Visitor Agreement.
Still, would you REALLY want to go back to Armstrong Steering and swelter without A/C?
Not me!
As far Isellhondas says about going back to no A/C and Armstrong Steering, I guess I have gotten kind of used to the comforts of A/C and PS, but the '66 Impala SS I am restoring right now doesn't have A/C, and that is part of the reason I like it. I have even thought about switching to a manual steering box. With a big-block Impala that might be a little masochistic . . .
For commuting and city use it is nice to have A/C and be able to "control the climate." For weekend and pleasure use: I say roll down the windows and listen to the V8 hum and/or roar.
-mike
Isuzu's Duramax Diesel that goes in the new GM pickups is a dang nice engine too. I love how all the good-ole-boys (no offense to any on here) slam their hood and go "what a fine die-sel ingine I have, good-ole american style" meanwhile it's actually a japanese engine under the hood (although it is built here state-side)
-mike
Probably because my '79 was a full-size R-body Newport, while the other two were compacts, a Dart and a Gran Fury (remember, when that design came out for '76, it was still compact).
On the Gran Fury, you almost can't take the air cleaner off for fear of breaking a vacuum hose or popping something else off that you'll never be able to find out where it goes.
They're all a pain when it comes to changing the oil filter though. The Dart and the Gran Fury have exhaust pipes that are in the way, and Newport's was a long stretch down from above. It was also angled upward, and it was also difficult to get a new filter started on.
My grandmother's '85 LeSabre is pretty hideous looking under the hood, as well. Its one redeeming feature is the extra tall oil filler tube. My '82 Cutlass Supreme had a Buick 231 V-6, which was literally buried on the passenger side...you could't even see the valve cover on that side! I'd imagine the 350 upon which it's based got pretty bad by the late 70's, as well.
-Andre
After that, though, I figured dang it, I'm not going to let this car psyche me out like that!
Turns out the Intrepid is one of the easiest oil changes I've ever done! I think I'm going to let someone else mess with the spark plugs, though!
-Andre
Now I wont mention the piece of crap TH200 that was behind it....
Aesthetics are a personal issue,to me nothing is more beautiful than a big orange chunk of cast iron with huge, wide, chrome valve covers pierced by black plug wires. A large argent silver shaker bubble topping two Carter AFB's(a work of art in themselves). Well,only thing more beautiful would be if it was sitting between the frame rails of my '70 Cuda.
One thing I would like to say about the new generation V8's is that many people seem to confuse the greatness of the engines with the greatness of modern electronics. Engine management has come a long way,the basic long block hasn't changed much. Maybe this is a testament to the strength and engineering excellence of the V8 in general. Imagine if you will a 340 with modern electronics how could it not be vicious?It already has 6.123" rods like the Chevy guys pay big bucks to get. It already sports 2.02" intake valves and 1.60" exhaust valves. It has a relatively large 4.040" bore and a short 3.313" stroke giving it(if memory serves me correctly)a nearly perfect 1.88 bore/stroke ratio.
And I know the 340 is only one example there must be more.
Modern engines are great,but I believe the best have already been made and now we are just refining them.
http://members.spree.com/entertainment/mr409/bob_s_409_chevy_page_index.html
By 428 do you mean the 352/390/427/428 'FE' motor? They run pretty well (my CJ Mach1 was suprisingly quick for as docile as it was) but really don't have the obvious pull of say, an L72 or L88 Chevy. These days you're looking at a lot higher prices than the Chevrolet equivalent anyway.
This strikes me as kind of an odd thread since the obvious winner(s) are the Chevrolet small or big blocks, depending on the size car they are pulling. There might be some design advantages here and there in other makes, but due to the enormous amount of factory and aftermarket r&d plus the low prices due to mass production, nothing else comes close.
The 428 CJ took care of the 390 GT's biggest problem, 1958-style cylinder heads. I think the cam was the same so that wasn't the reason 390 Fairlanes and Mustangs were such underachievers, but the Competition Cams 270 cam I put in a 390 really woke it up.
Speaking of Olds, there was a 4-cam hemi engineering exercise called the OW-30 that was on the cover of I think Hot Rod's 1971 Engine Annual.
Reminds me of a hemi version of the SBC that Chevrolet engineering built. I saw where some guy found one, found whatever parts where needed to make it run (some from unobtainium I'm sure) and put it in a '69 Z/28. That same engine was described by Smokey Yunick as a 'pile of junk' which there was no hope for. Hope the dude with the Camaro never saw any of the articles.
That Chevy sounds a little like the tunnelport Ford 302. Another idea that sounded good...
"I'm not even really a Ford guy, but, I think the best engine ever was the 429cj used in the '69-'70 mustang bosses. The reason for this is because the 429 had hemispherical heads...therefore making it a "Hemi". Next after that engine would probably be the 428 "semi-hemi" with semi-hemispherical heads as were still used up through '94 in crown vic's with the 4.6L sohc v-8.
"Yes I do mean the "FE" style engines when I say the 428 but the 428 is the biggest, so why not just name that one? lol. To tell you the truth their is a much larger aftermarket for fuel injected 302's and 280/281/282 sohc and dohc Ford engines than there is for the 350LT-1 or the 346LS-1. Pick up any popular performace order catalogs(summit,Jeg's,etc.)and you'll see what I mean. But yes, I think that both the LT-1 and the LS-1 are better engines than the 5.0 and 4.6sohc/dohc straight from the factory."
429's were never true hemis and the semi-hemi was a Boss 429, not CJ or SCJ. The 428 ALWAYS had a wedge head, never a semi-hemi head.
The modular 4.6 Fords, both DOHC and SOHC are no where near the FE head design or a semi hemi. C'mon man, the 4.6 is an Overhead cam. The '94 Crown Vics use the same motors from '91(?) to present.
The LT1 is NOT a better design than a 4.6 modular Ford. The LS1 and current Fords share a deep skirt cross bolted main design which is more modern than both the 302/351 and LT1. And believe it or not the current LS1 heads share more design features with the OLD Ford design than ANY past Chevy small block heads.
One question for you: WTF is a 280/281/282 SOHC DOHC Ford engine?????
You still don't believe Toronado's ever had RWD; do you????
Yeah, and looking kind of foolish doing it, too, as Toronados were always, ALWAYS, front wheel drive. I notice you haven't been back there.
And just HOW many horsepower does your 442 have?
And let's not provoke any more beefs, okay? The profanity has been deleted just now.
Mr. Shiftright
I will concede that some publications will say 280 or 281 CID depending on who they are.This is like some magazines will call the 302 a 5.0 or 4.9 because it's actually 4949 CC(?) BUT ALL THE INTERNAL DIMENSIONS ARE THE SAME!!!!
Maybe the 3.55 and the 3.54 are rounded off a bit? I'm just wondering because I've always heard it referred to as a 281, but never a 280, and obviously never a 282.
For example, I know the Olds 350 has a bore of 4.06" and a stroke of 3.385". Maybe the bore is rounded off too, but I have an old car book that lists bore and stroke on various engines, and some Olds engines have the stroke listed as 3.38 and some as 3.39. I think the 260, 307, and 350 (maybe the 403 as well) all have the same stroke, just different bores. BTW, when I do the math on the Olds 350, using 3.38 I get 350.065 CID. Using 3.385 I get 350.584 CID. And using 3.39 I get 351.101 CID.
"You mean there is NOT 3 different engines that Ford built using the 4.6 designation??? You mean the CC of the head has NOTHING to do with displacement either??? I'm sorry guys, I was mistaken again. Me bows head in shame."
As far as a deep skirted crossbolted engine being something new I must misunderstand. The 426 Hemi was a deep skirted crossbolted engine way back in 1964,and I wouldn't be surprised if it wasn't the first.
It is funny to me how in a topic awhile back every one was claiming the new Dodge Hemi was just hype,but people seem to love to say their favorite engine is a Hemi, or Semi-Hemi.
As far as Ford producing several different 4.6 liter engines in different sizes just apply some common sense. I am definitely not a Ford guy but I do know that no company is going to produce a new engine from the ground up,then throw away millions of dollars of tooling every couple of years so they can change the bore or stroke a few thousandths.
Anyway, back to "hype". Until I see a head pulled off the yet to be released "hemi" (or an actual engineering print) I still have my doubts about a hemi being an efficient EPA friendly design. Great high RPM race motor, YES!!! Great all around modern motor, NO!!!
Trivia time. What is/was the highest factory rated horsepower motor from the big 3. Hint for Mopar, it wasn't the hemi.
The most powerful motor offered in an American car will be the 8.1 liter Dodge Viper V10 for 2002/03 - 500hp/500lb-ft (net). I don't think anything else ever produced that much net power. I could be wrong, but nothing comes to mind.
Just curious...
Oh, you don't have to go to a big V8 display to see car guys arguing...I've seen them argue over the correct bolt head pattern on a Model A Ford for HOURS.....I'm sure Henry Ford would have had a chuckle over that, inasmuch as I'm sure his workers grabbed whatever was on the shelf.
You might want to check out all of your car/engine choices (they don't exist). Try: www.camaros.org/geninfo.shtml#DealerModified www.camaros.org/engine.shtml www.chevelles.com/shop/ss_ident.html
Thank God for these forums!
