Pontiac Bonneville Starting/Stallling/Ignition Problems
Hope someone can help me with a real bugger. My son's '96 SSE locked up at a light last Nov. before he shipped off to Iraq. Thinking he ran low on oil, etc. the car sat until I decided to look into it this week. Pulled pan - ok..Found it to be hydro. locked on #1 (egr pipe came out of plenum, which melted through coolant passage). Pulled all plugs & checked compression - all around 150 with fair battery. Replaced intake manifold gaskets, plenum & all other related gaskets. Now, engine won't start. Occasionally get random firing, that's all. I have spark, injector pulses, 45psi fuel rail pressure. Checked & rechecked for a connector I missed. Any ideas? I'm thinking stale gas would still allow car to start. Hoping I didn't jump a tooth on the timing gears, but don't know if I would have this much compression. I should note the security light is on, but it was on with car running ok last year. Any way to disable that? Thanks!
1) You said "no start". Does engine crank or not?
2) Security Light probably not thee issue as you have fuel pressure.
1. Yes, engine cranks like crazy. If I open up throttle wide, it sounds like it wants to catch, bu no dice. I just bought a can of starter fluid (in case gas is stale) & gave it a shot in the intake rubber between throttle body & air cleaner - no difference.
2. Yea, I opened up the owner's manual & learned the same thing. Ignition key can't be it either as it cranks.
I'm starting to worry that the sudden stop of crank either allowed cam to jump a tooth, or perhaps the vibration dampener slipped(?) That is where the tone wheel is for the crank sensor, no? I worked for Oldsmobile up to '88 & remember something about them, but have forgotten a bunch as well...
1) Damage to vibration damper
2) Timing chain and/or sprocket damage
3) Failed Crankshaft sensor
4) Failed Camshaft Sensor.
5) Failed ECM
Good Luck!
One thing I'm going to do is pull the dampener to check the crank key. That would seem to be the weakest link in the picture to me. I'll post whatever I find. I'm taking the night off of this one...:)
It would be broken wires in the steering column, it could be dirty contact wires in the ignition lock, it could be...
You can put alcohol on the key chip area and put it into the ignition lock several times to get alcohol in there to clean the contact wires. It may help.
There is a way to cut the wires going up into the the steering column and replace the key at the top with a resistor at the bottom to make the box read the right resistance.
Was the tilt column moved up and down a lot? How many miles on the car?
The resistance system is called VATS if you want to search for info on the web.
Do you have fuel injectors working during cranking?
Do you have fuel pressure?
Next door neighbor just had a 97 Monte Carlo with 40K that lost its fuel pump. It had sat a lot in the garage and was driven on low fuel levels most of the time since he inherited it from his dad.
The car has 117K.
I did try the alcohol with no result.
It could have been the tilt wife was the last one to drive the car... I know should not have let her get behind the wheel...
I will check out the VATS system on the internet.
Thanks again...
http://www.12vp.com/info_resistors.htm
These two links may help.
Send me an email and I can send you some other links to help you learn how to do it yourself it you're interested in on the floor work! Email is in my profile info; click on my name in the message title line to see the profile.
I stopped to make a left turn a few days ago & my engine died while idling. & now it won't start again & the power brakes & steering won't re-engage when I turn the key (the other things come on -- lights, fuel pump, radio).
The engine has been having problems idling & cruising (+ acceleration hesitation) for some time now whenever the gas goes below half a tank. It wasn't always this bad, it used to last a whole tank & gradually started showing problems w/ more fuel in the tank. now it's up to half. Before, the car has killed once or twice w/ the same problem but has restarted & been fine after I refilled the tank.
I think the problem began a few yrs ago when I left the gas cap off for an extended period of time (for maybe a week or so). Immediately after that my engine would start whistling when the gas got within 1/8 of a tank or less. At the same time, my gauge went out of whack & seems to be off by as much as a 1/4 of a tank, depending on whether I'm cruising, accelerating, or idling. This time after it died I was able to add 12 gallons before it was full, although the meter said gas was just under half full.
I can hear the fuel pump come on and it was replaced w/in the last 40k mi, so it should be working...
I just changed the fuel filter hoping it would help, but the thing still won't start. I think my fuel may be contaminated.
Does anyone agree? I think I should drain the tank & refill it (at the same time maybe add an engine/ignition system cleaner). But before I drain the tank, are there some easy things I should check? The Haynes manual has a few suggestions for erratic idling, but my problem is pretty specific w/ the broken gauge & the car crapping out when fuel level is not high.
just for the record I have 184k mi on it. Oh, 1 more thing - the car is parked behind a gas station, so I'm trying to fix it before it gets towed (or before I have to have it towed).
thanks.
It rained at one point when the gas cap was off so I suspect that dirty rain may have gotten into the tank.
It's always been strange that when I refill the tank all the way there is no problem, but only when the fuel becomes closer to 1/2 or 1/4 full there is a problem.
If I drain the tank what should I do with the gas that comes out? It's probably bad (or illegal) to just pour it down a normal drain).
thanks again
Well, after spending this morning pulling timing cover & finding everything ok (all steel cam gear btw), I put (front 3) fresh plugs in & removed the springs from the cat. convertor pipe just in case the antifreeze got in & plugged the catalyst. Engine started right up, ran rough for a bit, then cleared. Re-connected cat. & still ran good. Even though they looked good & having checked plugs on two cylinders outside the engine while cranking, I figure the electrodes were shunting in the cylinders. Rule of thumb - never ignore the simplest measures......
Check into the ends of the cables for corrosion down in the copper wires beyond the ends. Some acids from batteries have corroded cables down in.
It sounds like you're getting reduced power as in poor connection. Occasionally a battery post has broken inside the battery causing a make and break contact situation.
Is your battery good? Have you tried jumping the battery?
I replaced starter on 98 and it had given weakened sounds occasionally for a year like I had a weakening battery or poor charg9ing. Turned out to be the starter. Rebuilt by Delco authorized local store. Guy mentioned that solenoids die because of oil leaking into them and their contacts from oil hanging on the edge of the oil pan... Mine had very little but there was some. I never get a drop on the driveway...
135000 miles and lots of short trips on the car so lots of starts.
P.S. I did try to jump as at first I thought it was the battery.
