Ford Aerostar: Care & Maintenance
 newaerostarman
                    Member Posts: 2
newaerostarman
                    Member Posts: 2
                                  in Ford
                    just bought myself a 93 Ford Aerostar 3.0 L V6 XLT Sport, it has 252,400 KMS, now I've read about all the problems linked with these vans but I've also heard all the good things about them too, I'm just hoping I can get 3 or 4 good years with this van so I can save up to get a better vehicle down the road.
I'm prepared to do regular maintaince on the van but nothing too too major.
Can anyone give me some details on what to look for with the 93 model year Aerostar? Thanks in advance.
http://www.ford-parts.com/
Rock on Aerostar,
Regards, Aeroman
The hardest part was removing the starter from under the van, you need to remove the front drive axel in order to get it out ,
Starter is located under the drivers side of vehicle 2 bolts it out enough wire to pull it down and remove the cable, relatively easy once I located it and got the an jacked up, I had to lower and move it once in order to get to all the bolts on the drive shaft, just roll it back a few inches and jack it back up again.
Vicki
I have had a 93 Aerostar XL Sport for about three years and have had great results with the engine, but had to rebuild the transmission twice and replace it after that. There is an oil leak so be sure to check your fluid levels weekly. Also replaced the fan clutch, radiator, power steering pump and seals (check the seals first if you begin to lose power steering fluid; maybe your pump will last a long time). I met an engineer whose wife goes to church with me. He was on the development team at Ford for the Aerostar and was pleased to tell me that the engine should last 500,000 miles! Mine has 258,000 on it and I use it in Florida to deliver fruit and vegetables to needy people in the Orlando area. I too hope it will give me three or four more years of good service. Hope this helps.
I do not speak English and I request excuses to them by the spelling
To train the next gen of auto mechanics. A vocational technical school requested they be allowed to work on the Aerostar under supervision of a certified mechanic instructor. The camber tool will ultimately be donated to the school for future use.
