Buick LeSabre: Problem Codes/TSBs/Recalls
Was there ever a recall on the faulty plenum? Looking at a $400 expenditure for an '01.
There was a recall on vehicles 2000-2003 to have the nuts holding the throttle body to the plenum changed to ones that were broader and to add antileak to the coolant the way it's added at most factories to stop minor leaks. GM stopped adding it in 2000 because it discolors the recovery tank.
What happened with your plenum?
We put it on a machine and got 2 codes:
P1361- Ignition Control Signal Not Toggling
P0300- Misfire
We are pointing toward Replacing the Ignition Control Module.
Does anyone have any ideas or imput?
When you turn the key is the car cranking? Is that what you mean by it's not getting gas from the fuel pump?
I've read posts in another discussion by people chasing problems like this. The crankshaft position sensor seems to not give a clear code or sign. For your Ignition Control Module is it getting spark? If it quits and you can remove a spark plug wire to determine it's NOT giving spark would be a great help. Don't just toss on parts. Diagnose (I know, easy for me to say).
The shutting off while running sounds like it _might_ be crankshaft position sensor of camshaft sensor. If the crankshaft sensor gives a problem it _sometimes_ is heat related. Are you in a hot climate? is the car hot when this happens?
People in another discussion have mentioned putting cold water on the crankshaft position sensor (it sits just behind the flywheel and you can throw cold water from a cup on it they've said). Cooling it sometimes gets it back to sensing the timing pieces as they go by.
How many miles on car?
When the car is hot about 10-15 minutes of driving, it will shut off. I try to start it and it turns over but does not start. Like starting an engine with no gas in it. I will have to check for spark next time it happens.
After around 10-15 tries, it starts right up, no problem. It runs great.
A friend put it on a tester and the codes that came up were:
P1361 Ignition Control Signal not Toggling
P0321 Spark Reference Circuit
P0705 Trans Range Sw Circuit
P1530 A/C Pressure Sw Circuit
P0300 Misfire
It suggested the Ignition Control Module
or the ECM or PCM (Which ever one is the main Brain) I am not quite sure which one. I was going to go to the junk yard and get one. I did replac the Ignition Control Module and the light still comes on , but it hasn't shut off on me yet.
If the crank shaft was the problem, would it have showed up on the tester?
The crankshaft sensors don't seem to throw a specific code with their erratic failures.
When car doesn't start you can check the injectors by feeling them during cranking. If you touch them while the car cranks and starts normally you can feel the vibration as they work. If it doesn't do that when it won't start, you know the injectors are getting a signal from the PCM.
The question about the security light was because of the VATS system that turns off the crank and the injectors if the wrong key chip resistance is detected. But if the security light isn't on but works properly during startup it's not likely a problem.
It is possible for PCMs to do funny things. A neighbor had one that gave a terrible rough idle and poor running. But that was a cobbled motor (replacement) to begin with. A replacement PCM from a junkyard did fix the problem.
I'll send an email with a couple of links to places you might want to read about probems and diagnosing to your carspace email box. It's the "mailbox" in the gray horizontal bar at the top of each page here on edmunds.
Certain stores may have gotten the setup of cables to read the OBDI with their readers. Shopping for readers some will mention they have cable to adapt to the earlier ones. But lots of people still seem to have trouble.
IF it can be read by using a jumper to touch the terminals A and B, here is a sketch showing how it works.
Have key off. Connected between contacts labeled A and B. Then turn key on and watch the check engine light. Hope it works on your year car. Otherwise keep checking at different stores that provide free service of checking codes.
Try callin different ones. E.g., one Advanced Auto may have the reader and correct cable that will read it while another one doesn't.
BTW, what trouble are you having with your car that you want to read the codes?
Maybe if your light is on, someone can help if there are symtoms. And remember codes only hint at the cause. Don't just replace parts because the guy at the parts counter says that's the code for a carburetor low out reading; replace the carburetor! Troubleshooting is needed to find the cause that can trip the code.
Most trouble codes I've had were emissions; the gas cap was not sealing on the filler neck after putting gas it. One time a hose at the carbon cannister had started leaking at the connection. Garage fixed that one by cutting off the end and stretching the hose and reconnecting.
I'd change the oil and put in 20-50 IF you're not in a cold, cold climate. I'm assuming you're using 10-30 now.
You don't tell how many miles and what kind of maintenance like regular oil changes at 3000-4500 miles it's had. I'm assuming it's wear on bearings especially if it's over 150K. miles and hasn't had frequent oil changes.
I'm not sure about the knock meaning since it's at low rpms only.
Ask in this discussion about noise and which oil might buy some more time on the motor.
Oil, a slippery subject
i put spark plugs in it. what can i do to tune it up to get optimum gas mileage.
If you know which dealer did the service, I'd go back and ask them about the records for the vehicle. And I think it would be well worth having them check what's the problem.
Listen with a broomstick or long piece of wood to where it comes from in the motor. Be careful of belts and moving parts. Change the oil and put in fresh oil.
Take off the serpentine belt and spin and push and pull on each of the pulleys to look for one of those giving trouble. Check the idler pulley really carefully. They usually give a squeal or rushing noise on newer 3800s but you could have a pulley on an accessory bad.
I'd put in a bottle of Chevron Techron fuel system cleaner (available at Walmart, Meijer, Pepboys, Advance auto, compare prices). Put it in when tank is low and then add 10 gallons or 20 gallons. Drive and see if it makes a difference. I use it twice a year. Don't over use it. And don't get the injector cleaner version in the same black bottle. I don't think it's as strong.
Check the air filter. Replace if it looks like dirt is embedded into the fibers. Or knock dirt off and continue.
See if the trans oil has been drained and replaced. If the one dealer did service, they can tell you if it was done if the papers aren't in the car. Some people would advise against draining oil after 15 years. You might want to ask in the Oil, A Slippery Subject forum.
and someone noted in another discussion
" These engines were notorious for their weakened oil pressure relief valves. If you have been using conventional oils and not changed oil at proper intervals, you probably have gunked up the seals inside the relief valve or in the oil pressure sensor. Doing a motor flush may help things out and restore the operation of the relief valve. You might try adding Risolone (a high detergent oil) to your crankcase and hope for the best. Other than that, it's a fairly meaty chore to remove the oil pan and oil pump for replacement."
im not 2 sure about the lights in the steering wheel. u may b able 2 get the switches replaced. unfortunately u sometimes have to do that. good luck!!!
You need to find a store or some who has them.
Do you have a second key? Put it in slowly and then turn the key to ON before turning the key to START. See what the Security light does.
The resistance it reads may be wrong because
the contacts inside the entrance to the key cylinder that contact the two sides of the key resistor are worn or dirty. You can try putting alcohol on the resistor parts of the key and quickly insert it to clean the with the alcohol carried in.
The resistor on the key may be gooey or oiley. Rub it with a pencil eraser to remove goop on the two resistor contacts.
The two wires that go from the contacts inside the key cylinder down the steering column to the connector at the base may have broken some of the fine wires where they bend all the time as the tilt wheel goes up and down.
If it reads the key resistance as correct, it will then start the car. It may still have problems. The light may come on while you're driving if and then go off again.
The dealer will want to replace the lock cylinder and cut new keys for that cylinder at $30 each. I would expect $300 at some dealers. Independent garages may charge less that are knowledgeable.
There is a fix where resistors equal to the key resistance are soldered into the circuit down on the steering column instead of the contacts reading the key in the cylinder at the top. Then you have no theft deterrent but the VATS system always works. (VATS=vehicle anti theft system).
The Buicks had a very soft, but controlled ride. They are at home on a relatively smooth street and interstate. If it's a Custom, that's even more true because it doesn't have the leveling rear struts that pump up to maintain height. Those were actually stiffer than the base struts for the rear. In the 1993, with two people in the rear, stopping at a stop sign quickly and making the nose dive then hitting the gas actually threw enough mass to the rear that the struts bottom (softly).
If you're comparing to an Accord's ride, that won't work as you see from what I've said. If you mother intends to keep the car I'd do as I did on both my leSabres and put on Monroe SensaTrac stuts all around. You can shop for price. I don't recommend Sears but another store would match their pricing. Sears runs half price on installation labor cost fairly often and you can take that plus the cost of the struts to shop at your favorite place. Don't forget there'll be a 4-wheel alignment added to that.
Eleven years of age may also have softened the struts.
could be blower motor--connect a direct wire from the battery positive post (with a fuse in it) to check. If it doesn't work take the ground wire and connect it directly to the negative post of the battery also.
could be the BCM, blower control module, which is the power transistor unit that varies the speed. Follow the wires from the blower motor to the BCM which is under the relay center with all the fuses and relays if I recall the layout correctly.
If it's a manual control system it could be the blower motor.
Or it could be the resistor pack for the lower speeds is blown. But then it would work on high speed only because high speed uses a separate relay in the relay center to provide power directly because of the high amperage.
Need help! I have a (new to me) 1998 Buick Lesabre with the 3.8, 77,500 miles. I’m coming up with the code P0300 which is multi-cylinder misfire. My mechanic came up with it being # 1 & # 4 cylinders. At this time I’ll mention that the code get’s picked up at about 2700 RPM. The engine runs smooth and no noises.
We’ve done some of the obvious; Changed plugs and wires. Change out the coil pack. Ran Sea Foam into vacuum at throttle body. Cleaned and shifted around injectors.
I’m at a lost, any suggestions out there?
Check engine light is on. I had it scanned and it came back with these two error codes:
P0107 - Manifold Absolute Pressure [MAP] Sensor Circuit Low Voltage
P0201 - Injector 1 Control Circuit
My thoughts are that either one of the two parts in question is causing all the problems or some other underlying third problem is causing them. Maybe an intake manifold gasket or other vacuum leak?
Any thoughts on what the most likely culprit is?
Thanks much!
If it should be 4-6 volts does anyone have an idea of what might be the problem?
Does it mean that the PCM is bad and needs to be replaced?
Schmegalhof
Did you find the problem on yours?
