Audi A3 Suspension Questions
2»
    Yep, feathering would certainly make a tire noisy. Some tires seem more prone to this than others.
    The common cause is incorrect toe-in (alignment problem). it's also possible that there is some worn front suspension bushing causing things to shift around.
  • andres3andres3 Member Posts: 14,064
    while coming to a stop from almost a dead stop. You know that last second where the car goes from 1 to 0 MPH and the weight transfers and the car bobs a tid bit. I'm hearing noise now where once there was no audible noise.
