Today I took it by the dealer and he installed part #1F22-13-210A which is a Volume/mass air flow sensor. According to Mazda support they apparently reengineered a new version of this sensor in an attempt to fix the problem. I'll let you all know if it works.... I'm keeping my fingers crossed.
Anyone else experienced this problem? I'm trying to arm myself with more information so I can get this problem fixed once and for all.
PS - New problem today. A very loud whistling noise coming from somewhere in the undercarriage. Happens while engine is running, doesn't change while accelerating, etc. We're taking in to the dealer tomorrow to get that one checked out.
Steve
Rattling problems can also come from loose exhaust brackets that may vibrate or loose skidplates..
MPG may vary with your driving habits. I find myself putting my foot into the V6 and know it doesn't help the mileage. Things that may affect mileage are using 10-W30/10W40 motor oils. Ford recommends 5-20W oil for gas mileage reasons. Other factors can be accessories like stepbars, roof racks, rock guards cause drag that may lower MPG. I have about 7K on my Escape now and am averaging 21MPG. I also use 10-30W oil, have stepbars, bugguard, and 2 bike racks. I'm sure this doesn't help my MPG.
Shelly..This squealing noise is interesting. Almost sounds like a leaky exhaust system. Please let us know what you find....
Thnx.
Anyone else have this problem, and if so, did you find a solution??
Just had the bucket 'o bolts into the garage (where it feels most at home) for the 24000km checkup. Gee, what a surprise... they found a leaking axle seal.
At this rate I'll have replaced all the original parts before the warranty runs out. Already on the fourth alternator and third PCM..
And here's the kicker...
Mazda Canada offered me an extended warranty "in the spirit of good customer relations". So I get the paperwork by courier, which turns out to be a legal release form. The release is required before I get the MAP contract. Can you believe that?? So much for the spirit of good customer relations.
This is my third consecutive Mazda.. and LAST.
OK, The constant whistle noise while the engine is running from the midsection... is the Fuel Pump. Yep, that is what they said. I 'll know right away, but they did not have the part in stock, so have to wait. Yeah, this is so simple to replace, I can go to Kragen and do it, but gotta keep the records going and have them do it for the warranty. Too bad a new fuel pump won't help the mpg.
Which dealer did you buy from in New Jersey? I think you will have success with the lemon law, just stick with it. Ford hopefully will come back with an offer in response to your letter.
Good Luck.
That place is within a 10-minute walk of my house, but I would never buy from them. That is one reason I scratched the Escape off my shopping list.
V-6 XLT loaded, love the handling and styling. Hate the quality. Purchased in Oct 2000. Noticed fuel smell almost immediately. Extremely poor gas mileage - 13 city, 22 hwy. I had been led to believe it would be much better. Stalled in Dec, twice in Feb. Had recall for the Wiper motor, replaced under the recall, then the motor burned out during a hard rainstorm on the highway in March 01. Took car in for repair for wiper motor, and mentioned stalling problem and fuel smell in March 01. Have had no problems with those since. March 2002 - Transmission failed at 23,500 miles on Highway @ 70 mph. Has been rebuilt. Let me summarize - I have had every problem that has ever been posted about the Escape - stalling, poor fuel mileage, fuel smell, wiper motor failure, and transmission. HELP!!! At this point all have been "corrected" by the dealer, who wants us to give them an "excellent" rating on the survey that FORD will send us. RIGHT!
I sound angry but after writing this it makes me feel so much better.
Last Saturday, a caller talked about her Escape stalling problem - they acted like they knew exactly what it was - a loose electrical connection. She had another problem with her car - think she said transmission - and these guys told her that the shop did not do all the electrical connections properly at the time of repair. So, all you owners that have had stalling problems, this might be a solution - have your electrical connections checked. You may have a loose connection.
The Tapperts advised that the cause may be a loose wire. Since replacing a tranny requires quite a bit of un-installing, they figured that the mechanic may have forgotten to tighten a connection when they put things back together.
It was an amusing segment, though. I thought they were a little hasty to suggest the lemon law. They were probably just taking advantage of the fact that it's a lemon yellow truck.
Speaking of lemon laws... A_Handlesman, you may need to give your dealer three attempts at fixing the problem before going lemon. In most states, you need to document three separate attempts at fixing a problem before taking legal action. Simply having the same problems three times does not qualify (not sure if that's what you were thinking). Good luck with the vehicle.
Murphy
I don't know much about cars so I'm not sure what an DPFE Sensor (Delta Pressure something or other) and an EVR Vacuum regulator is what Ford is telling me is wrong. Has anyone heard of this problem.
P.S. Anyone want to buy an ESCAPE for $15k (negot)? XLT, Leather, upgraded wheels and side bar?
The Tribute got the lowest mark for reliability and second lowest mark for customer satisfaction. The Ford Escape fared slightly better for customer satisfaction, but reliability was the same (crap).
As an unhappy 2001 Tribute owner, I can relate to that. I still prefer the Tribute's overall design to any other small SUV, but that's not really much good if it doesn't work
Cheers.
Seems like maltb, varmit, canadatwo, carseeker, murphy27 have this room pegged.. to name just a few....
In fact, my last post was rather positive, about a fuel pump
noise that probably indicated there was no problem with the fuel
pump. But I have read all the new negative material. In with that I say...
... thank the Lord I didn't buy a STINKIN' FORD!!!
Stop the UAW posturing and falsehoods.
To all who read this thread for advice, take the time to look at each person's profile so you can see if they actually own the vehicle that they are writing about.
carseeker4, you bought a Santa Fe didn't you? Hmm, let me see, which one has a better history Ford Truck or Hyundai Truck (or even Hyundai in general)? That's a tough one. Give it a year or two and then come back to make your comments. I wonder, how many improperly manufactured engine parts will have been replaced by then? I used to think Hyundai had something good going, then I was forced to drive a 2001 Sonata from mid-December to mid-January (wife's Civic decided to form the letter 'T' with an Accord one dark December night, and it was a rental with < 10,000 miles on it). Let's just say, what comes around, goes around.
Try reading the content, instead of focusing on the poster's name.
However, from my memory, the only time I speak up in here is to debunk what I know as false info or to gather more info. If that's not what a forum is for, people are wasting their time posting.
Personally, it's in my best interest to see everyone and their mother driving a Tribute, but the fact that it doesn't have a good record disappoints greatly.
I'm with you on the unions.
I know some people that have said they would never buy this, or never buy that because they had a problem with a certain brand. They always end up having a problem with the next brand, and the cycle continues on. Fortunately for them, with autos, it could be decades (or never) before they have a problem with the next brand. Some people just deal with problems better than others I guess. By the way, it took Hyundai 2+ years to fix the Santa Fe stalling problem. That's not so quick if you ask me. At least they fixed it though, I'll give them that.
-tidester
SUVs
carseeker4,
Yes they are built on car platforms and have the unibodies, etc., etc.. They really are trucks in the end though. So, they don't play in all of the big truck games, but they do have the skills to play in most. Look at their manufacturer names on nhtsa.com. You'll see Ford Truck and Hyundai Truck. On another note, something I always thought to be strange here in Pennsylvania (you're from the Philly area right), large vans and pickups say "Truck" on their PA license plates. Why don't SUV's? I never really did find out why, as I just got the new one (PA website and all) and it is the same as those on cars. Not that I really care, I'm just curious.
Anyway, we've put 1200+ more miles on our Escape in the past three months, and have not stalled again. I'm thinking about taking it in to have the PCM upgrade before it does stall again (if it even does) which may give me a better idea of whether or not this "fix" is really working. No one seems to want to come back to report success with it even though some of us keep asking them to. Anyone have any good news?
Sent the Lemon letter to Ford last week, so I'm waiting to get my return receipt and start counting off 10 days. Just a reminder that my stalls have occurred with thousands of miles between stalls so watch your dash! Usually I can't tell I have stalled until I need to brake or turn. If anyone has advice on how proceedings with their Lemons have gone with Ford, I would love to hear it. Murphy, where are you at with this?
I know of one other case where Ford admitted the 2001 Escape was a Lemon and the owner won. Anyone else have any experiences with Escape Lemons?
