Chevrolet Malibu Maxx Problem Codes/TSBs
The TSB that a lot of us have been waiting for was released June 13, 2006 - "Knock, Clunk Rattle Noise from Front of Vehicle While Driving Over Bumps at Low Speeds (Diagnose and Replace Steering Gear, if Necessary)"
Partial summary:
2004 - 2006 Malibu/Maxx
2005 - 2006 G6
Noise may be generated during contact between the rack gear and pinion gear. The EPS motor holds the pinion gear from rotating and the suspension input drives the rack gear into the pinion gear.
New Part Number: 15858368 Steering Gear Assembly
Off course the part is on Nationwide back order...
Partial summary:
2005 - 2006 G6
Fortunately I have Major Guard, which supposedly covers that part.
still very much love this car....will hold it for another two years....at that point if no major issues...will just keep it and look towards a new replacement....waiting for the HHR to come out with their turbo...or maybe even one of the sabaru legacy sport wagons.....but a long way off from that decision....
Small draw-back is that it seems less willing to center itself after a turn. May get better with time.
Drove over a rough road last night that used to rattle the suspension - night and day difference now. Feels like a different car.
I took it in mainly for the brake problem with seemingly warped rotors. I also asked him to check a rough idle and that sometimes it seemed like the power steering would go out. It usually happened in parking lots at low speed, so I thought it might be idle related, or even causing the rough idle.
The service guy called yesterday and said they were going to do a light turn on the brakes and had to replace the steering gear. I guess I'm getting luck in some ways that they are replacing it, as I definatley had the clunk, but just blew it off as this is not a lexus or infinity!
Anyway, he called back today and said the steering gear is on "national backorder" and that I could not get the car back. He offered to get a rental for me (As I guess the old gear was torn off and not useable), but fortunatley I am travelling with my big car (2000 Chev Suburban) for a few days and said I didn't need one.
I'll let you know how the backorder process goes, but I am very happy that the service advisor is basically fixing it right the first time!
Also, my CD changer quit working the other morning but in the afternoon it started again. Any similar experiences?
Thanks. Great to have this list to find people who understand these cars.
I have had this done and it solved the clunking noise (even though it is not what I was complaining about, but I did have the nose and feeling of the front end was going to come off). My concern is that it is going to continue to happen over time. Anyone know?
That makes me feel a little better about it.
Have about 4,000 miles on the new steering gear. It has loosened up a bit and "clunks" a bit turning in/out of the driveway. However, it remains much much quieter than the original - especially on gravel or rough roads.
Will see if dealer will understand what the bulletin is, and if they will do anything.
Does the TSB mention parts that GM actually replaces, or is it merely an advisory that the disks will warp due to bad wheel torquing?
How can I get that TSB 00-05-22-002H without subscribing to AllData?
Turning of rotors to correct lateral runout is covered under original 3/36 warranty.
Dealer told that rotors are covered 12/12 and
tried to charge me for repair. Never happened thou...
Larry :-)
If so you might be dealing with a software issue.
To your knowledge has dealer recently updated software in engine controller? There is likely an update although it would have been done per a TSB to address a long crank condition and not your complaint. However it might also resolve your complaint. If I can find out more I will
Larry :-)
This condition was probably always present, not due to anything they did - just takes certain conditions to show up.
What I was saying is there there is a potential that this might be cleared up with latest calibration.
Larry :-)
Larry :-)
What it did not mention were any replacement rotor parts to address the problem. So I guess the rotors, at least to date, will remain relatively flimsy and easy to warp.
Local dealer also printed out hot starting problem TSB. The report hints that the problem might be related to a Delphi EGR valve (saying that the vehicles with Siemens EGR valves already had newest calibrations). I'm to go into dealer tomorrow to see if they will recalibrate my '04 Maxx and if they do it, whether or not it helps.
Cheers
Pete
