Chevrolet Malibu Maxx Engine Questions
We bought the brand new '06 Maxx LTZ in April, and 4 days (yes, 4 DAYS) after we bought it, the battery died and left us stranded at Best Buy. The dealership put a new battery in it the next day, and it has started fine ever since. Now at 4 months of ownership, it occasionally takes longer to start. You have to hold the key over, and it will crank like out of beat, and then start. This has happened with the remote start and manually. It did this right before the battery died, and so we have taken it to two dealers (it is at one as I write). If this odd starting happened once month, I wouldn't be as concerned, but it has happened 4 times in the last two weeks. The deal just called and said that it is turning over perfectly so they have done nothing. I have read on other forums of people having this occurrence occasionally with a Maxx, and was just wondering what I should do. If it doesn't come up on the scan, is there a problem? Thanks for any advice.
PS; We love most everything about the Maxx. We just don't think we should be concerned about a brand new car starting.
This seems to be "normal" and there is no fix yet(extended hot starts). My 2004 Maxx will do this a few times a week. It always starts on the first or second try, but makes you a little nervous when it cranks. I have just gotten used to it.
I have read that this is "normal" in another forum, too. Mine started funny three times in a row last week, so we were just nervous about it since the battery had died after 4 days of ownership. This starting thing happened a few times before that, so we just assumed it was related to a dying battery.
I took it to another dealer yesterday, and the guy hemmed and hawed about it since they had tried to duplicate the problem all day to no avail. Finally he said, "It should start right up. I would watch it."
No one should have to be worried about a new car starting!
We are happy with the car overall. This is the first new car that we have bought in 10 years. It really scoots along and even my elderly mom liked riding in the back seat.
So far...
"The car has been to the dealership 7 times, 4 just for the issues with intermittent starting issues (not associated w/ remote start even tho it does happen with that AND manual starting) that are not related to a bad starter, it's somewhere between the starter, the computer and the cyl or plug that should be identified by the computer to fire/start. The dealership I've been taking it to has no clue. So far they have replaced hood release, block assembly wiring harness, coil for air bags, roof molding, and control switch on steering wheel. Not all associated w/ my starting issue, but other things they have found. This car is just over 3 months old, and about 4000 miles. I'm livid with all these issues. Under VA law I'll be able to file for lemon law issues if they don't resolve it while it's in the shop right now for it's 4th visit."
4th visit ended, and it still persists. I'm SOOO aggrivated.
AFAIK based on my talks with the shop foreman, the service manager and the customer relations manager ... they are getting the run around from GM (my impressions of our discussions) on exactly what TSB's should be or should not be applied to my car.
Do you have the exact TSB #of the one you state that probably is close to this issue? Perhaps if I went in there armed & dangerous with an appliable TSB they might actually realize that i'm not blowing smoke (not that i am, after all, they were able to reproduce the issue themselves at some point). I know that the wiring harness that was replaced WAS part of a TSB, I'm just not sure which one as they didn't enlighten me on that information. After all, I'm just some girl, what could I possibly know about cars?
117643
Let me know what you find.
I am also kind of interested in why they changed the steering wheel switches on your vehicle
It shouldn't take dealer very long to confirm that a newer calibration is available for your vehicle than what is in it with respect to an Extended Crank complaint.
If dealer still needs guidance they have available the Technical Assistance Center to call for assistance which they have not made use of yet regarding your vehicle
Keep us posted
"#3574 of 3610 PHANTOM STARTING PROBLEMS by panthersfan95 Aug 04, 2006 (12:29 pm)
Bookmark | Reply | E-mail Msg
We all know how frustrating intermitant problems can be. I have an '05 Malibu LS V6 that just had it's third visit to the dealer in 18 months, for the same problem. Every 10 or so starts, the engine turns over for an unusually long amount of time (about 5-10 sec.), before finally starting up. Sometimes it turns over and stops without ever starting. Of course, every time I take it in to the dealer it acts fine. I don't hear any grinding or metal to metal that would indicate a mechanical problem, but the fact that it shouldn't be doing this has me worried. Any thoughts?
Replies to this message:
• rvoth (Aug 04, 2006 7:38 pm)
• rvoth (Aug 04, 2006 7:52 pm)
• e2helper (Aug 04, 2006 8:05 pm)
• gonogo (Aug 05, 2006 9:26 am)
• rvoth (Aug 05, 2006 9:58 pm) and 1 more...
• bunnymasseuse (Aug 07, 2006 11:58 am)
• dtownfb (Aug 10, 2006 7:21 am)
• bunnymasseuse (Aug 10, 2006 8:16 am)"
The bolded section above is almost EXACTLY what I experience. It's funny it started slowly too...
Meaning around 1500 it would have that happen maybe once a week, then 2-3 times a week, then 5-6 times a week, then it literally was 1 time every day out of 4 starts (once to work, to lunch, back from lunch, back to home). Take it to the dealership, they 'fool around in there' again, and then watch the earlier pattern unfold again, just quicker (not so long now for it to get to the 1 time a day senario). It can be putting the key in the ignition or using the remote start. It's never just ONE or the other. It can happen with either.
They replaced the switches on the steering wheel because they stopped working completely.
I didn't see any history on reprogramming of ECM in your vehicle so that would definitely be suggestion.
In regards to others with 3.5L but similar concern the TSB doesn't cover them. That is a different engine/controller than what you have on your SS.
Have been looking for a replacement but have not found a car yet that gives so much value for the money. To get all the features that I have on my LT, I would have to pay close to $28,000 and will will not get the mileage I get on my MAX.
Good luck on yours.
http://www.toptiergas.com/retailers.html
TOP TIER Gasoline Retailers:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
The Somerset Refinery, Inc.
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
If I have a __lot__ of mountain climbing on a trip, I might mix in some 89 with the 87 just to be safe.
My Prism and Camry (toyotas) did occasionally have problems with 87, though. they were "designed" for 87.
http://en.wikipedia.org/wiki/Octane_rating
Absolutely false!
"I guess I started a good thread with my initial reply on octane. I agree pretty much with all the threads, and will probably go to regular instead of mid-grade on our Malibu. However, there is still a detergent difference between grades on at least SOME gasoline. I do not know for sure on Top Tier, and the earlier post may be correct that all Top Tier has the same. I will investigate further with those I know in the oil industry. I do know something from my own experience. With my Volvo turbo, if I do not use premium, I get carbon deposits on the valves which cause a problem. And the car does lose power. Engineers I knew at Shell years ago had told me to watch for excess carbon build-up with lower grades on some engines. With that in mind I used nothing but premium on my 1971 Pinto (yes the exploding car) for over twenty years. Got 325,000 miles on it and only did one valve job, at 190,000 miles. So there is evidence that still leads me to higher grade gas. Also, it has been shown in many tests that you do get better gas mileage with higher grades."
What do others have to say about fuel octane. As discussed above, I really do believe octane makes a performance difference. I have primarily used premium in all my cars, and have obtianed better life that "normal" life on cars for more than 30 years. What do others say?
Now for the real reason I responded again. I don't know about the rest of you but splintering all of these forums is a big mistake IMHO. What kind of legs will this board have? Ten posts and it'll drop off the page in no time.
The big mistake is when the new 'Bu and the old Classic model were mixed on the board. That plugged up all of the non-Maxx boards with comments about 02 classic bu's. At least the Maxx board stayed pure.
By mixing the Maxx and the sedan 'Bu you no longer have access to the Maxx through hatchback or wagon boards. I've fought over Edmunds decision to make the Maxx a wagon instead of a hatch. Whatever it is, the mixing of the Maxx and the failure to recognize it as a hatch was bad marketing on the part of GM and (now) Edmunds. I want my Maxx board back!
So the 10% ethanol isn't "bad" for my engine, but it doesn't have the performance of a non-ethanol gas?
Talk again later!! Go Hawks!
Engine seems to start more reliabily, but it's still early into the repair.
Does anyone have a solution to this what is wrong with the car? I had the car at the dealership a few times before, and they did not find anything. :sick: Should I say goodbye to my 2004 Maxx?
My 2004 Maxx LS has been pretty great for me. Its build date is January 2004 at the Kansas City, KS facility.
I bought it new in '04, and the only troubles have been a need to replace the steering and an intermittent starting problem (which began in 04 about three months into ownership). I've taken it to the dealer for everything, even oil changes, and I took it to the dealer for this about a year ago when I got stranded for 20 minutes. The car refused to start. They couldn't find any problem.
Lately, the intermittent starting problem has gotten a lot more frequent. Starts usually take two tries. Also, the past couple months an odor of gasoline inside and outside the car has gotten stronger. If the car sits for a day, the odor is mostly gone, but once it's started and runs again, it's back. It got so strong that a week ago I took it to the dealer. They said the ECM needed to be reprogrammed with some update for the crank sensor. I got in the car and it still smelled a little like gasoline. I figured it might take time for this to go away.Two days later, the gasoline smell was still there -- and the car still takes two attempts to get started usually. I've got an appointment at the dealer for tomorrow. Does anyone have any suggestions that I might be able to pass along to them?
by disconnecting the battery, but it was only a temp cure, forcing the vehicle into a learn mode), New battery fixed it in my case. (evidently the ECM was real picky on
the minimum voltage, more so than the starter).
Well I have them now on my 05 w/ 48K miles and "of couse out of warranty!"
Has anyone found a fix.
My column wheel control buttons are going bad too! lost my cruise and radio chanel select.
D!
Steering wheel buttons going bad too. I have no cruise.
Will call the dealer today. I see a mention of
TSB #05-06-04-076B did this help anyone? With Vacation season I can't believe I lost my cruise!
D~
