why dont you price new stock springs,you could also measure
the length of the unsprung spring and compare it to the
length of a new one,get the length from a manual.All of the aftermarket springs will probably lower the car so thats
why I would stick to stock.If you replace the struts it is
very important to replace the mount also.
abfisch
I read one of the camry posts that talked about how someone had had their front struts replaced, but that it was making the noise (that I recognized.) They took it back to the mechanic who simply needed to tighten the upper strut mount nut (visible from the top) to resolve the problem. I thought "hey.. what if I tightened that nut on my Camry?..." So... I happened to have a deep socket that was the right size (same as the lug nut) and gave it about a 1/4 turn to tighten. Well... after that, the problem disappeared... it's been several days and about 140 miles... I'd say I'm on to something.
I understand that Avalon suspensions may rattle the same way.
Food for thought... Keep in mind that I'm not a car mechanic. Just an average guy who doesn't like to spend money on needless "repairs".
The link no longer works. Who was the supplier selling at this price? I just paid $209 for a set of KYB GR2's from Performance Parts for my wifes 03 Avalon. $330 for installation, $50 for alignment. It had pulled to the left, and the best we could do on camber was right on the edge of spec, so we installed an adjustment 'kit' which is an eccentric that allows further adjustment, for $60. Many shops won't install struts that they didn't sell, but I had Fleet Farm do mine - after I explained that they were new and upscale from stock. I could have had them done by the mechanic at a local junk yard too, for a bit less due to a lower hourly rate.
I had installed Energy performance front sway bar bushings first. These brought quickness to the steering and eliminated much of the vague, sloppy feel. For 30 bucks you can't go wrong. I installed them myself. EZ. Check your sway bar size though. I've seen 18 & 19 mm listed, but mine were 17 mm.
The struts improved steering more yet. Yes, it rides stiffer, but that is to be expected. I installed large super duty shocke on my wifes 67 Fairlane way back when, and it was stiff. But we took it on a trip from MN to AZ and back. That broke them in, and it was just about perfect. So, I expect the edge to come off these with use too. The Av. had taken speed bumps with out much effect before, but better slow down now, as they definitely are noticeable, as are rough streets, but not objectionable. A good trade off for the improved driveability. The quick response to steering wheel input still surprises me. That's when you know you have improvement - when something unexpected pops up. Nice. So far, I can't find bushings for the rear. Energy lists them (16mm. I'll need to modify to 17mm), but no one can get them, and apparently they don't intend to make them any time soon. Anyone know of any availability (P/N 8.5120), or another brand?
I had just about 60k on the car, and the float was very noticeable with someone in the back seat, or a load. We plan a trip to AZ with a full load. That will tell the story. They said that they usually didn't replace the strut mounts unless the mileage was really high, and did not change mine. Wife likes the improvement.
BTW, if any of you want to improve your old strut performance, you may get a boost by replacing the sway bar bushings with Energy polyurethane units for abott $30 if you do it yourself. The reason for this is that they better tie the strut action together so rather than one wheel moving up and down fairly independently, a stiffer bushing makes the other strut to contribute more. I may not have replaced my struts had I done this before I ordered new ones. It may not be night and day, but I could tell the difference. The tech that replaced my struts did say that my originals seemed good yet though. So, if your budget won't handle a grand right now, try $30 to get by til it will.
Jerry
Not sure what you are hearing. Wish we had audio to this forum but check all of these levels and I am pretty sure you will find the area if it is abnormal. Road surface you cannot change.
abfisch
Steve :shades:
In general, the higher the speed rating or the lower the profile (60 vs 70), the firmer the ride. Probably more road noise too.
You talk about thunking and ride. So, is the problem noise, or ride? Or both? Lower profile tires high performance/speed rating will Probably give you more road noise and firmness.
Have 86K on the 02 now. Never ran better. Washer pump made me mad, but took my time and fixed it myself.
For the post that is having trouble with road noise, "thunking", expansion joints do that to all cars. The noise is a product of tires, pressure and rebound from the struts. Yes, I agree some tires are more comfortable than others and I think yours CR rated very high, and if the pressure is normal 31/32 65/60 series tires, I got to think the struts could be a potential cause. They all contribute.
I also saw a posting recently about intermittent functioning of the heated seats. I just am shaking my head. The more electronic componetry, the more stuff can go wrong. Rather stick to the suspension upgrades.
Again, great to here success from others.
abfisch
abfisch
Tokico and KYB make an excellent aftermarket replacement strut. They are the exact match to fit, and in addition they are twin tube(not monotube) low pressure (not high pressure)gas struts. The KYB are priced more reasonably from these posts. I personally put in Tokico's but it makes little difference in the end. I have about 65K on these struts with remarkable differences. There are starting to wear but that is normal for any hydraulic device.
I hope this helps you.
abfisch
abfisch
Then I had moved out of town and the streets in my new area were rougher in general. This was August. The clunk and rattle in the left rear slowly became worse and there were some parts of town with the bad roads that caused me great cringing and quite embarrassing as it felt like the entire rear was loose or a buckle full of bolts. I had checked everything and took everything out of the trunk for the 5th time and tested the car with empty and full gas tank as well as the spare tire removed. No difference. Finally with the colder weather approaching, this annoyed me so much and during my times of tire rotation and alignments, I would ask the mechanic about it. Nobody could see anything but they all suggested new struts as this was the only thing I had not done. I checked around and after spending about $300 already and not getting anywhere, the price of new rear struts was generally around $500-550 and $850 from the dealership. The strut prices weren't too bad but the 4+ hours of labor was pretty much average. I checked online for prices, ebay being a good source but found that most shops would not put on products that were not bought from them; the few who did would not guarantee them, and I was also not knowledgeable enough to know if Monroe or Gabriel which many of the places normally recommended and carried would be any good or "tuned" as well to the Avalon as some people online felt they were of low quality with poor efficiency and lifetime compared to the more expensive Tokina or KYB which some noted a more stiffer ride. I was looking to eliminate the noise first but a ride comparable to the original ride. At last since I couldn't take the noise any longer, I had Sears put in Monroe Sensatraks back in Oct. as their labor costs were only $112 (although they run a half price installation often) and the struts were about $95 each (a little higher than what can be had through parts stores). But I figured $300 and some change a bargain. This seemed to help a few days and then the noise returned. In fact it was worse and I figured it was that the struts were stiffer and whatever was causing the noise, this amplified it. I took it back in in Dec. They noted the left rear strut was "shot" and replaced it. That seemed odd but unfortunately this did not fix it. Then recently with this cold weather, I was hearing noise from the right front--this was a belt or alternator or bearing noise and it was noted that the seals to the rack and pinion were broken and the power steering fluid was leaking. At this time I had pulled the rear seat out completely since this was a new mechanic I was trying out and wanted yet another opinion of the rear noise. They repaired the rack and pinion (long rack) and replaced the left CV axle as the boot was also broken (the right side being done within the year). With the seat removed, it was much more obvious the knocking noise from the left rear as well as outside road noise, etc. The mechanic had gotten in the back seat area with another driving and saw the strut moving excessively over rough surfaces as well as making a racquet. He noted it was the strut mount that was recently replaced 8 months ago. I confirmed this and put a hand over the upper assembly and this eliminated the noise while the car was moving. By the way, I had even gotten into the trunk several months ago to isolate the noise. Did not hear it but a scary experience and very noisy otherwise. Since then it is against the law to ride in the trunk, mainly due to kidnappings and kids being put in there for a quick transport. Good law by the way!!
Well, this mechanic wanted to get the major upfront stuff fixed first but now I could tell it was the strut mount (again). Since this sits behind the seat and not very well exposed, mechanics do not see anything nor typically hear anything and unless they are aware of the strut mounts, are not likely to diagnose it correctly. Also one mechanic had suggested it was the seat making noise and not the suspension at all on a test drive and knowing the seat had been removed and replaced three times, I was looking for anything plausible.
To make a long story short (LOL)--I then figured since Sears worked on the struts I would see what they had to offer and it was a Sunday and very few others were open. The mechanic was very nice and explained it was the strut mount most likely and commented that he knew I was serious with the rear seat out! Having the rear seat out also was not ideal but I was determined to get it fixed. He replaced the strut mount with a Monroe brand and this eliminated all noise and for the first time I can appreciate the overall improved suspension. The car is now quiet and since I had been hearing so much noise for over 2 years I had forgotten how the car was suppose to be and this also affects the ride as the strut moved around in the mount.
I cannot say why the strut that was initially installed did not work properly. ? defective, perhaps not put in right? At least that mechanic had the right idea. This column also helped as I pretty much knew that it was the mount all along despite my limited mechanical and car experience and knowledge. But I was sidetracked as well as all the others after having a new mount installed initially.
I would certainly go along with a strut mount being the problem with such noises and of course the bushings and struts themselves. Other undercarriage things like the exhaust and other links and even the wheel and brakes should be considered. BTW, I have 168,000 miles on the car and hope to get a little more use out of it.
I thought it was quite odd that the second strut mount that was replaced some 8 months prior could be bad or "defective."
Too bad the mechanics did not have enough sense to try this simple measure. I would have certainly saved a lot--and perhaps this will help others. I have noticed an early rattle noise on my right rear strut so I will try to tighten the nuts down and hopefully this is the fix. I did look and attempt to tighten the nut on the other side and they did appear tightened before having it replaced and wouldn't budge. As with such nuts and bolts, I don't have any air compressor power tools and not too familiar with how much torque I am delivering (by hand) so what seems to be tight or with no obvious appearing looseness, may not be.
Thank you for your input again and I believe it is as you have noted all the problems. I did inquire however after the first mechanic replaced the strut mount and it still continued to make noise if he did tighten it properly and he said he did. Again being a layperson and being it was covered by the back seat and reluctant to take that out (which I finally did on my own and wasn't difficult), but you have to have some trust in those in the business-- it is that initial curve of going through the whole thing as being the most educational of course unfortunately.
I look forward in getting the back seat out again and attempting to tighten the other side now!!
They would have most likely recommended replacing the struts with a car with high mileage on it. It is not something they can visualize. It is also a "problem" they are not too commobly aware of it seems.
The rear seat has to be out and two people have to test drive it--one driving and the other in the back seeing and hearing the strut loose in the mount!!
Most places take it out for a test drive, either hear nothing or very little in their limited drive and if they do hear anything, they recommend a strut and may notice some moisture around the strut to confirm their suspension. Most mechanics also are not bothered by some rattle and noise as it is not their car and with something of high mileage they consider this to be normal in many cases. To the owner, it is a very annoying, cringing experience that is anticipated over every uneven surface.
I think my rear struts had gotten a little soft with 168,000 miles on the car however and I guess this is consolation for it all--it seems to be doing much better now that the strut mount and screws are finally and properly placed on the left side. Now I am able to hear the beginnings on the right rear side but will certainly attempt to tighten the screws better before taking it again.
Took the car to the Toyota dealer and they said that they had experienced this on one other Avalon and some Camrys, but that Toyota "doesn't have a fix". They claimed the noise may be coming from the strut supports, springs or something closely related. The only work-around that they said Toyota Engineering had was to dissassemble both sides (drvr/pass) stut/spring assemblies and put a piece of felt between the strut support and the body and then greased everything else.
I beleive that this is obviously a temporary fix and I will be back there at some point.
I also have a noise in the right rear of the passenger compartment in cold weather.
I'm a bit disenchanted with the new Toyota Avalon.
Anyone else have this experience, and if so, what have you been told?
I don't like the color choices offered on the Touring model.
Do you know of any simple upgrades available for the 05-07 Avalon that would bring it close to the Touring model?
abfisch
I am not totally familiar with the 06/07 suspension, but on my O2, in an independent rear suspension espeically, taking down the links and arms, you need to make sure the alignment is at specs.
You'll know if the tires wear really fast on one side or the other, or the car pulls to one side or the other.
Hope they got your problem fixed anyway.
Enjoy the car.
abfisch
Jim
Steve
97 XLS w/ all the toys!
Long live the avalon!
No, you can't have mine!
It may help due to the fact that there will be a better, or more rigid connection to the other strut, forcing it to contribute more.
Make you have both sides on the same plane. If only one side is raised, you will preload the sway bar.
It seems to me this has something to do with the OEM struts being too sloppy, not being able to damp vehicle movements effectively or quickly enough. I'm not really looking for a "firmer" ride, just a more composed one with less rocking, porpoising, etc. when road imperfections are encountered. Would changing to KYB or Tokico struts help with this?
Have had TokicoHP for 70K on an 02 Avalon, with Energy Suspension PU bushings, regular springs and Toyota OEM wheels. My other vehicle is a BMW 3 series with the sports suspension. While two different cars, you would be very very surprised. I took the BMW yesterday, but I took the Avalon today, more comfortable for a large person.
Not inexpensive to change, but worth it if you intend on keeping the vehicle.
Bigger sway bars I do not find necessary on this vehicle. The PU sway bar bushing, act the same as putting on a bigger sway bar, and the vehicle rides markedly well controlled while still balancing out for comfort.
abfisch
So somewhere along both axles,Isee, but do I put them as near as possible to the wheels? Can they be put in the wrong (non-supportive) place?
Jwadle1, did you ever take the pics you promised?
To clarify, I am no mechanic, but I do change my own oil and struggled through a recent sparkplug change.
Mahalo,
hawaiianavowner
Haven't checked in in awhile. Sorry. The PU bushing replace the OEM rubber ones, and attach via a brace to the chassis. It is not necessary to take the wheels off, although the front ones are hard to get at, the rear ones are quite easy. The support jacks are suppose to go on the side of the car, you are correct at the jack positions. Their is also a jack position in the middle of the front and in the back. An easy way to have the wheels loaded while accessing the underneath, is to buy a 2x10x12 board, cut it on a diagonal into 4 pieces, place each before the tire, and then roll the car onto the boards. It gives you a little extra clearance for working under the car, or alternatively, you can lift the car up from the central lift points and put the either front or rear axle wheels on ramps. You can easily work on the bar mounts from there, it is safe,if the ramps are safe, and the suspension is loaded.
That is what I have done in the past, carefully, and it has worked well, using every safety procaution possible. Grease the bushing well. Do not over tighten. Using a stubby ended rachet wrench made things much easier in front.
Hope that helps.
abfisch
Thanks again!
