I have a 1999 Grand Am (Love it!). I've had it for 8 years and now have over 130,000 miles on it. My brake light was coming on when I was turning corners then turning itself off within 2-3 minutes. I took it to my friend who's a mechanic and he said the brake fluid was low. He couldn't find any leaks so he told me that it was probably a Master Cylinder (about $65 at auto parts store) and said it was an easy enough fix that it could be done at home if you have a friend that knows a little about cars. He topped off my brake fluid reservoir and showed me where it was so I could watch to see if it got low again without an apparent leak (if it did then it was the cylinder). Hope this helps someone!!
~amh1
PLEASEEE Help!
I brought my car into a few mechanics and they couldn't figure it out. Finally at Brakeway in Louisville, KY, they found out that I installed my brake pads backwards and the hardware (clips) weren't fitting properly. Each time I changed my brake pads, I would match them up with how they were previously. This way, they were always put on wrong!
So, if you have problems with the brakes wearing faster than normal, they may need to be properly installed. I hope this helps you!
front passenger hub replaced
Front passenger caliper replaced
Front brakes ( pads and rotors)
rear brake drum inspection (both fine little brake dust but plenty of pad)
what i believe wrong:
falty or defective caliper? faulty defective abs sensor? pads installed incorrectly? (not likely) rotors installed incorrectly?
any further ideas? would appreciate some further input and brain storming. thank you
