Chevrolet Uplander Brakes and Rotors
uplanderguy
Member Posts: 17,098
in Chevrolet
Our Uplander has 21K miles and while the brakes don't really pulsate very noticeably around town, they do when braking firmly at highway speeds and also when braking firmly going down a big hill. It's been this way for several thousand miles but hearing the retail replacement cost of these rotors in an earlier post, I was hesitant to having anything done to them right then. However, in the next couple weeks I think I am going to have my dealer resurface them, which I know is only a "Band Aid" fix. I'm almost certain this will be a warranty item. Has anyone on the forum gotten their dealer to REPLACE rotors under warranty yet (after one or two resurfacings)? I read pretty carefully the TSB on "Brake Warranty Service and Procedures", from the link in message #2683, and while it says that for pulsation concerns, rotors should be resurfaced not replaced, it also says "Important: If the scoring depth is more than 1.5mm after the rotor is refinished, it should be replaced."
Just curious.
Bill P.
Kent, OH
Just curious.
Bill P.
Kent, OH
Bill P.
Kent, OH
I moved them here to start the discussion -- they were here at the time, so I'm wondering if the server burped during the transfer. I'll try to find out.
As for the name, ack... that's my error and I apologize. I've corrected it.
I am beginning to hate my GM purchase. So many issues... :mad:
The last one (at about 16,500) they wanted to charge us for. I made a big stink because I had already had them done twice in the first 12k (predictably, at roughly 5 to 6k intervals), and went to the trouble of calling the Customer Assistance number. After much deliberation they ate the cost for the last resurfacing, calling it a "goodwill" measure.
Goodwill my foot! I've had four other vehicles during my time in this area, all driven in the same conditions and having all their service needs handled by the same dealership. The Terraza is the first to have any problems. Yet they insist that it's how / where we're driving that is causing the problem, not the design (maybe undersized brakes causing overheating in situations where that shouldn't occur? :mad: ).
When I pointed out that three of the other vehicles weighed the same as or more than the Terraza (all had 4 wheel discs) but never experienced the issues all they could say was that different vehicles were designed for use in different conditions. I then mentioned that none of them were driven in extreme conditions- this is all highway (some mountains to cross, but no heavy braking on our part even then).
No dice. So the next time I'm going to try to correct the situation for good with a complete replacement with non-OEM parts.
Interestingly enough, the 2006 models of all the CSVs quietly switched from a 5 lug tire pattern to a six lug pattern. There was (and has been) no explanation available for why this happened. Now that I've had these issues with the brakes and read similar reports from others, I wonder if they haven't gone to a heavier duty setup, and that was a six lug (GM light truck / SUV) system.
Since my earlier posts to you, I looked again at that TSB and the warranty booklet with my Uplander. ONLY "Brake Pads/Linings" are mentioned in the warranty booklet as maintenance items. Rotors are neither pads nor linings, by anyone's definition.
My dealer REPLACED rotors on both my '02 Venture and '02 Cavalier at 39K and 35K miles, respectively, a couple years back. Both were done under warranty (I never buy an extended warranty). I had had both vehicles' rotors resurfaced once by them, prior to the replacement.
I gotta believe had you showed your dealer the TSB and asked where in the warranty does it mention rotors, you may have gotten some satisfaction. The Customer Service number, even my salesman commented on how hapless they are a few years back...he said once he had to explain to them what a "G" Van was (full-size Chevy or GMC van).
I agree, long-term, it will probably be best to buy aftermarket. Too bad you will most likely be forced to do this before 36 K miles.
Bill P.
Bill P.
This brings up and interesting question. Are people having the brake rotor/tire wear issues with the '06 model since it has reportedly changed to a 6-lug design?
The work order also mentioned installation of shims. When I asked my Service Advisor (whom I know and like) what this was, he said it was something new to help alleviate brake pulsation. When I said "Hallelujah!", he said "let's hope for the best, I can't guarantee that'll make a difference"!
I do notice more "dead pedal" before the brakes grab, then before, for whatever that's worth. I also noticed the steering wheel off-center slightly to the right...it definitely was not like that in the morning before being dropped off, plus I had paid for a four-wheel alignment there only three months before. They corrected that aspect of the alignment for me, yesterday, free.
Bill P.
Bill P.
I had all of the brakes replaced and the rotors resurfaced June of 2007...the van is pulsating...so I bet it is the rotors again...does anyone know if the GM silver extended warranty pays for this resurfacing again.
I hate this van...the door won't open remotely, the rubber is scrutch up, the gm service person tells me it is fine...it opens when it wants too...so embarassing....the vcr constantnly winds itself....Hate it...
Oh well, any help on the extended warranty would be appreciated!
hatemyuplander! :mad: :mad:
Thats about the same distance i did with my Sienna. However, the ABS system is quiet on the Uplander, where it was noisy on the Sienna.
We need some good news at times, voila.
Stanyh
Honza8
I have put three sets on now in 95,000Kms
the gm rotors are crap :lemon: and I am sick of changing them. Dont bother turning them they might last ten days.
I am in Germany and having problems getting a good heavyduty rotor.
Any help with a part number store that ships to Germany would be greatly welcome :
Can you forward the details on the heavy duty rotors for us to get as I cannot find them anywhere! I desperately need rotors and I am tired of buying the stock cheap ones from GM.
Please help !!!!!!!!!! : :shades:
Here's the important part: Once you've installed them and put the wheels back on, you need to "burnish" the rotors...The procedure is listed in the GM repair manual. If you don't have the manual here's what you do: Go for a drive around your neighborhood. Accelerate to 30 MPH and then firmly come to a complete stop without "stomping" on the brake pedal. Drive a little bit (about 30 seconds or so) and then do it again. repeat this about 25 times. What is happening is that you are building up a layer of brake pad material on the rotors which will protect them once you go back to your normal driving routine. I did this 40,000 miles ago and still stop as smooth as the day I replaced the rotors. Problem solved. :shades:
i need to find a store that will ship to a PO BOX I have in Belleville ON.
I'm military in Germany. From Belleville they can be shipped to me free.
do you know of a good parts store in Canada.
I've had good luck with them and their prices are very competitive with your local store... :shades:
They want to much money to ship them to Canada.
They want the same amount to ship as they want for product.
I guess I will have to find a store in Ontario Canada or have a friend ship them personal for me.
tyvm
I believe its a size "T20" but I'm not 100% positive - I did mine a few months ago.
I have a set of torx screwdrivers that I use for removing taillights & such...its pretty tight so I used a wrench on the screwdriver to get it off. If you don't have a set of torx head screwdrivers, now is a good time to buy them as you'll use them more than you think...
Make sure you put a little never-seez on the screw threads before you put it back in so its not too hard to replace next time you have to take the rotor off.
I have new rotors for mine and so far so good.
Anyone else with 95 Uplander rotor problems do not replace with OEM parts.
GM or AC Delco rotors are a waste of time and effort on this van. My forth set is now installed with only 102kms. This time i went with after market rotors and it did the trick.
Step 2 -The Uplander ABS system likely needs to be bled using a scan tool if air made its way to the brake modulator.
Thank You for your help,
Tommie D
I'm just a parts changer too so I understand exactly what you're going through.
Thanks again!
When you change the rear pads, do yourself a favor and buy the special tool to back out the calipers...it looks like a little metal block...you back out the rear rotors by turning them with the special tool...not by using a c clamp to push them back in...
You might already know this but I figured I'd put it out there in case you weren't aware of it...also, when you push them back in, before you do anything notice the orientation of the tabs on the pistons and make sure that before you put on the new pads that the tabs are in the same orientation...otherwise your pads won't self adjust...
Like I said, you might know this already, just wanted to throw it out as a tip since I've already done the rears on our Uplander....
:shades:
Thank you again!!!!
I can't say for sure but if it took an extreme measure to compress it I would say it should be checked out by a professional at the very least. Most times people can't get it to budge without the tool...
I had a 2006 and just got tired of the brake issues. The van was the family vehicle and I hate to say it but it is the worst GM vehicle I have ever owned.
I have worked on cars since I was 7 years old and have done all my own work. This vehicle has the worst designed brakes that I have ever seen. I changed the front and back brakes at the same time and within about 6 months the rear brakes were gone but the fronts were fine. I also had multiple issues with the sliding doors and the brake dust the covered the wheels was bad. Wash the car and within the week the wheels were black with dust again.
I traded it off and got an import.
Example: my 85 Astro needed a new starter when it had 157K and new brushes ($3.15) for the altinator at 175K. It started smoking when I started it up after it sat for 3 years while I was stationed overseas. It never gave me any real trouble, except for the paint. The breaks on the van worked well and lasted for about 2 years front/ 4 years rear. I loved my Astro and wish I had never traded it in. The 1999 Astro was starting to have transmittion trouble so I decided to get the Uplander.
I have always bought Chevy, currently I have a 1967 3/4 ton pickup, 1979 El-Camino, 1984 S10 Blazer, (work in progress 1940 PU) and my first car was a 1968 Chevelle, 327. Then I bought the POS 2006 Uplander, this van has changed my mind on the way I buy cars.
1. THE WIFE HAS TO LIKE IT.
2. Safety: the car must have a good safety rating.
3. Warranty: a long warranty indicates to me that the company believes in their product.
4. Fuel economy: Gas prices are high and Chevy does not have the best MPG ratings
Electric cars do not have the range I need, but KIA has plans for one that
not only has the range but does not take forever to recharge, 8 -vs- 24
hours without special equipment.
These two are the first four categories I am looking for besides styling and comfort. I don't know why MPG is still so low, I had a 1983 Pontiac J2000 station wagon that got 39MPG and would drop to 36 when the plugs needed to be changed. My 68 Chevelle would get 16City and 21 highway. I also had a 91 GEO Metro that averaged 48 and the best I got was 53.9MPG.
Now I have an import and feel good about my purchase because I am not worried about making it safely to my destination.
