Buick Lucerne Vibration Problems
I purchased an 06 CXL in mid June. There is currently 5400 miles on it. The car is a dream with the exception of an annoying vibration between 50 and 63 mph. The dealer has put 3 different sets of wheels and tires on this car and the problem is still there. Has anybody else had this problem and know what the fix might be?
The fact they're tried several other wheels from other cars makes it sound like something else. Did the other cars have a vibration when the wheels, yours or the originals, were on that vehicle.
I'd say it's a driveshaft or something. Call in the factory rep or try a different dealer.
Another possibility is checking alignment on all four wheels and putting it dead on center of each; none of this "It's within the tolerance range so we're not going to change it." My 03 LeSabre had toe in error on rear wheels for 6000 miles before dealer did that after rebalancing wheels twice and driving the car on a nicely repaved asphalt road that was smooth with a vibration analyzer hooked up tot he seat and to the steering column.
What brand of tires does the problem car have on it? Michelins are the best for quality and roundness.
I'm not sure what they used for balancing equipment --I will be calling the dealer again shortly so I will be sure to find out. Thanks for your help.
Michelin and Continental would have to meet the same specs for the Lucerne.
As the tires rolled up toward 25 K miles they seemed to get more even. I suspect the crush in the sidewalls evens out as the tires roll that many miles.
Early on in this GM was replacing tires on problem cars with Michelins. That was about the time I bought my LeSabre in Dec 02. That's why I'd still suggest Michelins. If they have a car on the lot they're willing to switch wheels with yours for a test, choose one that has Michelins.
That's my opinion after owning Michelins since 1967.
One note, my neighbor just bought a CXL/V8 and he loves the ride. He just got out of a SRX and is a lead foot but the car is making him very happy.
It became clear to me that the CX was the kind of ride I
prefer as it had the perfect balance between too firm and too soft. It better isolates you from road bumps and
is a pleasure to drive. The CX has 16 inch tires that compliment this type of suspension. Buick calls this "Premium-Ride". I think of it as providing a "Luxury" ride for less than $ 26,000 MSRP.
The "sportier" CXL does not give a harsh ride. It gives a slightly firmer ride and more road feel,with it's 17 inch tires and re-calibrated struts. Buick calls this "Ride and Handling." CXL offers more control so one can take exit ramps faster and practice accident avoidance maneuvers more often!
Leather is not available in CX but that is ok with me because I hate leather.( I know some must have it)
Leather cost about$1,000 more,(Hidden in the cost of CXL) Leather is hot in Summer and feels cold in Winter. Car makers must agree because options are readily available.
Another $500 can be spent on heated seats to fix the cold Winter problem and another $500 can be spent on heated/cooled seats to fix the hot Summer problem! OR, just take the cloth seats that come with CX.
Cloth is best described as neutral, not hot in in the Summer nor cold in Winter.
I loaded my car with the 3 major option packages Lots of toys for less than $2200 additional. Dual-Zone auto climate control,theft alarm, "Rain-sense wipers etc.etc. add to the convience.
Each of us have an opinion of what is the "best" ride. Some will loudly dissagre because they know what they like, I'm glad I chose Lucerne CX over the Toyata Avalon and Hyundai Azera. Now with 5 year 100,000 mile warranty it's even better.
Replacing the tires with anything that hasn't been mounted before will probably fix the problem.
I noticed my dealer drove my 03 Buick before rebalancing and that's in the TSB for the use of Hunter 9700 troubleshooting the out-of-round rolling.
Too, my Michelin Symmetrys seemed to become smoother after 15000K or so. Do they tires "relax" or become softer and become more even in their crush around the circumference from the factory as they're used?
Those interested can follow my saga, going through 3 tire brands, starting here.
HTH
You reinforce my tenet that the quality of the tire makes a difference and Michelin usually has better quality for the rolling characteristic.
FWIW, I put MXV4+ on my Bonneville, but its size is pretty rare: 235/55R17.
Part 1
Part 2
Part 3
Part 4
HTH
Double check the warranty info on the car, because there's probably a requirement to use a BBB forum, as I recall. If you have to go that route, BBB will send an independent expert to inspect the car, who may actually say it's a serious problem. Here's a website to look at on PA Lemon Law.
http://www.autopedia.com/html/LemonLaw/PA_lemonlaw2.html
Note that in the definitions sections, a "nonconformity" is defined as:
"A defect or condition which substantially impairs the use, value or safety of a new motor vehicle and does not conform to the manufacturerÍs express warranty."
Let me know if you have any questions about it.
Actually, the popping feeling and/or sound when turning the wheel has been an issue on so many GM mid-size and full-size platforms, from Chevy to Cadillac, that it's not funny anymore.
BTW, have I said that I had my Bonneville serviced twice already to address this very same issue?
GM has no fix, though there are plenty of TSBs about it. Even replacing the intermediate steering shaft doesn't solve it, it's a failed design. What others have found to work is to lube the steering shaft spline every couple of years or so. That is, you learn to live with it. :P
HTH
