Toyota Avalon Basic Maintenance Questions
in Toyota
I just purchased a 1996 Toyota Avalon with only 30,000 miles. There were no maintenance records and the lady I bought it from was old and had no idea what he late husband had done service-wise with it.
I am planning on keeping this for the long haul (250K miles) and want to make sure it is in tip top shape. What type of engine/tranny/etc. maintenance should I do right now to get this in pristine condition? It has very low mileage but is over 6 years old. Thanks for your suggestions!
The number on the factory oil filter is 90915-20003, the stock number for filters sold by Toyota is 90915-YZZB1. The factory filter is slightly longer, gasket and interior color is red vs. black for the stock. And the factory filter has both Japanese and English written on it.
Any reason why the number and other differences?
My maintenance guide says to replace the following: engine air filter, coolant, a/c filter, oil&filter. Also rotate tires and inspect lots of stuff. On the other hand, my dealer says I should do a bunch of extra stuff, like replace spark plugs, clean disc brakes, adjust engine idle speed, clean throttle positioner system (do I have one?), and NOT change the a/c filter. They'll do all that for a mere $300!
So should I tell them only to do what's in the maintenance schedule, plus the a/c filter? What's a good price for that? And why does the dealer discourage me from touching the a/c filter anyway? I've never had it replaced.
The cabin air filter is a tricky one - are you sure it is not supposed to be replaced at some odd maintenance interval like 22.5K or 37.5K? If you have never had it done, just ask them to tack it on to the service you are going to have them perform. And you are allowed to bring your manual with you to the dealership and go through it item by item to show them exactly what services you would like done.
Every dealership has a different idea of what they think is the absolutely perfect maintenance schedule for your car, and how can they all be right??!! With Toyotas, doing what is asked for in the manual will not only ensure you meet the warranty requirements, but it will keep the car running for a long time as well. There is no need for extra stuff.
This, of course, doesn't apply to the 120K plugs.
I am not sure what to recommend as far as places online to get spark plugs. I tend to make use of the local auto parts discounters. They have good cross-references for applications, and tend to stock a large quantity of useful late model parts. The best part of local discounters would be local accountability. Who wants to wait on shipping to get needed materials, and even worse, what happens when something goes wrong?
Besides, the Bosch platinums I used for my avalon were only $1.99 each over the counter. Thats about as inexpensive as you could desire.
Everything else about this Avalon XLS has been flawless, outstanding car.
Replaced air conditioning cabin filter
Drain and refill cooling system
Drain and replace transmission fluid
Rotate all four tires
Oil and filter change
Air filter replacement.
Everything else was inspect or check. For that they charged me 3.5 hours of labor time. But I must say after the service the car sounds and feels great, just as if it was brand new. I am looking forward to many more trouble-free miles and hope the next major scheduled maintenance is not as expensive.
Parts...............$111.82
Labor..............$253.13
Disposal fee.... $ 10.50
Tax....................$ 6.09
Total................$381.54
So I guess 3.5 hours labor time works out to be $72.32 an hour
Whew!
Also, the dealer wants to change the oil at 3000 mile intervals. After lots of research, I'm basically convinced every 5000 miles is more than sufficient (the shorter interval recomended by Toyota).
Expert opinions?
I was wondering the same thing about changing the differential oil on my 98 Avalon. The only thing I have seen is a plug with a small piece of bent tubing on the front side of the block, about 1/3 the way over from the end on the right. I assumed this was the differential oil drain, but did not see a fill hole, so I left it alone. I am going to the dealer for a brake job this weekend and will ask them. I am planning on switching over to all synthetic fluids- Amsoil tranny and diff fluid, as well as motor oil and filter.
The key phrase seems to be "Tires For Life Agreement". To qualify for the program such ridiculously short service intervals are required. The program was of no interest to me so I was able to terminate the irritating call.
Who else is suffering these misleading calls?
Seems as everytime I go for a oil change I am asked about 15K,30K and so on services. One time they even made me signed that I declined on the receipt. The other time lady sid "oh, you must have fogotten ...". You should see the look on her face when I said, no I have not forgotteb but I have declined.
Bottom line is that those types of services are DEALER recommended and not TOYOTA. They improve their bottom line. I recall that the dealership mailed me flyer on one of those (15K or 30K) services which was basically oil change and
" check hinges... check tire pressure ... etc"
for a discount price of $249.
If you are a sucker or want piece of mind you should do it, otherwise tell them no.
Since my Avalon is under warranty I have oil changes done thru them. Once the warranty is over, I plan to stay away from them and do it all myself (within a reason).
Tom
Everyone has a differenct story about changing intervals. Your type of driving has alot to do with it also.
The fuel filter, the one in the engine bay, doesn't need to be changed at 22K. That is too premature. I believe I saw a dealership say 30 or 40K which means longer.
The tranny doesn't need to be changed at 22K either, unless you are doing 100% city driving, mountain driving, pulling a trailer, etc. 30K intervals are more than enough, however I am going to replace mine at 60K the first time, then 30K thereafter.
5K Oil change intervals are in my opinion perfect from the literature on wear and tear. Unless you live in a very cold climate, the difference of synthetic versus regular motor oil is negligible. How many people do you know keep a car past 200K miles??? How many autocars have you had in your lifetime past 200K??? I have had one, using reg. oil at 5K intervals, except during the dead of the winter. I sold it to a soldier at 236K, a Honda, and it did not even burn up a full quart every 5K intervals. So if it makes you feel better use it, otherwise, put the money in the bank and save for a new car one day.
I change my A/C every year, not based on mileage. It is located in back of the glove box, which has 5 or 6 screws and just slides straight out.
I hope this helps. Perhaps Nomad56 can give his opinion, but his Avalon is an older model, not sure if they have an A/C filter.
abfisch
Tom
Email Nomad56. I think he has an older model Avalon and does extensive work on it. He probably missed your post. I am pretty sure, but not totally sure, the new model (2000-present) share the same fluid. Drain plug on bottom, filled through the dip stick for the transmission in the engine bay, using Dexron III.
abfisch
In the Avalon manual, it states that the drain and refill quantity for the tranny is up to 3.7 qts and 0.9 qts for the differential. So I would assume that if you drain both of them you would add about 4.5 qts of ATF fluid to the tranny dip stick. Is this correct?
Also, we bought our Avalon out of a lease and it developed the worn strut mounts shortly afterward. Had to haggle to get them repaired, as they said it was not covered by the extended warranty.
While I try at points to be the devils advocate, "leaving it to the dealer" gives me the whillys, unless it is a fair and competent dealership, which their are, but few and far between. By sticking to a REGULAR maintenance schedule, and changing all the fluids, no only including the ATF, and Brake fluid(every 3 years regardless of mileage, and Steering resevoir, you should really never need to flush the stuff, and have some incompetent put their mitts on your 30K machine. Yes, flushing gets all the fluid out, but replacement at scheduled intervals does also, without the exorbatant charges for turning a freaking screw and pouring fluid. I just can't let them do it, not at $75/hour. I would rather get frostbite!!!!
abfisch
Most of the Toyota dealers around here change book hours and more for labor. Sometimes I think the book hours are set for someone that has to read the service manual first and has little experience.
Couldn't agree more with the last two posts. Doing it yourself, is always better if you can. Changing fluids are maintenance, not repairs, which should be very easy, with some basic equipment and safety. I have no experience with ATF longevity, since this is my first automatic car, but regular interval changes should bring it to over 200K without too much fuss, without flushes.
The Toyota Service manual, conveniently(2002), leaves out any mention of ATF change intervals or PS intervals. How freaking convenient. A new 2003 Civic manual, for severe service(much clearer) suggests ATF at first 60K interval, then every 30K thereafter. There is a NEW DEXRON III Synthetic now, instead of an organic DEXRON III. Does anyone have any experience with this synthetic in there tranny yet????????????? Nomad56?????????
abfisch
On my 99 Landcruiser with 120,000 miles, I changed all the fluids to synthetic Amsoil motor oil, trans fluid, gear lube, and grease. I plan on driving these vehicles a long time.
