I keep hoping that some bright engineer will soon realize that ABS need not be activated unless the VSC/PSM system indicates the need....
But...
Not all of "US" lived through that hundred years without ABS.
Personally I would redesign the DBW accelerator pedal system to use a torque motor instead of a return spring and then use the torque motor to increase the pedal resistance, and maybe some vibratory signaling, during times of automatic engine dethrottling.
Sorta of like many of the new electrically powered stearing assist systems are now doing, increasing resistance against a turning force that VSC indicates is undesireable.
One of the reasons I liked ABS even initially, that vibratory brake pedal was a "message".
On another note....those of you who do not have the hesitation issue with their transmissions, consider yourselves extremely lucky, but kindly do not belittle our problems by suggesting this issue has been documented enough. It will have been documented enough when Toyota chooses to recognize there is a serious problem which needs fixing. I would love to rid myself of this problem by trading in my Avy for a Honda or whatever (anything but Toyota at this stage) but discovered that my Avy dropped from $35,000 to $25,000 in just a year. So much for Toyotas retaining their value.
Bob
are more than some dealers want,if you paid 35k you will take some kind of hit but not 10k.
My idea is to prevent the engine/transaxle ECU from commanding an upshift under some of the conditions defined within the Toyota TSB that "addresses" this issue.
By passively, non-destructively, monitoring the accelerator position sensor's output voltage we can determine that the accelerator pedal is in the process of being released and the instant it is released the trial circuit will activate the brake lighting system. Not the actual brakes, just the circuit that "tells" the ECU that the driver is braking and therefore perhaps provide an indication to the ECU that the driver clearly does not want to enter "cruise" mode.
Hopefully (it is a "trial") this will prevent the inadvertent/undesirable upshifts which as most of you know I believe are at the root cause of the delay/hesitation symptom.
The trial circuit will include a switch so the driver will have the ability to readily switch back and forth between the trial circuit and "as shipped".
Try using your left foot to apply the brakes just as you begin to lift the accelerator pedal to enter a coastdown mode. If my theory is correct that should do as well in preventing the ECU from commanding an upshift as would an actual circuit.
If it is somehow made clear to the ECU that you have no intention of entering "cruise" mode then it should not command an upshift.
I also doubt if the "little engine that could" in the Matrix/Vibe could generate any serious, unsafe, level of engine compression braking via the slushbox. Unless, that is, the driver is unwitting enough to downshift (presuming the firmware even allows that to happen during a coastdown) on a slippery roadbed.
Oh yes, it allows it. :shades:
I do understand what you guys are talking about though. Several years ago my parents had a 2003 Silverado. It experienced the same symptom of not accelerating when floored. Plus when I was driving it, I went to pass someone, floored it and got almost no power. At the time (don't know about now) Chevy said that it was affecting all their trucks and that the Tahoe was the one they were experimenting on trying to fix it. They had to have gotten it fixed, since I drove a Trailblazer not that long ago that didn't have that problem.
But be that as it may, that wasn't really the issue I was addressing/questioning.
Can you lift the throttle but stay off the brake and downshift, provide yourself with engine compression braking, using the paddle "steptronic" shift technique or by simply moving the shift lever into a lower notch. Furthermore at what speeds and into which gears?
Since it has become pretty clear that the vehicles exhibiting the delay/hesitation are upshifting during throttle closed coastdowns. I wonder if that can be defeated, easily, by manually commanding a downshift in a "timely" manner?
Using the paddle shifter, does the vehicle actually downshift, does it upshift anyway, or does it (best of all) simply remain in the current gear ratio?
If one of the "features" of this "new" engine/transaxle ECU control firmware is to prevent loss of directional control due to engine compression braking then I would think the firmware would exhibit reluctance, in the extreme, to actually downshift in the above conditions.
For instance I am quite certain sure that the transaxle in my 2001 AWD RX300 actually UPSHIFTS below about 10 MPH as I coast down for stopping, brakes applied or no. I can't be sure it doesn't even shift into neutral at that time. The feeling one gets is as if being bumped lightly from behind, or as if the braking suddenly became less powerful.
I am also quite sure/certain that it upshifts at about 30-45 MPH during throttle closed coastdown periods, the "slingshot effect" feeling. That last one is even verified within the Lexus RX300 shop/repair manuals.
Bob
My theory on that "feeling" (which I also get when slowing down whether with brakes or without) is that the computer has sensed the need to downshift to the next lower gear and it is dictating what RPM it will jump to at the moment the downshift occurs. I believe the RPM they have programmed in, is higher than it should be, thus creating the sensation of being nudged from behind. Perhaps it was designed for a gear ratio that was originally intended, but changed AFTER writing the software.
So I think not.
And I'm pretty sure mine doesn't actually downshift into 1st gear until I have come to a full stop, or in the alternative, "get on it" before coming to a full stop.
Which is why, I suspect, that these early non-DBW RXes with ASL firmware are having premature transaxle failures. My ATF HAD to be changed out (dirty looking brownish and smelled, odor, of burned resistors) out at 40,000 miles. Never had to do that with ANY Ford product, or previous Lexiis, even at over 100k miles.
Yes, and at the same time I feel that, the RPMs come up about 500 or so.
Yes, I can lift the throttle (if it wasn't in the highest gear it possibly could be it will upshift) and then move the lever down. For example: At 70 MPH, I can press the OD button and it will execute a 4-3 downshift. If I then push it down to second, it will execute a 3-2 downshift. If I then push it down to 1st, it will execute a 2-1 downshift, after my speed has come down sufficiently. Does that answer your question?
Ouch, this is definitely strange design. Mine does not do this and downshifts as it should during deceleration. I cannot imagine any good reason for it upshifting under deceleration. However, I have experienced this feeling before in the 2004 Malibu I owned prior to the Vibe. It too had DBW. It worked perfectly well until they applied a PCM update to correct the transmission not upshifting at higher speeds (you had to practially lift off the throttle to get the 3-4 upshfit to occur). After they applied the update, every time I slowed down from highway speeds, right at 55 MPH, it felt like I was being bumped from behind. Since, near as I could tell, it hadn't downshifted before that, it was dropping out into neutral momentarily. I definitely had to apply more brake at that point.
The relevancy is that these are all other products made by Toyota. If Toyota makes other products (especially multiple other products) that work correctly, then they can't hide behind "that's how it is" as a defense. So it is useful for us to compare how other Toyota products work to determine if the Avalon is exhibiting normal Toyota behavior.
Federal regulators propose rule that will require new safety feature on all U.S. passenger vehicles.
By Peter Valdes-Dapena, CNNMoney.com staff writer
POSTED: 12:01 p.m. EDT, September 14, 2006
NEW YORK (CNNMoney.com) -- The National Highway Traffic Safety Administration announced a proposed rule Thursday that will require Electronic Stability Control on all passenger vehicles in the United States.
Electronic Stability Control (ESC) uses a variety of sensors to detect when a car is a skid or rollover is happening, or is about to happen, because of hard cornering or slippery road conditions.
The system will rapidly apply the brakes for fractions of a second at individual wheels and simultaneously reduce engine speed to keep the vehicle under control. Such systems can often react even before the driver is aware that there is a problem.
The proposed rule would require all manufacturers to equip passenger vehicles under 10,000 pounds with ESC starting with the 2009 model year and to have the feature available as standard equipment on all vehicles by the 2012 model year.
Several studies have shown ESC to be extremely effective in preventing the most dangerous types of crashes.
About 43,000 people are killed in auto crashes in the United States each year. The agency estimates that ESC will save between 5,300 and 10,300 lives annually and prevent between 168,000 and 252,000 injuries.
NHTSA Administrator Nicole Nason called electronic stability control for cars "the greatest life saving improvement since the safety belt."
ESC tends to prevent more single-vehicle crashes, which usually involve a vehicle running off the road, the study found, but it also helps prevent the most serious, high-speed multi-vehicle crashes. The technology had little effect on less serious "fender bender" crashes, presumably because those types of crashes usually do not involve loss of vehicle control.
ESC is currently standard on about 40 percent of 2006 passenger vehicle models and is offered as an option on another 15 percent. On some vehicles, it is only available as part of a more expensive option package.
Adding ESC to vehicles that already have anti-lock brakes will cost car companies about $111 per vehicle, the agency estimates.
Ford Motor Co. recently announced that ESC would be standard on all of its cars and trucks by 2009.
General Motors has also said that it will make ESC standard on all of its vehicles by the end of the decade.
DaimlerChrysler's U.S. Chrysler Group has said it will have the technology as standard equipment on all of its SUVs, including Chrysler Jeep and Dodge vehicles, by the end of 2006.
Unlike other technologies, such as airbags and anti-lock brakes, car companies have a variety of different names for ESC. For example, General Motors calls their system StabiliTrak on SUVs and trucks and Active Handling on its cars. Chrysler calls their system Electronic Stability Program (ESP). Ford calls its ESC system AdvanceTrac.
NHTSA will be taking comments from the industry and the public about the proposed rule for the next 60 days.
The article doesn't say, and I would imagine that it has not been decided yet - IMO these systems should be required to be user switchable, either on/off or for levels of intervention. Otherwise we will really be at the mercy of what some computer programmer (or lawyer) thinks is safe!
And the new Camry 5 and 6 speeds the same sort of complaints. Would also imagine in the 4 cylinder cars these behaviors are even more bothersome simply because there is less power available after the tranny does decide to engage.
The point being that the Toyota trannies are working exactly like they are designed to - at the expense of some drivability - and in exchange for better FE, emissions, and possibly limiting torque steer issues in the higher power applications. Isn't technology wonderful?
I keep reading about the transmission problems. Are these issues across the board in all Toyota cars? i.e. Avalons and Lexus?
I assume there isn't and won't be a fix for the problem.
Roland
There are posted complaints on this matter concerning VW, Ford, Toyota and Lexus FWD models.
I have come to quite firmly believe it is a result of an industry wide understanding of the hazards unique to FWD and they have now set out to somehow alleviate or eliminate those hazards.
"The overwhelming problem with this vehicle is the transmission; this was the source of my very first problem on the very first day of ownership. This car is consistently plagued by throttle lag/hesitation and the transmission is unable to provide a reliable ‘luxury car’ automatic gear changing solution, especially when in stop/start or in low speed traffic.
The automatic transmission will more often than not make the wrong choice for the car speed and road conditions and will result in unnecessary revving of the engine, jolting the car forward or doing nothing at all. When light pressure is applied to the accelerator pedal in an attempt smoothly accelerate, it is impossible to predict what will happen, making it very difficult to drive smoothly and tiresome to have to be constantly ‘on your guard’ to compensate.
It is literally anyone’s guess which one of the below options it may take. It may not react at all . no increase in the revs or drive to the wheels and do nothing for a few seconds just as if I was not even pushing on the pedal.
The below are all possible and this is after putting up with the throttle lag/hesitation period;
§ It may allow the engine to rev up to 2,500rpm and with no drive going to the wheels, (even when the road speed is already high enough to allow a change), hold this moment in ‘limbo’ and then slowly change the gear.
§ It may hold a shorter period of revving in ‘limbo’ and suddenly bump the gear in, causing a jolt of forward movement in the vehicle.
§ It may take the ‘huge thud’ option and try to break itself (and the driver). (has only happened twice)
§ It may accelerate normally (but only after the throttle lag/hesitation period.)
The problem is most noticeable in stop/start and low speed traffic but the transmission will often let the engine rev unnecessarily when accelerating while travelling at an already reasonable speed (60-80kmph). A point at which the car’s momentum should be more than sufficient to use the torque of the engine and not need to use the revs."
and the reply:
"Whilst the gear shift pattern does not suit your personal preferences, the performance across the full and varied condition range tested was to standard"
This car is a real pain in the Ar**... this is onyl one of several problems with the car..
Definitely NOT recommended..
Bob
It is my firm belief that sometime in the mid to late ninties someone, or some group, with TONS of clout over the automtive industry issued an edict that the safety of FWD and front torque biased AWD had to be brought into line with their RWD and rear torque biased AWD brotheren.
My vote goes to the automotive insurance industry. Accident statistics most readily available, certainly with the CLOUT and enough synergy with the industry to want to keep this on the QT.
The safety issue involved the potential for loss of directional control due to engine braking, especially FRONT engine braking, in wintertime adverse roadbed conditions. There is also the issue of the potential for engine braking to interfere with ABS, again especially detrimental for FWD vehicles.
So, late in the last century the shift pattern/schedule was revised across the industry to address the safety issue. The new shift pattern dictated that anytime there was a FULL lift-throttle action by the driver the transaxle would be quickly upshifted so as to prevent any significant level of engine braking.
The problem that quickly arose from this change was that if the driver quickly returned to acceleration "mode" the engine was now at idle and the just previously commended upshift would deplete the ATF pressure/flow reserve. With little or no ATF pressure/flow available the subsequent downshift due to the driver's re-application of pressure to the gas pedal could not be quickly completed.
As evidence of Lexus has now replaced a LOT of early RX300 transaxles.
By 2001 Lexus had figured out the problem and increased the displacement of the ATF oil pump, gear type oil pump, to provide more pressure/flow at engine idle.
So, the 2001 RX300's, even with all equipped with the extra ATF cooling via the tow package, OVERHEATS the ATF to the point that the recommended traansaxle ATF service interval has declined from infinity (the life of the vehicle actually) to every 15,000 miles.
What to do, what to do...??
Oh, I know, let's use DBW, e-throttle, to delay the onset of engine torque until the subsequent downshift can be completed, the clutches firmly seated.
So the RX330 used the old standard ATF gear pump displacement but was equipped with DBW "to protect the drive train".
Regretably some one else in engineering had already decided that the VC, Viscous Clutch, in the AWD version was contributing to the overheating of the ATF and so it was removed, not to return until the advent of the RX350.
Is Lexus listening, do you suppose?
The final FIX...
SNOW mode...Assuming the new shift pattern upshift technique is to help alleviate accidents due to loss of directional control arising for engine braking, why not just have a SNOW mode that can be activated by the driver, by a rain sensor, or if the OAT hovers around or below freezing?
Upon a full lift-throttle event in SNOW mode the transaxle would remain in the same gear ratio (ready to SURGE forward on command) but the engine RPM, via DBW, would not be allowed to fall enough to provide a significant level of engine braking to the driven wheels, FRONT, rear, or ALL.
Absent being in SNOW mode the shift pattern could be the same as it was pre-2000, NO upshifting on full lift-throttle events.
No HIGH potential for engine braking, FRONT especially, to put your life at risk or interfere with ABS if the roadbed traction is satisfactory.
I guess on second thought ABS interference via engine braking might still be an issue. But that could addressed by keeping the upshift pattern but delaying it until the brakes are applied.
You might want to inquire at your dealer just to see what they tell you.
Thanks for the response. I made an appointment with the local dealer to look at this and a couple other minor issues on Wednesday. I also read WWest's litany on transmission related issues associated with throttle response and hesitation. While interesting, I'm afraid he's coming from a technical side above my understanding level. I guess I'll just let the Toyota Service folks tell me "that's normal", there's nothing wrong with it, and learn a little different method of throttle control. Thanks again.
Driving with a "smooth foot" will lessen the hesitation chances considerably. Try to feel how the transmission acts and adjust. Some have posted that driving in S5 will also help but I have not tried it as the car is fine in D. Experiment with yours, post the results....
Having owned each generation of Avalon I would gladly trade the current 5 speed for the 4 speed of yesterday. The gas mileage and acceleration difference is not worth it and the constant hunt for a gear is noticable. But, we must move forward. You will probably be told your transmission is fine and it probably is. Keep the board informed.........
Bob
i'm not sure all owners would feel confident doing the same.
As a matter of fact many of the new Toyota owners manuals advise that engine compression braking can only be obtained via manually downshifting and with cruise control off(??).
Just keep in mind not to use this "downshift" procedure unless you are certain of good roadbed traction.
Rich
I drive most of the time with 'S5' selected, which does reduce the lag and unnecessary revving quite a bit... but it still does not behave like it should and
I have many other little nagging issues which Toyota here (Dubai) say are intermittent and therefore not a real problem..
cheers
their "flagship" vehicle? not according to their website.
Source please?
avalon xls,the most recent a near rear end collision.
My contact with toyota has had polite discussion without
admitting a problem exists or correction of the problem.
A real shame that toyota is willing to sell cars that are touted as the finest,but are not willing toback up that claim when a buyer may be faced with a major safety issue.
