MINI Cooper Clutch & Transmission Questions
At 3000 miles I had to have my entire clutch system replaced (under warranty). In stop and go traffic on a slight incline in 1st gear the car wouldn't move. I also had and still have a horrible time getting my car in reverse. The MINI service people tell me that is just normal. Now at 12,000 miles my clutch did the same thing. On a slight incline in bumper to bumper traffic the car wouldn't move... The MINI service people drove the car for 20 miles and found no problems. I know better. Now they want me put down $2000 to open the thing up to see if its a warranty issue or the clutch needs replacing. Is this a rip off or what? I have had clutches for the past 30 years and never once had to replace any for the lifetime of the cars. I don't ride the clutch or abuse it. Is this normal? If it is a MINI isn't suited for bumper to bumper LA traffic. I called the MINI rep and I am waiting for a call back tomorrow. Paying for a new clutch is unacceptable to me. Is this to be expected from a MINI?
Any suggestions?
steve_conant@yahoo.com GLAD to discuss this w/ you.
What can we do? I was going to pull a fuse, but couldn't figure out how to remove the large, green fuse for the battery. Advice on how to do that?
ALso, is it the cooling fan or the power steering fan? SOunds like the bigger of the two... Thanks for help. -- G
Aside from being thoroughly infuriated, I really need to know if I have any recourse here. The clutch should not be gone after 30,000 miles. I don't know how it was driven during its 7,000-mile life as a loaner, but even then, I can't begin to comprehend that this is our fault.
Any ideas? I'm continuing to scan these messages about service bulletins and what not, but any direct advice would be appreciated.
I'd work with the dealer and escalate up and try and get satisfaction, but the 24K miles the car has accumulated in your hands are going to work against you. They may be willing to take it apart and make a judgment call on whether it was a defect, abuse, or simply wear/tear. The first they're likely to pay for, the 2nd you, and the third, they probably will suggest a sharing of the repair cost.
Good luck!
- Mark
I think the CVT is the achilles heel of the Mini drivetrain. It mimics some of the negative characteristics of a manual transmission without any of the positives. :sick:
- Mark
While i'm very pleased, a clutch should not go at 33K...esp driven only 10K per year, much of it highway. so...be vigilant...
you asked to have it towed?
My clutch went up at 28,000 miles. I had AAA tow it
to the MINI dealership. They pulled the transmission
and now they tell me that even if I don't get it fixed
I am in to them for $1,700!
Tom
cosgrove.t@att.net
I had the clutch changed at 45,000 miles for the first time.
Clutch lifespan can go out sooner depending how you drive the vehicle (Clutch yoke noisy and worn out clutch). Lucky I was covered under a 50K warranty when I purchased the car.
A normal clutch in other car's can get a lot more mileage than 45K miles. I now have 48,000 miles on the car.
Some of the most common problems I have experienced is with the Mini Cooper S (manual transmission) not of the routine kind of things of owning a car.
1) One of the first problems I had overheating problem with engine at 10,000 miles.
2) Rear latch on rear trunk never locked (needed replace latch).
3) Idiot lights on dash tire flat (Motor wheel rotation sensor) you hit a pot-hole it stays on very common and sometimes for weeks off and on.
(Computer software glitches of some kind)Airbag idiot light stays on all the time now.
The Mini dealer service told me eventually they will come up with a better software upgrade.
I've learned to live with idiot light on the dash being on or off so don't be alarmed if you see them.
4) Cooling fan to engine kept turning never shut off then drains battery overnight. Mini dealer had to change both Cooling fans which they were very reluctant when its under warranty.
5) Brakes last 20,000 miles about on the front and 30,000 miles on the rear.
6) Clutch problem at 45,000 miles.
7) All Tires replaced.
Yeah, we all have problems the Mini Cooper S but I would rather own a Toyota Corolla that I have as a second car with 250,000 miles and never had these kind of problems with only 48,000 miles. If I keep the car for another 50K miles will have the same problems again plus more.
The tow truck driver who came to load my Mini cooper to the shop say most Mini's he towed are transmission problems and overheating problems.
I drive my Mini Cooper S 2002 about 10,000 a year....so most of the time its parked and really has not much chance for a hot running engine.
I happen to get on my Mini Cooper 2002 S 45,000 miles out of the clutch before it broke. I have had many Volkswagens in the past I got at least 95,000 miles out of a clutch. I drive a stickshift like you would think its an automatic transmission ride. The shifting is smooth and you never realize its a sticksift car since I had many clutch car's in the past.
This car has more problems than a normal running used car you buy off the lot.
I personally, would stay away from these cars until they make them much better and realiable.
They just are not working on the problems that the first models had and now they still have the same problems on newer models.
Buyer beware, its still an experimental car with lots of bugs to be worked out even in the latest models.
Replacing is will cost me almost 1/3 of what I paid for it...I don't know what to do. Any suggestions/similar experiences? I'm leaning towards getting it fixed and then selling it. I just wonder if it's even worth getting fixed at all.
colleen
ctm3267@yahoo.com
There is a awful sound everytime you take off or back up. The response from him was "oh that's coming from the clutch, it does that after awhile, we can tighten it but the sound may come back again."
Every time I call dealer or check online there does not seem to be any recalls or similar problems with other Mini's. Anyone else experiencing this problem?
The transmission went out on my MINI too. Mine is a 2003, automatic, with 33,000 miles. I bought it used a few months ago. I was so excited about owning a car that was built this century! I still love the fuel efficiency (31 mpg SF down to LA) and the heated seats and fitting in tight parking spaces. Unfortunately I’m back to thinking of cars as a huge drain on my money and time.
Short version: the transmission was replaced and covered under the warranty even though the warranty expired about a month earlier. SF MINI Dealership cost estimate was $5,000. They replaced a tail light free of charge and they provided a loaner car.
I’ll post a longer version of the situation in a minute.
Reading other posts on the forum makes me concerned that the transmission is just the first of many issues with this MINI. At this point it would not be cost-effective to sell, but the warranty won’t cover problems 3 months/years from now
Colleen/ctm3267 - If you’re reading this, I’m interested to know what you ended up doing?
Taj
We called up SF Mini dealership (where they had just completed the 30K mile tune-up). They immediately said they would take a look and if it was the transmission they would absolutely cover it under the warranty, since it had literally just expired.
Short version: it was the transmission and it was replaced under warranty. Dealership cost estimate was $5,000. They replaced a tail light free of charge and they provided a loaner car.
Longer, venting version: Looking back a few months/years from now I will probably only remember that we didn’t pay for the transmission. But since it’s still fresh . The customer service was AWFUL:
We dropped off the car after a 12 mile, $100 tow. After four days of no news and no returned calls, I finally got through. They said they hadn’t even looked at it yet. Service Rep#1 offered us a rental car for $25/day. We got a better deal on our own. I finally got through after about a week of no news and no response to multiple phone calls. Service Rep#2 said “oh no, I would have given you the loaner car at no charge” and “we can’t find the problem.” So we dropped off our rental car and picked up their rental car. After 3 days of no news and no returned phone calls, I got through. They said they found the problem. After four more days of no news and no returned messages, I got through to the receptionist in the late afternoon. The car had been ready for pick up all day.
Summary: They had the car three weeks. We are out of pocket $260. We have a new transmission.
I’m now considering 1) keeping the car and hoping nothing else goes wrong, 2) selling it and getting ????, 3) selling it and getting a new MINI with a bumper to bumper warranty and upgrading my road-side assistance plan.
Any thoughts/comments/suggestions are welcome.
But even after the transmission is replaced (w/re-built one), by reading the Forums here makes me worry. I, too hope nothing else goes wrong....
What kind of problems have you had with your transmission? Has it already been replaced with only 8,000 miles on it? I also have a Mini (2006) with an automatic transmission with the same mileage as yours. So far everything seems to work fine, but now I'm a bit worried after reading a couple of complaints from this Forum. :confuse:
What kind of situations are you having with your Mini? I'll have to be more attentive on my MCS to see if I experience anything unusual. I'm thinking it would be a good idea to buy the extended warranty after what I've read here.
Is there anyone out there that has higher mileage (50,000 or more) on an automatic transmission with no problems?
My 2005 Mini Cooper's auto. transmission was replaced with a re-built transmission.
One day I noticed that when merging on to a highway,(going from 30 to 60mi/hr) it jerked and hesitated for a second. But it drove fine once going. Then few weeks later, I could not drive any faster than 25mi/hr on a slushy road, I first thought it had something to do with the Dynamic Stability Control. (I must admit my knowledge in auto-mechanism is very limited...) But once towed to the dealer/service, they said it's "defect transmission"..... It is running great right now. And I found that the MINI Customer Relations reps are very helpful.
Since I DO love driving my Mini, most likely will buy the extended warranty when the time comes.
Thanks replying so quickly to my inquiry about the problems you've experienced. I'm sure I'm not the only one who appreciates the fact that you shared your misfortune. At least it'll give me a heads up to look out for anything usual.
I should buy the extended warranty for peace of mind. However, I may buy a new Mini in 2009, so I'll just have to wait and see how many miles I'll have on my 2006 by then. Thanks again for sharing... May the rest of your driving experience with your Mini be uneventful.
It took me a while to decide after owning 2 Toyotas in the past.(Both drove it over 100,000mi) But I just love how MINI drives, no comparison when it comes to "Motoring"!
I guess you need to ask yourself how long you plan on keeping the car, 3 yrs? 10yrs?, then get the right warranty and ENJOY driving! I admit that after the transmission problem,I am bit worried but personally, I don't wish to go back driving a Toyota. Good luck and let me know what you decide! Zippco
It's been a bit since the transmission was replaced, so I wanted to post a quick update. My husband and I haven't had any new problems and the difficulties with the dealership are quickly becoming a distant memory. Even after all the hassle, I agree with a few of the other posters that it's just a lot of fun to drive! And I love fitting into tiny parking spots! Despite this rough start, our next car may be another MINI.
Thanks to everyone who posts here. It really is a great resource.
Taj
The following is to voice a technical concern (get some answers) rather than a customer service complaint against the dealer or service manager. I hope that a person with the proper technical background can provide a clarification.
Our Mini has been making this squealing -grinding noise, mid clutch release, mostly when vehicle is cold and in first gear (when need engine torque to move the vehicle fm idle). When the noise occurs you can feel it in the clutch pedal. Once the car has been driven for over 30-40
minutes this noise/condition is not reproducible. Because of what I have just described, I took our Mini to the dealer, the customer service manager knew exactly what I was describing to him. I was told that this
is a well known GLITCH with the MINI's clutch system, and that there is no repair for it, just keep observing. If anything I do appreciate this man's honesty in sharing this information. I have been a driver of 35 years- driven many stick shift's, the only
time I have ever heard a noise like such is when a clutch is getting ready to be replaced and well into the 90k miles. We, that is my husband and I, purchased our MINI hoping to own a piece of great German (BMW)-English engineering that is affordable. Needless to say our hopes regarding the quality and craftsmanship of your products has been
shattered, by the fact that it does not appear your engineers are finding a solution to this GLITCH (I was informed this has been a common occurrence for quite a few years), thus eventually, having to replace a
clutch at 40k miles at the customer's expense (not covered in the warranty). I believe BMW can do much better than this even if the MINI is not one of your HIGH END products. You don't have to be a seasoned mechanic or engineer to figure out that something that is grinding, is not working properly, even if it does not happen every day or 1-4 times
on the day it happens, that a grinding noise means release of shavings (damaging to any mechanical system) and uneven wear or damages to a particular part in this case could be the clutch plate, CLUTCH RELEASE
THROW OUT BEARING( shavings/dust could affect this part) or fly wheel.
is a well known GLITCH with the MINI's clutch system, and that there is no repair for it, just keep observing. If anything I do appreciate this man's honesty in sharing this information. BUT IT DOES NOT SOLVE OUR PROBLEM... :mad:
Sorry to hear about your 02 Mini....I don't blame you for wanting to get rid of it. But still have to spend the $$$ for the repairs...Have you contacted the MINI customer service? I'm not sure what they can do but they may have suggestions. And I believe they need to hear about these problems from owners!
After replacing my 05 MINI(auto)transmission at 8K mi,(under warranty)and now at 10K mi, so far it's been smooth running. I plan on keeping my Mini for at least 5 more years. Has anyone out there purchased an extended warranty before 5yr/50K warranty expired? And wondering if you used it.
