Lincoln LS Transmission Problems
Maybe I'm just paranoid from reading about all the transmission problems with the LS, but I am wondering if I should be concerned by a vibration that seems to come from the transmission at very low speeds. The sensation is almost like a shudder, similar to when you try to start in too high a gear in a manual transmission car. The problem doesn't seem to be the engine, because the tach shows over 1200 rpms. Is this how the transmission problems in this model first manifest themselves? Or is this considered normal for this car? The car has less than 500 miles; If this is a problem, I'd like to get it documented and fixed now rather than have it be a bigger problem later. Thanks..
Our '06 has ~3600 miles and runs flawlessly. If you think you have a problem, by all means, take it in!
The LS is the first American car I have ever owned (it's my 6th car in my lifetime), and I guess I am a little leery. But so far I love the car and hope it holds up.
They have to keep it for about 2 more days, and told me it was an electrical problem, and the work is not warrantied because they can't warrant electrical problems..
By the way, what was your total price including labor?
Also My TRAC/ABS light has been on for about a month. Im sure my ABS wheel sensor is shot. Can i damage anything by driving it this way?
Sorry but I don't know about the sensor
I now have a problem with the airbag. The airbag sensor light is constantly on. According to the only Lincoln dealer on this Island , the Airbag harness needs to be replaced. The part cost $60.00 and to have it replaced cost $400.00 Go figure...
my ls is making a funny noise it actually sounds like a deisle engine the noise seems to b cumin from tha tranny but i havnt put it on the lift yet has any1 else ever encountered this prob becuz im gettin the hard shftin from "D" and "R" aswell ... :mad:
Codes from the computer are; P0734, P0735, P07945, these came from the dealer who said it may cost as much as 3500
Their explanation/diagnosis is unsatisfactory. I'm sure they have a whole series of diagnostics they can run on your transmission before condemning it. Line pressure? Leak in accumulator? Maybe you do need to go elsewhere. This could be electronic or internal.
P0735(gear5ratio)P0791(internal shift speed cencior A-circuit)P0795(pcsc pressure)P1270(engine speed limiter). They said internal failure needs rebuilt at the tune of $2700 and that the bands for 4th and 5th gear were probley damaged. Also they handed me a cup with brown fluid and said this was my fluid(wasnt red like the day before). I asked them about the s-pack and he told me that if I replaced that it wouldnt fix it becauce the gear ratio codes were first in the order. I told them I needed a second opinion so Im going to bring it to the dealer. I wanted your opinion in the matter and if the order of the codes mattered? The (yellow)engine light goes off with a full tank of 92 octaine. It will shift into 4th if you going slow. After the car is turned off it resets everything and you start the procces over. After the "E" comes on even the lower gears are felt when shifting but not before. Could you give me some advise?? Please. I love this car and have no warrenty.
Prior to that I had $900 worth of service done due to a noise coming from the engine.
I think we all should go together and do a class action law suit. Only 3 years old, still making payments and steadily going to the shop.
Who is that we you're talking about? Got a mouse in your pocket?
In case you hadn't noticed, the LS wasn't exactly a colossal success & is no longer in production. Most of the transmissions at least worked, but beyond that, the bulk of the people who ended up driving the car couldn't tell the difference. I'm going to guess that you didn't pay exactly a fortune for this thing.
Craig
