Any way to boost the DIC brightness? I find during Daylight the display is virtually impossible to read. My exterior lights are working properly (dimmer control is not affecting DIC brightness during the day).
Was this something that was changed/improved in later iterations of the Malibu/Maxx l (mine is '04) ?
I don't know if a later PCM calibration would change this or not. I don't think you ever had your PCM reprogrammed so you probably have original software. However if everything OK up to this point.......
If this were to happen on 2 consecutive ignition cycles your Check Engine Light would have come on.
Engine cooling fans coming on is just a response of system to this uncertainty about engine temperature for that ignition cycle
On the sedan it is much easier to access. You don't even need to use any tools!
Reason? After very intensive vehicle shopping, I have found it very hard to find anything like the Maxx, which goes bye bye after '07. Trouble is, if things have not changed, the only Maxx with "braking" traction remains the SS, which I can't consider due to its high fuel use.
One of the changes to Maxx for 2007 though is Hydraulic power steering on that model
You once told me the SS Malibu has a better traction control, but SS's too weak wrt turning circle, MPG (worse than the V8 Impala, for crying out loud !!), ride, etc. to consider.
The only way I would seriously consider an SS Maxx is if I could have the final drive ration of the SS Malibu sedan, which is, I believe, the same as what is in my current Maxx. But I don't know if changing final drive ratios is possible, let alone feasable/affordable.
I'm hopeful '08 Vue and Equinox will do better in this area and carry on the Maxx spirit. Supposedly in '08 the Equinox will finally get a decent engine!
Now that all these electronics are tied in, I do not know how many things will be "reset" once I disconnect the main battery to replace it.
Reason for replacement is the battery had one very deep discharge (no frigging detection of headlights being left on for too long when the vehicle was stopped/engine off), the current battery is well past 3 years of age and has been subjected to very hot S. Calif summers.
comments/suggestions?
Likely after doors lock the ignition switch is truly OFF and so doors aren't going to Unlock automatically.
Dealer does have ability to read the status of all 4 switch input from the Neutral Start Back-up Switch (what you call park/safety switch) using a scan tool. Monitoring those signals when this happens might be informative.
Removed light cover and checked bulb, bulb filament is intact. Went to the rear fuse center and checked the fuse, fuse intact. Tested the rear power outlet with an accessory adapter, no juice. Used a multimeter to check both the cargo light fixture leads and rear outlet leads, no juice.
I was wondering if anyone had any suggestions on how to proceed. I'm not a gearhead, but tinkering with this car may turn me into one.
We bought our 2004 Maxx new, now 50,000 miles. This will be our first after warranty repair. Great car.
replacement took about 20 minutes...simply lift the hatch...remove the plastic liner piece..a quick pull unsnaps it...there are two screw caps that you can access with needle nose pliers....and the unit comes right out...plug and play....reverse the installation....note how the rubber liner sits around the light on the outside before you take it off...and make sure its the same after you reinstall the light....I have had no leaks at all....
I understand the fuel filter in the tank does not require servicing. Does anyone, such as Ehelper understand how that works? I cannot help but believe that a filter has unlimited capacity to store crude without leaching some of it out eventually into the gas line.
Thanks again PAO. Keep leading the charge on to 100,000 miles. The rest of us will watch with interest in your rear view mirror!
PS: average mpg by the DIC, however, is consistently between 25 and 28 30% town driving in NW MN.
The cargo light inop....do other interior lamps (like dome lamp) work? There isn't a fuse in rear center for interior lighting although that is point at which power is fed to it. I would have expected more of a problem on ground side to the lamp than power because it is a little more complicated on that side.
I could have sworn that when I first got the 2006, the key functions worked the same as they did on my 2004 Maxx LS. On the 2004, turning key clockwise first time unlocked driver door, second time, unlocked rest of doors, third time unlatched the hatch, Turning key counterclockwise locked all the doors. All locking and unlocking was done electrically. On 2006 the driver door lock/unlock with key is mechanical.
It is likely if your 2006 vehicle operation changed it was due to a BCM replacement or maybe even a programming update that occurred.
1. AC sometimes starts off blowing HOT air - So far, stops if I turn it off and restart it.
2. Individual gauges will stop working from time to time - Once fuel, temp x 2; they all restart eventually.
3. Drivers side window control inop for a day, then started working again.
As you said, kinda scary - I have no idea what would cause this, and since warranty is passed, I assume I'm basically screwed. MY wife wants me to get rid of it, but other than this, I love the car!
It's a connector underneath the dash that's been on all cars since 1996 I believe. It's that place that you plug in computer diagnostic tools and it returns a code that tells you what's going wrong in the car.
I forgot to mention, when I got to work the wiper was woking fine.
I am new to this forum and plan on towing my 06 Maxx behind my RV.
The manual says to remove one fuse Ignition Senser (2amp), I did this and the ignition was still engaged and I could still start the engine.
What does this particular fuse control??
If that sounds weird, how about this. My alarm automatically arms itself all the time. If I shut the door to refuel and open it up again to get back in, my alarm goes off. This is getting pretty annoying. Please help. I am pretty mechanically savy but am at a loss on this one.
Kevin
