quicker than another in the 1320 means nothing in the real world.I have spanked big blocks with my 318 Cuda,and have been spanked by V6's.I'm not John Force and most people on the road aren't either.On any given day a collection of twenty different cars could post twenty different times all with the same driver.
    I am currently building a 440 for my Cuda for two reasons: I think it will be faster,and I cant afford a Hemi.I don't plan on driving 100 mph down Main St.,USA so I'm not too concerned with the handling,I just like to have my eyeballs pressed into the sockets for a couple of seconds.
    All I can say about people who belittle the Hemi E-bodies,is they can talk all they want,but I bet most of them wouldn't turn down a Hemi E-body convertible.
    I don't think anyone would turn down a HEMI anything!
    I agree, many of those old test results are bogus. One magazine was scrupulously honest and consistent, though. Car Life was run by alot of slide rule/pocket protector engineer types who were consistent and fair in their testing methods.
    Each car was tested bone stock with a driver, a 100 pound accelerometer (that's funny, when you consider today's G-Tech a-meter does more and weighs about a pound!), and a 2nd guy to run the accelerometer. They didn't generate the impressive 1/4 mile times you could find in other mags of the day, but they were more realistic and allowed valid comparisons to other models tested by the same magazine. Unfortunately, the mag wasn't around for long.
  • mmcswmmcsw Member Posts: 29
    I probably spelled his name wrong, but this guy tested cars for Popular Mechanics Magazine until about the early '70s. I believe it was he who popularized the zero to sixty acceleration run as a benchmark for testing cars. Anyway, he was of the old school of automotive journalism, before success corrupted things.
    He was pretty funny...here are some of his quotes for you to enjoy or at least marvel at:
    http://www.pacificcoast.net/~viwpc/quotes.htm
    He wasn't always right, but he was always entertaining....he UNDERSTOOD what a critic really was supposed to be!
  • speedshiftspeedshift Member Posts: 1,598
    Car & Driver did a satire of his style around 1970. Something about him driving the test car through a ring of fire. I guess he could be pretty flamboyant. I remember a photo from one of his roadtests, I think it was a '49 Plymouth or some other sled, and he had the thing leaning over on its passenger-side doorhandle. I'm exaggerating, but only slightly.
  • 16valver16valver Member Posts: 8
    toyota and laxus 4.0l and 4.7l and lotus esprit 3.5l turbo
    What's a laxus? Is that what I take when I'm 'bound up'?
    It looks and tastes like chocolate, but...be careful!
    This isn't really on topic, but.....how about the new Chevy truck motor (2001 model year).... did a little research on it... only available as a HD emissions package on trucks with a 8600+gvw... developed from the old 7.4L (454 cid).... now displaces 8.1L (496 cid).... 340 hp/455 lb-ft....Chevy claims it out performs both the Ford and Dodge V-10's... will it fit into my wife's Tracker....
  • andy_jordanandy_jordan Member Posts: 764
    I am seriously considering a 2001 Sierra 3500 and that engine looks like somew performer - as does the new Duramax Diesel (6.6L V8)
    Yes, the big block will fit easily in your Tracker--in the back seat. How did they get that many cubes? Does it have a 5" stroke?
    According to the October 2000 issue of "Trailer Life" magazine, the stroke is 4.37" vs. 4.00" for the 454. The new engine is the same basic layout as the old, but "is more than 80 percent new".
    While it makes a decent amount of horsepower, it's a truck engine, and as such is optimized for towing--lots of torque. Chevy's over the counter 502ci engines would be much better for a Chevelle.
    Thanks for the info. Didn't know Chevy offers rat motors larger than 454 CID. I'd guess that bored/stroked factory engines offer a cheaper combination of cubes and reliability than the aftermarket, hence my comment.
    Actually, I said that kind of tongue-in-cheek. I rarely see Chevelles--or any '60s intermediates--on the road anymore, and there's no place in the Bay Area, except I guess Sears Point, to race legally. Big-block street cars are so rare these days that I can remember the last two I saw: a mint late-'60s 4-speed SS396 that I think wanted to race my GTP (would have but wife was in the car) and a '65 442.
    Your comment about torque versus horsepower reminds me of the old controversy about whether the small-port or big-port heads were better for the street. The big-port solid lifter 396 was the one to order from the factory, when they would admit it was available, but supposedly the small-port engine was more livable with aftermarket cam and carburetion.
  • sgaines1sgaines1 Member Posts: 44
    Not that I'm saying any of these are the best, but I'm infatuated with the huge old man cars, and they've all got V-8's. I'd just like an opinion on:
    Ford's 451 Cleveland (I had one, always breaking, but maybe it was me?)
    The older 460 (there's one in my '73 Mk. IV)
    Chrysler's 440 (If they put it in the Coronet, how bad could it be?)
    Cadillac's 500, and whatever big went into Buick/Olds/Pontiac's bigger cars, like an Electra, or Grandville, or 98.
    I'm thinking of getting a new old car in a few years, and this will help me decide.
    Seth
    Most of those engines were designed mainly to haul around late-'60s-early '70s land yachts and cope with early smog controls. That often meant low compression, mild cam, retarded timing, leaned-out carb and crude smog controls, all of which killed performance, especially in the '70s. A few had hi-perf applications and some were very good at that.
    351C: the one exception, had lots of performance potential but came on the scene a little late. Made from '70-'74(?), when it was replaced by the 351M. No history of premature failure that I'm aware of.
    460: really heavy, even for a big block. Some of the 429s were built for performance but really didn't do much (except the ultra-rare Boss).
    440: 4-barrel version was a big-car engine, built more for torque than horsepower. Six-Pak was very strong.
    Buick 455: short stroke, the GS versions were very strong, especially the Stage I.
    Olds 455: long stroke, torquey. Some strong musclecar versions including the W30.
    Pontiac 455: long stroke, kind of a boat anchor, only really strong version was the '73-4 Super Duty.
    Cad 472-500: don't know much about it.
    Of course, every engine has its fans, and I'll probably hear from all of them. But if you're buying a barge don't worry about what engine it's got. They're all good enough for that application.
  • rea98drea98d Member Posts: 982
    So basically if we added hi-compression pistons, an agressive cam, bump up the timing (maybe a modern ignition system?), and add fuel injection, we could wake these 1970's big blocks up? Why hasn't the hod rod scene thought of this? (Or have they, only to lose public attention to the "sport compact" crowd?)
    Well, no, of course I don't want a land yacht to race in. I want it to be large, and move okay, but mostly for the tacky luxury. I was just wondering if any of those engines were hopeless duds, just waiting to bite it. For example, I heard the 451 Windsor had a bad habit of leaking lots of oil at high pressure. And I don't see many Chryslers on car sites, but maybe there were other problems that took them off the road. Anyway, it's very helpful.
    I have an old '78 Ford 400 is why I was asking. Anyway, isn't torque more important than horsepower to begin with. The engine is soon approaching the point where it will have to be rebuilt, and when it's laying in pieces on the workbench is the best time to upgrade.
    As far as $ goes, I know it's not worth what I'm going to put in it (It's from a 78 Grand Marquis), but hey, I'm young, stupid, and love the car.
    As far as a GTP goes, it's a bit lacking in the cylinder department, has the wrong wheels doing the work, and is dependent on the "iron lung" (I prefer my horsepower naturally aspirated) Besides, the car's looks are a little too mean for my tastes
    Once I figure was a mis-stroke but twice???? There was no 451 anything. The scoop on the Windsors and Clevelands are as follows: The Cleveland would have been the best small block ever but came on the scene too late. It had very good canted valve heads, a small journal crank for high RPM use and a durable lower end. It's negatives included a goofy oiling system that lacked for high RPM use. Simple oil restricters kept the pressure in the mains for racing applications.
    The Windsor is a very durable small block and shares the great aftermarket for heads as it's smaller 289/302. It has a much beefier block and is an inch taller than the smaller 289/302 and has 3" mains that some engine builders don't like for sustained High RPM use. The 302/351 currently has an aftermarket that equals both in quantity and price of the small block Chevy.
    Plenty of big blocks on the drag racing scene.Both Ford and Chevy have crate engines that can make up to 600 HP on pump gas. Ford has a 514 inch motor that does just that for around $6000. It is based on the 429/460 motor which is a great motor that also came on the scene a little late. But since Ford used them in trucks for almost 30 years the parts and aftermarket are much better then the Clevelands.
    Your 400M motor is considered a boat anchor(I'm sorry) but one good thing is it shares the trans bolt pattern AND same motor mounts as the 429/460. You can go to pick a part and get a 365 horsepower 460 out of a '69 Lincoln and it should bolt right into your Merc. for around $200 and a the cost of a mild rebuild.
    Well, stupid me. I could have sworn it was a 451. That's what I was told it was, and I thought I saw it written that way too. Eh. Anyway, I had the Cleveland in a '78 Mercury Grand Marquis. I found it to be smooth most of the time and fairly decent to accelerate, given that it was lugging 6200 lbs. of car. I could routinely peg the 85mph speedo and it ran quiet usually. I think it hadn't been well cared for. There was at least a half inch of gunk on the valves, and one of the heads had been cracked for a long time, so it actually was a V-7 for about a year, until I could afford to fix it. Then the ungrateful beast warped the cam and cored out the bottom of the block. The only routine problem was that it was a twenty minute project to start on cold mornings, and stalled a lot, until it warmed up. Thank god none of my friends are car nuts, they probably would have had a big inside joke going about my 451. How embarrassing.
    Another couple of questions: Didn't Olds have a 429 or something? Maybe that was just a muscle car engine. And, finally: Suppose I go off my rocker and get one of the big AMC's (Matador/Ambassador?). What will I end up with enginewise? I'm not sure they ever made anything that quite qualified as a lux-barge.
    P.S. Speedshift, performance is important too. I don't want to wind up with old ladies in Dodge Colts passing me on the right and giving me the finger ;) So that info is useful too.
