Chrysler Town & Country Warning Lights
I have the infamous check engine light that just came on my car. It appeared 6 months ago, changed the gas cap and was charged $120 for the cap and diagnostic check.
Just recently, the check engine light came on again. I did a trick to do the diagnostic check myself. turning the key on and off a few times will show you the codes on the odometer. When I did this, the following codes displayed: "P1684 and P0135". Does anyone know these codes and how to fix?
See Also
OBD-II (Check Engine Light) Trouble Codes
See Also
P0135 indicates a malfuntioning O2 sensor. Available at your favorite parts store for about $75 bucks.
Hope this helps.
I can also smell burning gas and the whole engine (and the car) are shaking like Little Richard.
What's wrong and what to do?
I have a 04 Town and Country with 43,000 miles on it. In past months, prior to my warranty running out. The check engine light would come on. Chrys. said #2 was misfiring, so they replaced it for free. The warranty has since expired, and now it is doing the same thing. So, I took it to our local auto zone, for the free check and they said #3 was misfiring. I just tried doing the key turn 3 times, and it gives me a code of P030303. Is this the same thing as #3 misfiring.
E
I have a 2002 Dodge Grand Caravan and the check engine light is on. Are there any self diagnostics I can do? I did the turn the key on and off and I ended up only with the p1684 code, and nothing else. Any help would be greatly appreciated!
P 0442 and P 0456. Can someone tell me what they mean?
Thanks, Jack
Thanks in advance!!!
ON-OFF-ON-OFF-ON
with about 1 sec in each position. At that point, the CEL should start blinking the diagnostic code. There's a series a quick flashes with a longer pause between the sets. Each set is a digit, determined by the number of flashes in the set. So for example, the code 123 would look like this:
BLINK-PAUSE-BLINK-BLINK-PAUSE-BLINK-BLINK-BLINK-PAUSE, then repeat.
1 2 3
1) Fix whatever the problem was that kicked out the error code in the first place.
2) While pressing and HOLDing the "Trip Meter Reset Button" down turn on and off your ignition 5 times. You don't have to start the engine, just turn the ignition key until it get's power the 5 times.
3) You should get a display of 5 dashes (- - - - -) then a display that reads "donE"
4) In my case I had to drive the 2004 Town and Country Van a distance of 2.8 miles before the engine light went off.
NOTE: I kept on starting up the engine after I cleared the code about 10 times expecting the engine light to go off but it never did until I drove the van for a few miles. There must be some combination of engine start ups and driving distance requirements before it'll go out but this combination worked for me.
Good Luck
Thanks in advance
Brandy
P1684-The battery has been disconnected within the last 50 starts
Thanks for any assistance.
Captain IBC
OBD II Codes
Trying to figure this out myself because I don't want to take it to the dealer but getting frustrated.
I will go back and re-read how to find the code but any other advice besides taking it to the dealer?
TY!
