Ford Windstar Warning Lights/Codes
                    My check engine light came on and it is the O2 sensors, which I have not replaced, but today my husband was driving it and he turned the corner and hit the gas real hard and now it won't go anywhere.  When you put it in drive it don't act like it is even trying to go in.  We weren't having any signs of transmission slipping or anything it just quit just like that.  Some one please help this is my only vehicle and I have 3 young kids.
I have a 2000 Ford Windstar SE... A friend of mine replaced the rear brake shoes (drum brakes) for me while on vacation in Florida. After driving the vehicle for about 3 or 4 trips, the ABS light goes on and the ABS system is disabled. Other than some brake squealing which is what we tried to eliminate before, no other noises heard. Anyone have any idea why the ABS light would turn on after replacing pads/shoes?
The squeal you heard is because the back brakes need to be adjusted. You can do this easily and keep them in line by using the emergency brake every time you park.
My light has been coming on now for about 6 months with the red brake light on, nothing else. Nothing seems to be wrong with my braking, thankfully. I take my car to Firestone, been going there 8+ years and trust my mechanic and they run a diagnostic test on it, dont charge me the $75.00 every time and they clear all the codes from the module assembly and they tell me the same thing that it shouldn't interfere with my braking system and that it should be covered under my warranty with Ford. Of course when I took it to my local dealer they put it under the diagnostic test, charged me $100.00 and within 20 minutes told me I needed a new ABS electronic system and it would be around $1800.00, not including labor.
We are fortunate, this is the only major problem I have had with my van at 50,000 and I have been very happy with the Windstar. It just worries me that this has been going on for years and is still not fixed with newer models. I still don't like the idea that I'm driving around with this light on wondering everytime will my brakes work or not. I'm going to pursue the warranty issue with Ford and will post an update if I learn any new information to share with everyone.
Genstym
From what I have read, the ABS module does a static test when the ignition is first turned on. It checks the resistances to the various sensors and if everything is within spec, it turns the ABS light off. After the vehicle reaches a certain speed, 10 mph rings a bell, it then checks the system dynamically looking for proper voltages from the wheel sensors. It also performs some type of a test on the actual abs pump and actuators. If this passes, the light remains off, otherwise it turns on.
My ABS light seems to come on after the dynamic test. I get a code of c1185 which points to either a wiring issue or controller failure. The funny things is that it does not come on all the time.
I hate to replace the module if it is just a simple wiring issue. I heard mention of the ground issue/kit and just wanted to get more details.
He said that the problem is with an extra ground wire that just needs to be removed. I think the fix kit includes a wire cap. I will give him him a call and see if he can fill me in a little more on it.
Melissa
Jim
I have the same vehicle same year. I could see a comment refiring this ground conection and a "kit" refeired for that. If you know how is that kit, please let me know. I try to fix this problem too.
Arnaldo M
Could you explain me what kind of kit it is?
What I need to do?
Arnaldo M
Please let me know if you have news about it.
Arnaldo M
My question is if anyone knows if there are cycles in mileage where the engine light may automatically go on (such as current approx. 130k) even with not problem. I hate to try to pay to chase this down if there is nothing wrong or light can be easily turned off if no actual engine problem. As it also turns out we are buying a new vehicle and cannot sell/smog the 1996 Windstar in CA with the engine light on.
If it is anything serious, they will let you know and you can take care of it then.
Good luck to you.
Keep checking your gas mileage. If the mileage runs good, ignore this code - it means nothing, and it will not hurt your engine.
If the gas mileage is bad (less than 20 on highway), check possible intake leak.
If the gas mileage is bad, and you have a rough idle at warm engine (stop at red light, or restart at warm), consider to replace idle air intale valve.
If you don't have the above symtom, EGR valve or controller is to blame. It's your option to replace it or not. This repair only helps to clear the code. If you don't care about $100, replace it. Otherwise, keep going and you should be fine with the OBD "Check Engine" light on.
Hope this helps.
Check it and it should help.
My Parking Light stays ON. I have checked fluid and wires too. Any expert advice on this issue or the only option is to take it to a technician.
Does it make any problem if it stays ON as I don't feel any problem in braking or somewhere else.
Any help would be greatly appreciated.
Anyone any ideas on what else we could check? :confuse:
Good Luck
Before today I thought this issue may has to do with some part of brakes getting hot, these warning lights come on just 15 seconds or so after I start it up -- if the car was used recently -- ; or after 7 or 8 minutes after I start it up by first time in the morning when car is completely cold.
It is not difficult.
Mrb43
My tire light is on, does that mean that I have a low tire. I pressed the tire reset button but it stays on.
The light is on that looks like the emblem at the left side of my headlight switch. What is it?
Has anyone got any ideas ?? :confuse:
Any help would be grateful
This van has 112,300miles
codes are c1155 lf speed sensor input ckt failure
c1233 wheel speed lf input signal missing
B2477 module configuration failure
not sure what any of it means need to take to mechanic
C1155 Wheel Speed Sensor LF Input Circuit Failure ABS
C1233 Wheel Speed LF Input Signal Missing ABS
The B2477 error looks like it could be related to the ABS system, and replacing the supposedly defective left front wheel speed sensor should fix all three errors. If you are afraid of doing the job yourself, call a couple of different shops and ask them for a quote for replacing the left front wheel speed sensor. They won't want to at first, but if you insist they should be able to give you a quote for parts/labor for the job.
