Chevrolet Impala General Care & Maintenance
I have an '02 IMPALA LS 3.8L 84K miles on her.
LOW OIL PRESSURE message is comming up. checked the oil..proper viscosity and level
friend told me to put it in neutral and rev to 4K RPMs, message disappeared
he said that my OIL pump is going out.
Is it OIL sensor or OIL pump or maybe something else?
Do you change your oil and oil filter every 3-6k miles?
You may want to try using a heavier oil such as 20/50 or add some "Motor Honey." The thicker oil may buy you some more time. (If the seals in the oil pump are worn out this may temporarily fix the problem and boost the oil pressure) Eventually you are going to have to replace the oil pump.
By all means, swap out the sensor first before digging into the oil pan. Sometimes the oil pump pickup screen gets clogged up as well. So you might get lucky.
eh, yeah i checked my oil as stated...and i changed it too
aparently in my Engine there is no technical "oil pump" as i have pictured...It is just some gears (they are $23.77 from the dealer)
I just checked the thing with OBDII and it did not throw any messages or errors, most likely its the sensor (crossing my fingers)shop wanted like 35bucks to replace it. Hell with that, i ll do it myself. Also the sensor is located close to the oil filter.
here is the diagram for the engine, some people might find it useful..i did. The dealer is not that bad after all.
http://www.newimpala.com/sigs/engine%20diagram.jpg
oil sensor is 9 bucks at o'relli
You would think if the sensor was defective the "Low oil" message would have stayed on even during the high rev.
I do most of my own work, but this engine is by far one of the hardest to work on. Just try replacing the sparkplugs and wires and you will see what I mean.
I need to replace the thermistat as it sticks in the colder weather and causes the temperature guage to drop to zero and the fans to come on and run continuosly. By the way if anyone else has this problem, to fix it quickly do the following:
1 Stop car and turn off engine
2 Open hood and locate wiring harness directly above battery
3 Open the connection block, you will hear the fans shut down
4 Wait 5 seconds
5 Plug connection block back together
6 Restart engine, the engine will be hard to start for a moment
7 Notice the temperature guage rise back to where it should be
It seems this wiring harness directly interfaces with the BCM unit. I have had the BCM replaced twice now and still have issues, but thats another message posting.
Keith :confuse:
said, "You have to remove the air filter unit. Take the flexhose off and then you have to remove the breather. Thats the only way to get at the bolts. Its a real pain but its the only way. I just did mine. Good Luck!!!"
And so I wish you luck, too.
Which engine, 3.4 or 3.8 ?
Honestly I think that Chevy should replace EVERY BCM module in all Impala vehicles for NO charge. They know there is a problem with them but of course they will graceously charge you for their mistakes.
Keith
Not a big deal, but it's a therm"O"stat.
More importantly, are you sure it's working fine in warm months? The engine should warm up FAST, like 5 minutes of driving, and then level off at the correct normal temperature (around 195 depending on your engine).
Are you sure it's not stuck open and warming up too slowly, which you would have trouble noticing in warm weather?
Regardless - I think you're on the right track with the thermostat. Make sure all air is bled from the cooling system after a thermostat replacement.
Brian
Overall, it's a snap to use. I have retired my orbital polisher.
Thanks in advance, for y'alls help
Rocky
Also, my dash lights have gone dark when the lights are on. The radio and overhead information center are dimly lit, but unable to find a blown fuse on either side of the passenger compartment. Any clues?
I don't know where the power steering fluid is in your car but I know its in one of the caps up front, mine was to the top left of my engine, check your manual. As for the dim dashboard light, its probably just the resistor switch/knob where you can adjust the brightness. Try looking for light switch inside your car and see if it twists or roll or similar.
Does anybody have the latest Impala with the service engine and traction light going off and on a couple times a week?
This first happened in late September (I'm in the south so I did need the AC!), then at Thanskgiving. I think it's happened every time I've traveled long distances since then. I travelled at least 6 hours a weekend through all of October, and many weekends since Thanksgiving (though not always with my car now). The car hasn't broken down in all that traveling, but I have no idea if it's actually overheating or not.
Also, I did just take the car in to try to get this fixed. I spoke with the Korean secretary who I don't think quite got my problem across to the mechanic, so they found some other problem that required replacing a couple of gaskets. I just found out while travelling this weekend that they didn't fix the right problem.
Any ideas? Is it just a sensor problem, or possibly something more significant?
My car starts up fine, but many times when I start it non of the guages, radio, A/C, OnStar, Cruise, etc. will work. Turn signals and hazards work fine.
Took it to the dealership one day when it was actually acting up, and the guy said he wasn't getting any error codes on it at all...which I believe, I was standing right next to him in the parking lot. Checked all the fuses, no issues there. He says it could be an ignition switch, but not sure. I'm reading that it's possible it the bcm.
By the way, this usually only happens when it's warm outside. I'm from NE OH, so yesterday when it was 80, they didn't work at all. Today it was 35, and everything worked fine.
Any ideas?????
Make sure all the relays are working just tap them the next time this happens and see if it magically comes on.
If your fans are still running after the car is shut off, have your thermostat changed. This usually corrects the problem. Also, check the ground wire under the hood on the left side, above the headlight. Make sure it's a secure connection.
The traction control problem is most likely a broken or corroded connection in the ABS "wires" leading to the front hubs. Many have had the hubs replaced, only to have the problem return. The wires the car came with are too thin, and their connections break easily over time. Dealers charge around $250 to replace the wires. You can buy the wires and do the job yourself for a lot cheaper. The part numbers are:
Right Side: 10340313
Left Side: 10340314
www.gmpartsdirect.com
Instructions are included with the wires.
kenny
I remember my dad talking a couple of years ago about another chevy model he had (I believe it was a trailblazer, but not totally sure) that had a seperate radiator cap from the resevoir cap. Does the '05 Impala have such? Has anyone had this happen to them?
I'm stressing out. I can't afford a new car right now (nor do I want one) nor can I afford costly repairs. My husband is the only one working right now, as I try to find a job. If anyone has any info, I'm begging for help!
Melissa
You will want to carefully check your oil on the dipstick to make sure antifreeze is not getting into the oil from a manifold leak or some such thing. If you noticed that antifreeze is getting into the oil, you must take immediate action or you're looking at replacing the engine which is as you know a BIG problem. Please let us know if you need further.
Fuel guage is fine, Temperature and speedometer work only 5 minutes of shifting into gears. Read on another link there is a recall on the fuel line itself, could leak fluid or false reading on guage, may cause fire.
Wiper fluid freezes ever year when temperatures get close to freezing. This is the only vehicle I have ever had trouble with.
JK - when I was a young first learning driver, I thought I would do my Grandma a favor by washing and waxing her Lincoln Towncar after she let me borrow it for a date. I ended up getting wax all over the plastic trim and it forever stayed there - she neve said anything, but I am sure she noticed it. I would like to think that she was more grateful that I would be thougtful enought to try and return the vehicle in better condidtion that when I borrowed it in.
