Just curious about the deal you made for the Explorer. Did you suggest the deal, was it Ford's idea, or a mutual result of negotiation? Also, did you file through your state's laws, or use a Ford arbitration program? When I filed for Lemon Law arbitration through my state's program a few years ago, the manufacturer (not Ford, btw) made no offers about replacing the vehicle. They just kept calling me to have their "technical service department experts" take a look at the vehicle. Since I did not plan on buying another vehicle from that manufacturer at that point, I ignored their calls and proceeded with the arbitration. The result was a buyback of the vehicle with a minimal charge for mileage exceeding 12000 miles.
The deal was from FORD (and it is a deal that my dealer had told me they have made with numerous consumers).
At the urging of the dealer (who was just as frustrated as we were) we filed with the Dispute Board, our State Attny General, and had our lawyer write a certified letter to Ford threatening legal action. Our state (WV) has a statute that would have been a perfect fit for a lawsuit --- Before the Attny General could file anything and before the Dispute Board could rule, Ford made the offer and we accepted.
Your dealership urged you to file a complaint against Ford? I received no help from the dealership prior to or after filing with the New York State Attorney General. With all the problems you experienced with your Escape, at least you avoided the frustration and hassle of an arbitration hearing. Good Luck with your Explorer.
I hear you that other cars do it (the loaner Ford focus they gave me is doing the same darn thing!)- but maybe you can help me with the concern. My bigger concern isnt the annoying noise as much as the fact that my roof is vibrating so fast and so much- I have to question the structural integrity of the roof, luggage rack etc over time. How can it vibrate so hard without causing damage- I'm just wondering. Furthermore- couldn't it cause problems with the moonroof/leakage down the road? Why do the cars do this when the rear windows are open? Please- educate me because the dealer sure couldn't!
You have to remember --- I am in a smaller area and my salesman is a lifelong family friend. My wife knows the service guys by name. Our whole state only has 1.4 mil residents so our dealers depend upon REPEAT business. My wife is from Buffalo, so it has been a shock to her. There are positives to living is a more rural area, and this is one of them! MIKE
I often times drive with all the window open too and I have never had a noise or vibration problem. We even drove 3/4th of the way to Richmond Va. from Pittsburgh last month with all of the windows down (moonroof open all the way too).
Drive a new one from the lot and see if it does the same thing. Even with the moonroof and only rear windows open (do that often at night) I don't have any wind problems. It's quite peaceful that way actually.
It has to do with the way the the air enters and leaves the vehicle. What ends up happening is that the pressure or vacuum created (by the air flowing past the open window) begins to resonate and if you are normal, your ears feel like they will fall out due to the rapid changes in pressure. The best way to avoid it is to open a front window which almost always forces air into the vehicle making it a constant pressure. If it happens with only the moon roof open, you may want to look into a wind deflector.
is what happens when the rear windows are open and the front/moonroof closed. Open the front window slightly or the moonroof. Yes, it can be a terrible noise. There is no 'fix' as such from a dealer. A moonroof deflector may also help.
Got the call from my wife yesterday. 'I was driving around 40mph, going around a bend, and then it felt like I lost the power steering went out and all the dash lights lit up'.
'dang, sounds like it stalled'
'No, I don't think so, I had to turn it off after I pulled over, I think the engine was still running when I did that'
'Where are you now'
'On the side of the road still'
'Did you try starting it back up?'
'Ok, yep, it runs fine now, make the call to service though'
Anyway, it started back up and she drove the rest of the day with no problems.. Interesting parts: She really didn't think the vehicle stalled, her main concern was all of the dash lights and loss of power steering. When this occured she immediately started the process of pulling over. (she mentioned that the power braking was also not working). This is why she was in no hurry to try to restart the vehicle, because she didn't realize that the cause for all of her symptoms was a stall in the first place.
She said she had no problems pulling over or controlling the vehicle, she said without the power steering, the wheel fights back a little, but not even close to losing control.
I asked if she was going downhill, she said it was a very very slight downhill.
Appointment is scheduled today to have it looked at.
bess, That's pretty much how my wife felt about it too. I was the passenger at the time of our stall so I knew exactly what it was and was able to tell her what to do right away. We were on a really steep winding side street hill at the time and she had no problem pulling over and stopping.
My wife was confused for a second too because everything was still on (radio, HVAC fan, etc.). If it wasn't for the dash lights, and the fact that she was braking, we never would have known the engine wasn't running. Maybe that explains some of your wife's confusion.
(My summary) Checked a bunch of sensors, refered to TSB for stalling, replaced IAC, MAF, Throttle bdy assy, EVAP valve and reprogrammed PCM.
My check engine light also stayed on so for that they: Replaced DPF EGR sensor.
In at 8:00am out at 2:30pm.
======== Baggs, Yeah, thats what I metioned to my wife (about all interior fans/radio/road noise still on) and thats when she said, well maybe it did stall..
In her previous experiences with vehicles stalling many many years ago (Olds cutlass and caprice classic's), you tend to notice when a 350cc V8 stops running.
These are really two different vehicles. I'm just curious how you can be torn between these two? Highlander is about $5-$8,000 dollars more than an Escape, depending on level of trim of course.. Not to even include space..
We have a 2001 Trib LX V6. My wife experienced a typical stall at 12,000 miles. Took it in, they "reprogramed it" & we have had no reoccurances.
Is this stalling a gender thing? Seems like the vast majority who experience are female. Do more females drive tribscapes or do the males not complain or what???
Other problems have included some leakage from the brake cylinder reservoir cap, brake warning light stayed on, and the tailgate creak. All fixed occured within the 1st 12 months & were easily fixed Current mileage is 23,000. The reports of tranny failures does worry me a bit
If I read everything that was to be read on here concerning wind noise, am I correct in assuming the mirrors were redesigned on Jan. 02' Escape models and later, and if you have an '02 model pre-January, you are stuck with the old style and excessive wind noise? Mind seems to start whistling around 40 mph, and by 80 mph, is quite substantial. It makes the tire roar seem minor. Is this common with all '01 and early '02 models? Has anyone looked into getting them replaced or cost involved?
I never felt that the wind noise on the 01 Escape was that excessive. Is it possible that your roof rack is backwards? I've heard of others where this is the case. (I believe the roof rack cross slats are installed after delivery by the dealer).
Might be an easy thing to check (just as easy to remove the cross slats all together).
I have a 2001 Tribute that just turned 25,000 miles. Around 20,000 miles, I developed a vibration in the front end, along with a clunk sound when turning. Took it to the dealer and they checked the balance of the tires and repaired a leak in the steering. The vibration is still there. The vibration is most prominent at about 70 mph (more so on smooth pavement), and worsens while driving uphill at 70 mph. I also get a clank sound in the front when making sharp turns in parking lots. Anyone else with this problem and, if so, was your dealer able to diagnose and fix it?
We had an 88 Mazda 323 AWD with a button that locked the transfer (not to be used on drive pavements). Sometimes unknown to me the kids would activate it and when I drove on dry pavement with it locked - there would be clanking sounds on sharp turns and vibrations at high speeds. My apologies if you have already checked the obvious. I can't imagine driving 5000 mi with that sort of thing being the problem - but it's worth mentioning.
Did they check the power steering pump??? Our Escape went through 2 of em -- BTW --- my wife loves her EXPLORER and is so glad that Ford Lemon Lawed her Escape --- just feel sorry for the person that buys that at the buyback auction!!
the clicking in the steering is caused by loose lugs...go and have you lug nuts tightend and it should remidy the problem. from what the dealer told me was he prefers to tighten to 105lbs-ft of torque instead of the regular 100lbs-ft of torque. apparently there is a problem with case aluminum wheels that the lugs can loosen over time with higher speed driving. I don't know if that's true or not..but I only had the clicking once and haven't had since finding out about the lbs-ft thing. Hope this helps.
At mainly speeds of about 45 mph, several times per trip I experience a rumbling noise similar to the sound when rolling over warning strips. The noise lasts approximately 1 second. It appears to come from the right rear wheel.
Although it may have nothing to do with it I also notice a whining noise that sounds like the old rear end noise in past vehicles with rear wheel drive, also around 45 mph.
I have a 4x4 and I get the reeling the auto 4x4 somehow engages while on pavement and causes a binding binding.
This weekend while traveling I noticed something wrong with my stereo/6 CD disc. While playing CDS in Slot 1 and Slot 6, the Bass and Balance menus kept flickering on. Also, the balance went entirely to the right stereo speaker only. I was touching nothing on the stereo while it started doing these things. Seems fine today but am taking it in. ANyone else experience this?
By the way, my 2002 Escape XLT stalled in June, had the rear wiper replaced last month, creaks like an old lady's rocker and now has a funky stereo. I'm so sad!
I'm test driving a '01 Tribute and I have been looking other SUV's. In reading some of the discussions, I noticed that there are other people noticing problems with a gas smell as well? Can anyone tell me what that is? Should I be concerned about it - enough to take it back to the dealer and keep looking? Is this a sign of things to come?
Like most other reactive AWD systems, the one used in the Escape and Tribute will engage the rear wheels when there is a difference in speeds between the front and rear axles. When you take a sharp turn, the front tires drive a longer arc than the rear tires. This means that they drive farther over the same amount of time. In short, the front tires go faster. That difference in speed may be enough to activate the AWD system.
With This type of AWD activated on dry pavement, you get drivetrain "binding". The front and rear axles are locked together and will not allow one to move at a different speed than the other. Either the wheels scrub off the difference, or the drivetrain gets twisted (not likely, but possible).
I know this is true of the CR-V. Many drivers hear a whining noise during tight turns (steering wheel turned all the way) if the differential fluid needs replacing. I don't know if the Ford system requires similar maintenance. I woud be very surprized if this wsere happening at speeds higher than 20 mph. However, if you are experiencing trouble when taking sharp turns, it might be worth looking into.
My 2001 V-6 4x4 scheduled maintenance guide in the glove compartment is generic and applies to all Ford autos in 2001. It says to change transmission fluid at 30,000 miles for vehicles with tranny models AX4S, 4F50N, 4R70W, 4R100 and 4F27E. It makes no recommendations for the CD4E in the Escape. Other sources indicate only to check the fluid every 5,000 miles and service (change fluid) when needed for the CD4E.
Does anyone know how to determine the minimum service requirements for the Escape CD4E tranny that is required to keep the extended warranty valid. My local dealer is confused and says he doesn't know. I any not looking for personal recomendations on service trannys. I want the official FORD requirements.
ke4yyd - Please contact the Ford Customer Relationship Center at 1-800-392-FORD or emailfordcrc@ford.com. They will help you find your answer. Anyone else who has an unanswered question can also use this contact information.
I sent an email as you suggested. Got a reply that they would respond in 3 days. 4th day is over and no response. Don't know why the question is so difficult for them. Every new vehicle I have owned since 1956 had a maintenance schedule in the owners manual for that particular vehicle. Looks like Ford could do the same or at least provide info when requested.
Just bought this SUV in Light Tundra Metallic. Great color not so common in the Tampa Sarasota, FL area. Got ABS, Power Seat and Side Air Bags. Handles great and is a pleasure to drive. The V6 is more than adequate for power. No problems so far. In my opinion, it's body design is nicer than the Ford Escape. Zoom, Zoom, Zoom
If you need AWD the Highlander should not even be on your list. If you don't need AWD and you're SURE you will NEVER need snowchains then the Highlander with VSC/Trac will be a perfect vehicle for you.
Both the HL and the Rx300 use a VC for torque distribution in low traction conditions. In both cases an almost totally non-functional VC, regretably.
I was driving my daughter's 2001 Escape and when I tried to stop going slowly down an exit ramp there was very little brake pressure. I've driven her car many times and I knew something was not right. I pressed my foot further to the floor until it seemed to be as far as it would go and it still wasn't stopping. Finally it seemed as though the ABS system kicked in and we stopped. Still having my foot as on the brake as far down as possible, I put the car in park and pulled up the emergency brake. At that point the engine started racing at very high RPM's. I thought that the carpet was pushing down the accelerator or that my foot slipped on it, so I took my foot away to look, but it just kept racing. (My daughter who was in the car saw the tach go way up). I quickly turned the car off. Luckily I was going slowly and the light turned green so the car in front of me moved out of the way by the time I finally stopped. I then restarted the car and it seemed fine. Ironically, there was a Ford dealer right down the street from where this all happened so we drove the car there for them to check out. They have the car for 2 days and so far they can't seem to find anything wrong and have told us that Ford has not had any similiar complaints.
Needless to say, I am very concerned about letting my 20 year old daughter drive her car until we find out what could have caused this and how to prevent this from happening again.
Been here and on other Escape related boards for a while and have not heard of that.. To me it sounds less of a brake failure and more of a hung throttle case..
Read your post "Rumbling in right rear wheel" and have not seen a response. I have a 2001 Escape with 36K (fresh out of warranty) and have been experiencing the same problem. Is this a problem others are having and does anyone know what is the cause?
I have owned my 02 Tribute for 2 months/2 batteries and 3 jump starts. 1st jump needed on 3rd day, next jump needed at 5 weeks and 1600 miles. Drove in to Dealer who replaced battery. 13 days later, DOA in my driveway. Mazda is now towing it to the dealer as is.
Anyone have similar experience, advice and/or guess on probable cause?
This is a true story, it wasn't much fun, about my former Mazda Tribute, Year 2001. It rattled, it squeeked, it stalled once or twice and Mazda's district service manager, was anything but nice. "We're sorry your Tribute isn't just right, but with 3 years of warranty, hopefully you'll see the light" 13 times to the dealer, the light never came, so when the opportunity to trade arose, it took little brain to dump my "dream car" and move on. So no more will I hear "Rattle, rattle thunder clatter Zoom Zoom Zoom" Because in my garage for Mazda or Ford, there will never ever be room.
i have a little over 7,000 miles...no rattles no squeaks,no rumble,no stalls,no racing accelerator.Just pleasent secure driving.Hope those with problems get them resolved!(2002 ES,lux pkge,tow pkge)
well obviously, the dealer does not agree it was a short. They again replaced the battery saying it had 2 dead cells - they say they tested it before installing it and it was OK at installation, 400 miles earlier. Only a sad coincidence, they claim, that this is the second bad battery that was put in my car. I have no choice but to wait and see how long this one lasts - they told me that is why Mazda offers roadside assistance - to help when I get stuck!! That is suppose to make me feel better about a new car that doesn't always start.....
Its a short. Batteries, especially new ones just don't die in 1 month. Make them find the short. Start keeping all records. When it does it again, (It will) don't take it back until they fix the problem. make them give you a loaner car. zmeenow, I too am a satisfied 01 Escape owner with ove 18,000 trouble free miles...
even want to find a better mazda dealership for service - some of them are really bad, like the one near me, where the service techs are incompetent, and the service writers are impatient.
You need someone to find that short, and if it is warranty work, they will not be too happy, because it can take a while to dig around to find a short.
I have a 2001 V6 Trib with the same symptom. Shudders, vibrates at around 45 mph and then around 55. Like you said, especially at a slow acceleration. Did your Ford dealer solve it? Anyone else with tranny problems?
Just turned 24,000 on my '01 XLT Escape with no problems at all. I have not had the Escape stall once. I have not had the Gas smell (except type caused by Bush's Baked Beans) I have not had any rattle or squeak from the rear hatch or any door for that matter. I have not had any wind noise to complain of (and I've been as high as 95mph)
So in all my wife and I are both happy with the Escape. In fact we have had more problems with her '00 Civic EX.
My 2001 Escape seems to do it at roughly 45 mph, but while I'm accelerating up, going up a hill, passing, etc. At first I thought it was the tires or road. Mine now has over 38,000 miles, but I have the 100,000 mile power train warranty. Question for Odie where do you find Bush's baked beans? I've searched everywhere. Both you and Scape2 are so lucky to have one of the few Escapes not to have a problem at all. Which dealership did you buy yours from?
I'm in the Hershey / Lebanon Area of Central Pennsylvania. The baked Beans are at all the local supermarkets. As for where I bought my '01 Escape... I ordered it at a local dealer here in Hershey,PA and got 1 of the very last to come off the 2001 assemebly line.
My current Escape might be getting a nice christmas present for http://www.autoanything.com in the way of a Full front end Grille Guard (with brush bars) and Rear Tail light Guards and Rear Bumper Guard. Just have to talk the Wife into allowing me to Purchase them. Because now that we have a baby comming, we gots to save our money. I'm probally going to be getting a Rear Seat DVD system (from circuit city)mounted on the ceiling, and even with the Sunroof it still fits.
Mike
You might want to involve nearly every make of car with rear roll down windows. Wind buffeting is common among many cars.
MIKE
'Where are you now'
Interesting parts:
Baggs,
Yes, I would think so!
Odie
(proud owner of a 2001 XLT Escape)
Anyone have any info on these problems?
Thank you for all of your comments.
Sorry for the problems. Please contact me offline if possible at lori_fitzgerald@yahoo.com and I will try to be of more assistance. Thanks.
Does anyone have a similiar experience or answer?
Go to the following and read all about it.
http://www.escape-central.com/1forum/showthread.php?s=&threadid=2410
Unless you are leaving the lightson all the time or something...
Thanks for allowing me to vent!!
Odie
Odie
