Chevy Express/GMC Savana: Brakes
I have a 2001 Chevy Express
The brake lights LT, center, RT will work fine until I turn the parking lights on & then when you apply the brakes the LT & RT go out & only the center will light up as a brake light. As soon as you release the brake pedal the center goes out & the LT & RT will light up as parking lights. If you or anybody has an answer please reply.
I drive a 1997 GMC Savana 1 ton van. The two outside rear brake lights don't work, but the upper center bar brake light does. I've checked the fuses and the lamps and they are OK. Does anyone have any idea what could be causing this? Thanks in advance for your replies.
I have an Express and I encontered the same question.
It might be the same answer, I took a look into the lamp socket and found that there where no contacts for the braklight!!!
This means I have two taillights on each side and just one brakelight on each side.
BRGS Stein
Did you find an answer to your problem?
I have a 2001 Chevy Express & am having a simular problem.
My van is a 2001 3500 with the 5.7. It's got 121,000 on it right now. It is leaking coolant on the right side of the block. Looks like the head gasket, but it could be an intake gasket (hopefully).
Has anyone had this problem?
It looks like the GMC vans must have a problem with water getting into the lower socket since there a number of people posting with the same problem.
Hope this reply can help out and i hope i'm being accurate enough as it has been two years since i did the repair. It is still working perfectly today.
I notice these vans every day on the road with brake light problems. Don't know if it's moisture related or under rated/inferior materials
You can try asking in the Stop here! Let's talk about brakes discussion if you don't get an answer here. Hope you get this resolved soon :-)
This doesn't seem right--the bearings will be falling out just to change the rear brake shoes. I guess I could take a digital picture of the situation and ask at a brake shop, but I thought a would try this forum. Maybe there is a forum out there for mechanical questions. If someone knows of one let me know--I've got a lot more work to do on this truck.
1st off does anyone know where it is located at?
Maybe a Chevrolet Part number I can cross referance OEM versions
And thoughts of obtaining one from a Salvage yard...it there a way to test one from a salvage yard with a meter if I talk my meter with me?
Thx for any help.
Respectfully,
Auto Marine on Wheels
Having the same problem, confirmed myself that the socket are bad, the actual problem with the sockets are the way "they" attach or make contact with he ground wire to the socket. Its a pressure fit and my guess is dissimular metals. Add moisture to the picture and you get corrosion. I replaced both sockets to correct this problem. Using a NAPA replacement part.
You would think this would call for a re-call.
jcintc
'06 Express 3500 12 passenger van. Loaded up with people coming down a 9% grade (Jackson Hole, WY). I am a conscience driver and pay close attention to the vehicle, especially around extreme conditions. I was descending this grade with moderate speed and typical braking. The more I used the brakes, the more they became pulsating and alternating in the front (steering wheel shook back and forth ever more aggresively). I became very nervous as it became very severe and quickly downshifted the transmission and avoided the brakes as much as I could. I was certain that I had over used the brakes (even though I was paying attention and didn't think I had). I was certain I would have to have the rotors turned and brakes replaced in Jackson, WY. Silly think is once I was on level ground, the vibrations completely disappeared. With shaking that violent, there is no way that the brakes could have been that hot and the rotors that warped and not remain that way. Once rotors are warped, they are warped. But I tell you that I have not taken it in yet and they are as smooth as the day I purchased the van. It is like nothing ever happened. I do not understand why this could be.
Any help? :confuse:
Have you found out the problem with yours?
So, if you need parts you can use denali awd brake parts, or if you want exceptional braking you can purchase or get lucky and trade like I did for a baer like system that is for the 1500ck trucks....all the same, and most of the suspension if its a torsion bar front end truck, like the awd denali, awd escalade etc...
Shocks, will not and do not raise the ride height, but may help aot with wheel control and ride. We have done shocks on a friends 04 awd, and a rear sway bar. The shocks helped, they are the strongest bilstiens we could get. Ill have to get the number. They work well, but for all around comfort and performance we were thinking of trying the edelbrocks on mine. A lot of shocks are made by one company and reboxed etc ....ie rancho's are really monroes I think. They are about 90% sales pitch and 10% good shock. The guy that owns the 04 I referenced is a suspension guy. I rely on him for alot of information.
Since your using it offroad, if your worried about getting stuck, find out if your awd is equipped with a positraction in the rear. I think it was an option, but not sure. Id bet most are open anyways. Lots of options there, but costly also.
I se you have a 2500 awd? I researche dit abit, and found that (I think) the 2500 is really just 1500 with options. It was unconfirmed but I think the "2500" gets different spring rates and thats it. The tow package gets 3.73 gears, and teh stiffere springs I think. A true 2500 should have gotten 8 lug wheels(or a 6lug 2500 diff), the 4l80 e trans with a 6.0 engine, but I m nearly 100% sure they never built such a van.
Anyways Ill try to remember to talk to my friend, he has teh part numbers, interchangability etc all memorized somehow.
He is sorta like an encyclopedia on allthings suspension/van and truck related. His back ground is very very heavily offroad, and rock crawling etc.
I thought it showed it, sorry.
The side (actual intake gasket) sits on the cylinder heads on each side, the intake bolts down to the heads with the bridge of the block itself in the middle at teh front and back about 7 inches across.
An intake gasket leak would be rare, and might be possle to fix just by tightening the intake down a bit. Most common is an oil leak from the back along the bridge area. I think the information regarding the fp regulator being in the intake is incorrect. Most are on the the intake, but on a tbi injected 99 model I dont think its even near the tb. It ma even be regulated in the tank.
The gaskets are about 20-30$.......and it would take awhile to do. In my van I have to remove the front seats just to get the dog house off.......
you do need atleast 18 wheels to clear the large rotors. I scored a bear brake systems aluma brake system from a guy with a denali trading it in. The bear system is (4) 14 inch rotors with 4 piston calipers, I ve never been into brakle systems....I build power for going fast. So far the bears have saved it twice from accidents....and the stopping is incredible. I run 20 inch wheel with 275 tires too.
It has a 10 bolt diff.
I have a 2003 Express 3500 with both the ABS and Brake light on. Before going to a dealer and paying 90.00 to diagnose, is there a fuse for the ABS under the hood? If so, location?
Thank You,
Shawn
