Toyota Corolla Fog Lights
Anyone know where I can get a replacement fog light for a good price? I've been looking online and so far the cheapest i can find is $120 for one side or $85 for an after-market kit for both left and right sides. I only need the passenger side cause I hit a deer. Luckily that was the only damage. It's not broken just doesn't work anymore.
I bought a set off of ebay and just ordered the fog lamp switch and relay for my '05 LE. I will use the existing wiring harness 'cause its easier. I'll tell you how to do it and give you part numbers if you want or help you figure out how to make the extra wiring harness work after I get my car done.
I will use the existing wiring harness for my car. It will cost, $116.88 for the turn signal/ fog lamp switch, and $44.97 for the relay. But the instal will look stock and work every time. If you use the wiring harness supplied with the ebay Fog Lamps you'll have to find a place to mount the relay,connect a chassis ground and instrument illumination wire in side the cabin, and connect battery power, battery ground in the engine bay, route and secure the harness. That's a lotta work. The other way with Toyota parts from www.toyotapart.com is easier.
Any advice would be appreciated.
I looked for a place to connect the switch in the cabin and I can't find anything... Please help.
How did you do it mlewandowski.
1) Push out the UGLY black fog lamp covers and discard.
(Sell these things on ebay.)
2) Install the really great looking Fog Lamps that Toyota won't sell as an option. Remove the Phillips screw from the back of the new lamps, press the white plastic retainer into the small slot from behind. (Two small clips hold it in place.) Hook the gray plastic tab on the Lamp into the outboard slot and swing the Lamp assembly into position, Move the retainer as needed until the screw will mate and hold the Lamp. (Use a stubby screwdriver 'cause you don't have much room.)
3) Connect the Lamps to the existing wiring harness. Look for an oval shaped black connector taped up against the inside wall.
4) Repeat for the other side.
5) Install the Fog Lamp Relay, (Part Number 90080-87026.) in the under hood fuse box. (Lower right side of the panel.)
6) Replace the turn signal switch with the Fog Lamp/Turn Signal Switch, (Part Number 84140-02200.) Tilt the steering wheel down, remove three Phillips screws from the plastic steering wheel cover. (One brass screw is just to the right of the steering wheel tilt adjust lever, the other two are black and may be hidden by the steering wheel, swing it from side to side while looking at the cover thru the steering wheel, you'll find them.) Pull down on the plastic cover to separate and remove the lower half and push up and to the right to remove the upper half. Use the tip of a screwdriver blade to depress the black plastic retaining tab on the turn signal switch, remove switch and disconnect the white wiring harness. Install the new Fog Lamp switch, (Just line up the tabs with the metal bracket and push till it seats.) reconnect the wiring harness. Test you work. Replace the steering wheel covers, top first, This is the only part that is not a lot of fun, but it will snap back into place. Replace the steering column cover screws,
that's it. The Lamps will work every time and look like a factory option.
"Live long, and prosper"
on the lighting harness, I connected the red to red batt terminal; black to black batt terminal; blue to blue switch harness; and black ground to a ground on the chassis and it doesn't work nor does the light on the switch light up, there is still one green wire which i am not sure where it goes too, it hasn't been stripped off its cable shield.
any help will be well appreciated
I used the Vertex Racing fog lamps and the Toyota light switch that mounts on the steering column, but I didn't use the Toyota relay. AutoZone had an equivalent relay for 1/3 the price. Look for part #41-5154.
Since the LE is already wired for the fog lamps it was a matter of attaching these three pieces (lights, switch, relay) and now it's factory clean.
I can't tell you what an improvement the new lights are over those stock black plastic covers.
Thanks mlewandowski!
You can tell if the CE is pre-wired by looking up under the car behind where the fog lights go for the unused oval plug. It should be taped to the frame nearby. You'll also see an empty FOG relay position in the fuse box in the engine compartment.
If the CE isn't pre-wired, then you'll have to use the aftermarket harness, relay, and switch that comes with the fog lights. More hassle, but it's not rocket science.
help pls
pls help
1. Do you have to remove the covers underneath the vehicle to gain access to the Fog light installation area? It seems that is the only to get to them.
2. Do you need to disable the airbag system when installing the new Fog Lamp Turn signal switch.
No, you don't need to do anything with the airbag. Just remove the screws holding the upper and lower steering column cowlings and wiggle them off, then the screw holding the turn signal switch. It comes right out. Unplug it, plug in the new one, and then reverse the process.
It really is easy. Good luck.
richeyrob
1. There is no wiring where the Fog relay goes in the relay box.
2. There is no wiring to the 15 amp fog fuse holder in the relay box.
3. So I am not so sure that the new Light switch will have the necessary wiring to it to operate the Fog lamps.
4. So far haven't been able to find existing wiring to the fog lamp area.
Appreciate any assistance.
Thanks Richeyrob
So if you open your relay/fuse box in the engine compartment and look for the relay marked "fog" (check under the box lid), you should see the space for the fog relay. My fog relay location is in the lower right hand corner if you're standing at the driver-side fender looking towards the passenger side. There should be metal contacts in the box in this space so you can just plug in the appropriate relay.
If you don't have these, then your car isn't pre-wired for fog lights and you'll have to install them as per the instructions with the fog lights (self-installed wires to fuses & power, mounting an in-dash switch, etc. That just isn't nearly as nice as the plug-in process that mlewandowski and I used.
I shudder to think what Toyota would charge you to do a clean install if your car isn't pre-wired, but you may not have any choice if you want that factory-installed look.
If your car isn't pre-wired, I'm still certain that the fog-lamp-enabled turn signal stalk will just plug in and work. But you'll have to figure out the appropriate wiring harness connections to run new wire to the relay/fuse box and then to the fog lights themselves. That would be a ton of effort if you're not familiar with this kind of work and something that, yes, you probably should leave up to the dealer. It won't cost you anything to ask.
2. No. Replacing the turn signal switch requires removal of the plastic cover that surrounds the steering wheel shaft. The airbag system is not affected.
http://www.carcentral.net/content/guides/HowToInstallAuxiliaryLights.php
:shades:
Bullets
Read this discussion board:
http://www.tundrasolutions.com/forums/corolla/64686-factory-fogs-on-2006-are-eas- y/
Im hopeing someone can help me out with installing foglights on my 2001 CE....When I did some bumper work which required me to take the bumper off I noticed a wire behind each of those ugly black plastic covers, which I am assuming is for fog lights. Any help on how to install and what parts I will need is greatly appreciated. Thx in advance!
I have a corolla 06 CE and did not bring the wiring up of the relay or fog lights conectors, I already have the turn signal head fog light switch, if someone can give me reference on the installation and a wiring diagram.
Thank you for your attention :confuse:
http://www.9thgencorolla.com/forum/showthread.php?t=80578
I TOO, AM EXPECTING MY EBAY YELLOW FOGS, GOOD LUCK!
