Toyota Avalon Real World MPG Numbers
Just a question about mileage and expectations.
My 2003 has about 12,500 miles and I bought it in August 2003. For the life of the car I have averaged 20.7 mpg. I average about 175 miles per week. My drive to work is only about 1.5 miles each way. This past October we drove from eastern PA to Ann Arbor, Michigan. The best tank I got on that trip was 29.7 mpg.
I don't think I have a lead foot. My feeling is that I should be getting better mileage than this. Are my expectations unrealistic?
Ken
Ken
That is what most of us get. I am not sure of your expectatins but this marries very well with real world mileage for this vehicle and comes very close to the EPA 21 city/29 highway.
abfisch
I have bought several new cars over the last 12 years. It seems that my Foreign cars (Toyota, Honda, Infiniti, Nissans) gas mileage improved a few MPG around 14k miles. My GM's Fords, Buicks really never did. The day I drove them off the lot I got the same mileage as I did 1 year later. Others have posted that the Foreign makers (Japanese) build such a tight spec engine that it takes about this long for the intial friction from a new engine to "loosen up". While I can't support this scientifically, I have seen it in action a few times.
I'm still disappointed with the mileage: we do better with our 93 camry v6, and of course we got better still with an 86 tercel wagon.
I expected to average 21 with mostly around town driving. Did I get a gas-mileage lemon?
"Real World" Fuel Economy vs. EPA Estimates
MikeS.
From everything I have read, I guess I am quite satisfied.
Ken
A mechanical engineer once told me that you get your best gas mileage at 45 mph.
Is that for 2005 Avalon specifically or any vehicles in general?
The problem is Gas Consumption. According certificate, it must to use 21 miles p/g in city and 29 - in HW. I'm using car 70% in HW and 30% in city. But I've got real gas consumption 20 miles p/g.
In the my local service station told me that "It's OK, don't worry." I was amazing: Toyota promised me one thing, I've got another one...
Please, help me to make decision.
Ken
Deanie
Please let me know if the numbers are messed up or my car is.
drb
Great car!
Gordo
Good to know all those numbers. I have been putting 350 miles on touring. Had 87 octane in the first fill from dealer and then mid grade. I got 300 miles/15 gallon which is approx 20 mpg. Numbers on the blue screen also constantly reminded me that.
When I added midgrade, i began to see climb in the number to reach 25 mpg on highway.
Wondering, should I be using mid-grade or premium hereafter to get to good miles?
Should I go to the dealer for checkup?
drb
I have been repeatedly posting here.....getting bit worried.
Contradictory to what all others post-i am not seeing those numbers.
What others see:- Right from day1 after purchase-mid 20s in stop and go driving with AC on.(on blue screen)
What I am seeing:-16-18 mpg with stop and go/ac on. (on blue screen)
with full tank, if I go in highway-i may occasionally see mid 20s.
I tried mid grade. still the same. have put 600 miles on it. Real mpg-approx18-20 mpg (calculated tank to indicator light on)
called the dealer/serice-said needed atleast 5000 to get break in for engine. But i remember reading 1000 somewhere.
REALLY worried. Should i contact somebody in TOyota? any links/contact info please? (my honda pilot 04, gave better mileage than this)
thanks,
drb
Anyway, i will cross my fingers and look for improvement.
drb
2 things drastically reduces the numbers:
1. Long idling
2. constant stop and go with jackrabbit start. (a slow start gets better results but also you got to be tolerant with other drivers who give you a dirty look).
All my trips within city doesn't last for more than 20 min, hence it is hard to get the numbers up.
However my tank to tank and blue screen are correct. Both is giving me the right numbers. So there is no fault with blue screen.
probably should have gone for hybrid.
Don't worry. I have a 05 Limited. Had it since 4 April. To date I have (at last fill up) 3177 miles on it. I've gotten from 22.58mpg to a high of 28.6mpg.
The first tank, that the dealer provided, I got the lowest-22.6 mpg. The next lowest was a tank of hi test-22.7 mpg. My driving is almost all the same from tank to tank. I have had two short trips, one 400 round trip and another 300. Neither had much interstate in them.
This is a fill up to where I see fuel in the filler neck and the milage since last fill up. The blue screen mpg has run a little different, most 1 to 2 mpg highr than what the odometer vs the fill up gives.
I have tested every car I've ever had with the reg vs hitest thing. I have NEVER gotten better milage with hight test except back in the mechanical ignition days. I usually run 3 tanks of hi test to compare it. It has always been just slightly lower mpg. This was true in my last car (99 Volvo) that had almost the same words in the handbook as reg was ok but hitest was better for performance.
So, I'm like you. Don't get these high mpgs that people say, but then, I'm not driving on interstates all the time either.
Haven't been to one of the highway test areas to check my speed or milage. The nearest one I know of is about 75 miles from here.
I intend to do so as soon as I have a reason to go in that direction.
There is one area of interstate thats only about 40 miles that has an open area with the milage post readily visable. That will probably be my first check.
But it must be off. When I drive at a steady 70 mph, most people pass me up very quickly!!! :surprise:
The speedometer, however, tests to be right on the nuts which would seem to contradict the odo being off (shouldn't they both be off the 3-4%). Tested over hundred mile increments using hwy mileage markers and a stopwatch on a few different occasions - got into this habit years ago with new cars - when speedos etc. were generally notoriously optimistic and I used to get speeding tickets!
Anyway, as per others suggestion, I will still wait and see if it improves after several miles.
Yesterday I had my chance to check out the speedometer and odometer.
Like yours, the speedometer was right on the money. With the speed control set as close as I could get it on 60 mph, over a 10 mile run of the milage markers, it took a grand totla of 6 minutes and 2 seconds. That is accuracy enough for me.
But also, like yours, the odometer was off. In 30 miles of the Interstate milage markers, the odometer had a readout of 28.8 miles. That is 4 % low.the way I figure it.
Guess that is the way they made it!!! :surprise: :surprise:
Interstate and local are hilly.
On the highway I cruise control at 70 when possible, AC LO full blast.
A little bit of other random driving for errands, weekends etc. And there's even a few seriously bad traffic jams in there.
Results:
My overall MPG (calculated) is 26.35 - measured using the odometer and actual gallons
pumped. But I do agree that the odometer reads low - so this could very well be higher, perhaps as high as 27.5, but surely 27.
After filling up with 4 different grades, I can't spot any difference in MPG at all.
The computer and my hand calculations probably average out to be the same, but on any given fillup, one may be +- 2.5 MPG than the other. I've seen it go both ways, and it seems to alternate(!) The fact that I top it off may be confusing it.
The best I've ever seen is getting right on the highway after a fillup, hit 32.3 on the blue screen for awhile. I think low 30's on a long highway trip would definitely be achievable.
The blue screen is kind of addictive, I find myself trying to coast down hills or up to stop lights to drag it out. It's amazing how a long coast can sometimes add a few tenths of a mile to what after all is an overall *average*.
Example: On my home commute, I hit the top of a hill, and then have a long slow downhill run on the interstate before I get off at this little crap exit where I usually need to break real hard and do the 25 MPH thing. But now, every night at the crest of the hill, I take the foot off the gas and cruise all the way down without gas. I can generally pick up 2-4 tenths depending on how many miles since fillup. It's kind of fun. I'm getting to know the areas of my commute where I'll get an uptick or a downtick.
Reading the Top Tier site, it's not clear to me that Top Tier gas contains ethanol. The way I read it, ethanol is added to the fuel for the tests.
I travel highways all the time. Between 48-50 MPH seems to get me 34 mpg. 65mph gets me about the EPA rated 29 mpg.
zekeman1
