Kia Spectra/Spectra5 Transmission Questions
in Kia
FYI....
If anyone with a 2004.5/2005 Spectra experiences any shifting issues
with their transmission (esp, from 2nd to 3rd under heavy throttle) there
appears to be a known problem with the transmission's computer/brain.
It has been reported on another KIA Spectra forum that KIA has replaced
the transmission logic module on some poster's cars.
It appears that this problem is fairly rare, but it has been reported
by more than just one person. One person's experience was for the dealer
to reset the transmission's program by unhooking the battery, and then
having the owner run through a slow/medium/fast driving regimen This
helped the person for a short time, but then the problem reoccured. KIA
replaced the transmission's computer and the poster reported that their
car acts completely different... for the better!
My 2004.5 car's AT appears completely fine, so it must be an isolated
issue OR a problem that began after a later programming tweak in later
2005 production (perhaps after some programming adjustments to help
improve the Spectra's gas mileage???)
The 2006 model supposedly is getting a whole new transmission design,
so time will tell how well it works out.
So, if any of you experience any problems with your AT be sure to tell
your dealership that KIA's aware of the problem. There may even be a
TSB for this in KIA's warranty/repair computer system.
I seems that car is locked. I need to release throttle and then press gentlely.
I would have to say that, aside from this issue, the car is absolutely fantastic. I have had no other issues and I have 19,000 miles on it.
I've experienced some "gear hunting" (As Car and Driver calls it when they review cars) between 3rd and 4th under full-throttle... esp. if I'm starting to leave up a bit on the gas because I'm coming up on some unexpected slower traffic. The car sort of surges or bucks between the gears for a split second, and ONLY under heavy accleration. After a couple of "hunts" or switch backs, 4th gear then engages and you keep going. This doesn't happen every time either, FYI.
But I've never had it act so weird that it freaked me out or made me think that something was truly amiss.
Was this the first time your car did what you described? Did you have any of the "gear hunting" symptoms earlier?
Can you describe in a bit more detail exactly what happened? When the RPM surged on you, was it still in 3rd? Did the surge cause you to acclerate even though you had lifted your foot off of the throttle?
My car has 18k miles on it, so it's in the same mileage neighborhood as yours. That's why I'm curious as to whether this is a recent phenomenon in your car or not.
Can you experiment and see if you can recreate it, and report back here? Yours is the first 2004.5 that I've read is having the problem.
-SM
I noticed something completely different with the transmission when I first purchased the car. If I did a rolling type stop (yes, I'm guilty) or had to yield and almost came to a stop, the transmission would not down shift and it would sluggishly accelerate unless I really stomped on the gas. I just sort of accepted it as "the way the transmission was designed" and I now anticipate it so it's not that big of a deal. The other problem that I posted has also been going on since the very early days of ownership. I kind of blew it off because it was so intermittent. It's been happening much more frequently now--and it's more exaggerated than it used to be. That's why I was concerned enough to post it. If your transmission has not been doing this by now I would say that you are safe.
By the way, the surge comes right before it shifts from second to third. Sometimes, if I have to let up on the gas right before it shifts, there will be an uncommanded surge in RPM as it prepares to shift then "relaxes."
I'm sure that some of what I've described is typical of any automatic transmission (to a certain degree anyway) but this is beyond anything I have ever experience.
I know what you mean about the Spectra not downshifting all the way back down to 1st when doing rolling (or complete but brief) stops. It really makes the Spectra seem doggy.
But... use the manual shift method of pulling the gearshift down to 1 and then shift through the gears manually, and the car scoots right along.
I suspect that KIA doesn't want the car to always shift down to 1st for some particular reason. Perhaps fuel mileage, emissions, etc.? The Sentra rental I'm driving right now seems to always be in 1st when I stop and take off again. I'm driving the same route, so it's easy to compare the two cars performance-wise.
I will say this... the Spectra 2.0 in my car is a much quieter and smoother running engine than the 1.8 in the Sentra. The Sentra has a timing chain instead of a belt, so that adds a bit to the noise factor.
-SM
My Kia transmission also does not like to down-shift when ascending hills, worry to press the gas to get it to downshift. Other than a bad O2 sensor, I have not had any other problems. I really like this car!
If you think the issue is worth reporting visit the Kia website and submit a complaint. I believe you can also just call them directly at 1-800-333-4542 and select option number 3 to speak to a representative. They need to get feedback on this issue and they don't always get it from service departments.
I was thinking of taking it to the dealer,but wasn't sure if it was a warranty item,being that i'am the second owner of the car. mine is a 2004.5 with 9000 miles.
TR4000 - impossible shift
TR5000 - shift delay
TR6000 - shift shock
TR7000 - abnormal shift
TR8000 - slip when shifting
TRN001 - Noise
TRN002 - Vibration
TRN003 - Others
There was another reflash listed as a tsb but was for a light on with no real fault.
To see tsbs and info go to kia.com and then to Kia Owners and then to to Service Information. You need an email and password. I established these back when owned 2003 Rio. If you cannot get in write to me. George.
Thanks a bunch. I checked out the site and signed up so I could view what you described. I'm just glad to see that a TSB is potentially on the way for this issue.
The steering was also making a loud clunking noise when turning the steering wheel. They replaced some part for this. When the dealer called and told me the transmisson had been replaced but the steering was still making the clunking noise and what did I want him to do I TOLD HIM TO PUT THE CAR BACK TOGETHER SO I COULD TAKE AND TRADE IT IN! Upon getting my Kia back, I drove immediately to the Mazda dealer and traded the Kia in for a Mazda3. NO MORE KIA's FOR ME.
The mechanic could not find a leak.. and said to keep watch on it.. well I looked at the engine did not see the ATF dipstick.. where is it located on the Kia sedan? I have a 2002.. It seems to still be hesitating when I put it in reverse.. its only been 2 weeks since they filled it and with no leak how can it be low again.. should I be worried? :confuse:
Also just for information sake...always get a service order on your car even if the tech. just drives it or fixes the problem without making you wait. Mine did not have any record of my being in the shop until 35k miles eventhough it had been there and I had them drive it dozens of times in the first 6 months of ownership and I bought it new. Was told each time that this was just the way a Kia drives and changes out. So Beware. :lemon: This was a crown kia in anniston alabama.
I have a 2002 Kia Spectra , automatic trans. I had it in for service (77K miles) and had them change the transmission fluid. Now the check engine light is coming on ? They reset it but it has come on again. I dont know how much experience they have had with Kia's ? Is there anything in particular that could have triggered this ?
Glenn
I am suspicious of the place that did my transmission fluid change, thinking they maybe used the wrong kind? anyone else have this happen before? what can i do? i think there are now several problems and most due to the wrong fluid being put in. is there a way to test the fluid to make sure it is the right kind for the vehicle? :confuse: :sick:
This happened in winter of 2008 and now agin this winter--several times! HELP!!
It is a design flaw in the 5 speed transmissions.
The only thing I could suggest as a bit of a long shot is to use synthetic gear oil of the proper weight (who knows what they may have put in there?) and see if that helps.
If it doesn't, you have worn synchros.
I have a 2004.5 Kia Spectra and I am glad that I saw this forum because we have been racking our brain trying to figure out what is wrong with it. I began to surge and RPM's stick as we drove it on the highway especially after the slightest wind pocket and feather the gas to get it to go upon a stop. Initially We had taken it in to a corner lube and tune for an oil change and they sold us a fuel injection cleaning that it didn't need. No check engine light would come on until it came on for the TPS. Anyway, after that the Kia dealership in our town reported that they couldn't find anything wrong in 2013 but came up with a long list of things we needed that we really didn't need because all of the items had been taken care of previously. Haha! We finally took it to a mechanic who is a czar on cars and we went ahead and had them recheck all of the lube and tunes work and those things the Kia dealership recommended- everything was fine. After internet research, had them replace the fuel pump and relay switch which helped but didn't totally resolve it. Then the variable valve timing solenoid (due to the check engine light coming on because of the TPS (TPS was fine)). Variable valve timing solenoid was found to be a common problem with the Sedona's. This does make the car ok if we take surface streets and no wind pockets and no faster than 40 MPH or so and press the gas a certain way otherwise you have to feather it to go. No shaky feet on the accelerator haha! Maybe this has been a part of the problem all along. Thank you!
