Visitor Agreement.
Anyway, to top it off I started getting some weird random thud noises coming from the sub, even when stereo is turned off. I finally got the coins out, but the noise and flickering lights still persists. In addition the 1,2,3,4,5,6 buttons as well as the seek buttons quit working(unless I hit the left side of the console with my fist). Any thoughts on this???
Is this normal?
If the factory radio is replaced, the factory sub will no longer work." - this is what the supplier of new car stereo says. unless I replace it with a new sub which is too much trouble.
any suggestion ? thanks
I guess it must be very difficult. otherwise the vendor (Clutchfield) will say they can make the new stereo to work with Acura installed sub.
Best Regards,
Jon
E.g., I downloaded a lot of Rickie Lee Jones. The first one was a 3 disc set, "The Duchess of Coolville".
I then downloaded about 4 other different CD's by her.
If I do a Music Search by Album, each of the albums are listed.
But I don't recall the album names for many of the artists for whom I've downloaded multiple titles, so I do the Music Search by Artist.
It only has ONE listing for Rickie Lee Jones. If I select it, it takes me to "The Duchess of Coolville" and all of the songs from the 3 disc set.
But it doesn't list all of the other CD's by her which I've downloaded.
The manual covers Music Search by Artist on p. 326. There is no mention of this problem.
Has anyone else experienced this?
If you have an '09 TL w/Nav and you have downloaded more than one title by a particular artist, I'd be grateful if you would do a Music Search by Artist, and let me know if you have the same issue.
Any idea where I go for an explanation/solution/fix?
I plan to ask the 2 Acura dealers in town, but when I was last at one of them and asked a question about the sound system, the service rep knew less than I did and suggested he'd ask one of the salesmen. A salesman won't know anything about this or how to remedy this unless he owns an 09 TL and encountered the same situation.
I also plan to call the phone number listed as Contact on myacura.com, but would be surprised if a phone rep can help with this.
It seems it would take an Acura sound system engineer to be able to provide further info (unless any of you can).
Won't contact Accura until I know if it's a problem with the software in my car, or a problem with the way they designed the software.
I'd like to make sure I have this straight before I contact Acura:
In my case - If I've downloaded 2 different CD titles by an artist, and I "Search by Artist", and click on the artist's name, it will only list the artist one time, but IT WILL list the total number of tracks I've downloaded from both CD's.
Just to confirm - when you've done the same, and you've downloaded 2 different CD titles by an artist, and you do the "Search by Artist", it lists that artist 2 times (one under the other)? So that you can click on either of the titles, rather than only one?
Is that correct?
"In my case - If I've downloaded 2 different CD titles by an artist, and I "Search by Artist", , it will only list the artist one time, but IT WILL list the total number of tracks I've downloaded from both CD's."
ALSO - it does not list the title of the CD for any of the artists in my "Search by Artist" file.
Does your "Search by Artist" file list the title of the CD alongside the artist's name?
On my 2010 TL, XM,HDD,USB or CD are all about the same around a 8 volume setting like my wife's TSX, HOWEVER when I go to AM or FM I have to increase the volume setting to almost 14 or 15 to get it close to the others sources.. Anyone have a similar issue and if yes, did you get it fixed and how? :confuse:
Because 2001 TL doesn't allow any after market stereo, wired FM modulator is a valid option.
btw, my 2001 TL has just passed 100k miles today. it's a solid car that never given me any trouble in the last 9 years. add a FM modulator transfer my old TL to the iPod times. cheers.
do you guys have any ideas what this hiss might be? is there something wrong with the sound system? any ideas would be greatly appreciated!!
On my 2010 TL, XM,HDD,USB or CD are all about the same around a 8 volume setting like my wife's TSX, HOWEVER when I go to AM or FM I have to increase the volume setting to almost 14 or 15 to get it close to the others sources.. Anyone have a similar issue and if yes, did you get it fixed and how? :confuse: :confuse:
I've got the same issue....Did you fix or find out what was causing the non-playbak? A response would be much appreciated!
Jerimy
"Has anyone had the following problem? After battery was reconnected, radio code inserted, with radio and regular music CDs playing fine. None of my DVD Audio CDs will play. Radio displays on screen, "DVD-A", but no sound for each song/track. Anyone has any suggestions before I take to dealer? First time for this one. Thank you in advance."
Did you ever find a solution to your problem above...I'm in your shoes now and would love to hear if you found a fix.
Jerimy
did you ever get any information on dealing with a jammed cd on the 2002 TL CD player? I know it's been a few years but I'd sure be appreciative if you could share it with me.
thanks,
John
This site offers a $69.00 solution. The videos follow show how it works and they have an installation video on Youtube as well.
http://enfigcarstereo.com/BLITZSAFE_HON_MLINK1_V2X.html
I'd be willing to attempt the installation.
http://www.youtube.com/watch?v=keVuAXoQPTw&feature=channel&list=UL
http://www.youtube.com/watch?v=mx5n5y13jgo&feature=relmfu
