Visitor Agreement.
One way to make sure you don't get wax on your cladding is to use tape. I have done this a few times and it works great. Does take time to put it on but saves you time in not having to scrub off wax off the cladding.
Also, I highly recommend the 3step Meguiars 3 step also. Takes about 3 hours to do it but makes your paint look great!
I took it in to our dealer at 8:00 am yesterday and by 11:00 they called me and said it was ready. I was expecting to get the old routine, "we can't duplicate the problem," but instead they said there is a bulletin to correct the problem. They flushed the transmission and flashed the pcm and this worked. We had not noticed how hard the transmission had been shifting in all the gears before the fix. Now it is very smooth with no shutter going in or out of overdrive.
We've had one experience with the Tribute's motor dying while driving at 35 mph and going downhill about a year ago. We took it in and they said they fixed and we have not had another incidence like that. With 27,000 miles so far, we have been very pleased with our vehicle.
By the way the tires still look new. Continental Conti tracs.
I have never heard of any Escape or Trib being so loud its actually painful.. I admit the wind noise is there but painful, no. People must remember the Escape is an entry level SUV and a truck. More of a truck than others in this class..
I bought a 03 tribute - knowing fully well that probably the only downside was the noise. while it is noisier than my other sedan - altima, it is about as noisy as my eclipse GSX that i traded it in.
Does anyone know if the noise levels in this SUV have been addressed since 2001 thru 2003/4 models ?
Also, have the earlier model owners found that changing their tires have addressed some of the problems ?
The reason i ask is that in the 2 days of driving my new tribute, I find that more than the wind noise.. the noise is really coming from the tires..
so maybe if u changed the continental contis.. to maybe the michelin cross terrain SUVs.. noise might reduce and u can get better handling.. esp in snow and wet traction.
any comments/feedbacks ?
1) Ligths dim when using power windows.
2) Gas pedal vibrates more than normal in city and highway driving.
3) Rusting on front brake clamps where the silver metal piece enters the black clamp (sorry...not a techy).
a. The rears wheels only do about 25% of the braking vs the 75% for the front.
b. More importantly, the rear brakes are drum rather than disc.
I've noticed that my 01 Escape seems not to produce as much brake dust at 30K miles like it did earlier in its life. Still on origional pads/rotors both still have alot of life left in them.
Has anyone experienced these stalling problems on a 2003 model? Or does anyone know if Ford has addressed this issue already?
Also.. does anyone with a 2003 model have any comments on problems they've experienced?
Thanks in advance.
I just realized the other day that I haven't been to the shop yet for any problems, where as with my VW I was already there 3 times by 7500 miles :-)
Today, my wife was stopping in a parking space outside her bank about to shift into park, when the acclerator reved again, sending her into the wall of the bank.
Has anyone else experienced similar unexplained acceleration/reving problems?
I'd say on the plus side, the 5mph bumpers and air bags worked better than the brakes. In fact the front disc, rear drum combo on the Tribute is a real weakness, especially compared to the 4 wheel discs on my daughter's protege. Overall we loved the Tribute until now, even with some weak points, We only got 20mpg on the highway at steady speed, so that was poor. but handling and driveability was good, until the crash. Storage space was good too.
As 80% of hard braking is done by the front wheels, it seems like the rear drums are more than up to the task.
Do you have a Tribute? Please tell me your likes and dislikes. All-in-all I am still very interested in purchasing one. Thanks !!
The Escape has been a great step UP from the mini-van we used to drive.
I did not expect so many major problems that could actually be life threatening if they happend on the freeway at 60 MPH, in addition to repeatedly bringing the vehicle back to the Dealer. I myself, am living with a potential "time bomb"..... an Acura 3.2 TL, one of millions that sooner or later (hopefully MUCH later) have transmission failure and must get the entire transmission replaced.... and this is a $32,000 vehicle !! I started out last month, expecting to purchase a new MAZDA6s, but just two weeks ago I was notified I am being transferred back up to Connecticut (land of snow/ice/sand/salt) so my needs have quickly changed to an S.U.V., but one that handles and accellerates well.... and one that is on the ROAD more than in the SHOP !!
You mentioned 'life threatening' problems? The Govt gets pretty hyper when vehicles have 'life threatening' problems and thus they issue recalls.
When the Escape was first introduced 4 years ago, there were some recalls. But none for 2002 or 2003.
The purpose of akerman is to allow the vehicle to track correctly through a corner and since the inside steering tire travels a shorter distance through the turn, it must be turned more.
But the most likley cause of your irregular tire wear is: Rotation, inflation, alignment.
Because each corner of the vehicle does different things, that corner has a characteristic wear pattern. To prevent this wear pattern from becoming so severe that it causes irregular wear, tire should be rotated on a regular basis.
Misalignment and low inflation pressures will accelerate the wear, causing it to appear earlier.
Hope this helps.
After I bought my Escape I kept hearing about "All these problems". I took it upon myself to do a poll. Everytime I saw a person and was able to approach the owner of either a Trib or an Escape I took a minute to ask them how they liked there vehicle. I stopped counting after about 30. Not one person complained about "All these problems". Granted, there were minor gripes and issues. But not one out of the 30+ owners said they are never going to buy a Ford or Mazda product again.
My Escape has been perfect and flawless for me.... I am sorry for those of you who have had issues. But after 2 years and my talking with numerous Escape/Trib owners "all these problems" are in a very, very small percentage.
Sorry to hear about your Trib.
rep, with all due respect. I think your points are totally valid. If I had an Escape/Trib with issues I too would be posting on this board looking, hoping for some sort of advice to remedy the problem. In my experience I don't see these as the troubled vehicles some like to portray them as. My Escape has been through some pretty tough terrain, pulled loads just below its limit and has come through with flying colors. I have only done routine maintenance and it still feels strong and solid as day 1. For now, good luck to you..
in response to wenreder, scrape2, i did a search on this discussion roup for 03 - looking for problems with 03 tributes. didn't find much.
As others have said.. 01' being the 1st year model. had some problems.. as happens with many new intro. models. but since then, i think ford/mazda has done a good job and fixed the problems.
I am not aware of any major trends or problems on 03 models.. and none of the existing under 20k wagons fit our needs.. so we ended up buying a SUV. an 03 Tribute EX AWD. This car is for my wife. so i wanted to buy her a safe car.
Mind you.. with any car, there will be a few with problems...even the famed toyotas. just something to keep in mind.
Finally to wenreder1...
if u r moving to connecticut - and was considering a Mazda6 before.. I am not i understand ur need for a Tribute.
Unless u want to tow a lot of stuff once u r living in connecticut.. or something like that... i don't think SUVs are in general that much better for the snow. Mind u.. i own a tribute and live in Boston.
so check ur needs and buy a vehicle accordingly. If all u need is a sedan, then be rest assured that most NE states are pretty good in cleanign the roads.. so very unlikely that u will be travelling in roads that are covered with many inches of snow. unless u happen in live in rural roads. in that case, u need a SUV. and a tribute will do u good. else. Mazda6 will be just fine. If AWD gives u that sense of satisfaction, then most NewEnglanders tend to buy a Subaru.
u may want to consider that.
Does anyone have any experience with this?
Please email me @ jaimesturg@yahoo.com
